Best filter brand is WIX; others I trust are Mobil 1, Bosch, K&N... so of your choices, Bosch.mechanicalmoron wrote:Best oil filter, of a standard brand?
I've heard in real life that fram makes good stuff. But I've read on nico that fram makes junk. Currently using fram.
My choices are, I think, limited to fram, STP, and bosch. I usually get whatever I can get free with oil, but what would be the best?
I picked up my feeler gauge for like $4. Make sure you use some assembly lube, $5.jbreze wrote:When reassembling cams, is it absolutely necessary to use a feeler gauge and other special tools? Im trying to do this as cheap as i can because i already spent more than i wanted to.
You put it together wrong, try again.....240beater wrote:Ok so i changed out the window motor on my passenger side door and now the effin window glass isnt flush against the....well i guess its "weather stripping" when its all the way up so when i get my car washed water pours into the door, havent re-attached the panel yet, do you guys know how i can get it flush again? BTW im talking about the stripping on the actual door not the roof part.
X-pattern. I usually snug the first 2 or so down, then move on to full torque after that. Bring them up to 80-85 ft*lbs. Repeat on the first nut you fully torqued. You won't hurt anything by hitting the others again though just to be sure.mechanicalmoron wrote:Proper method for torqing wheel lugs by hand? I do have a wrench that I think goes high enough, what's the spec, and should it be re-torqued or anything? X-pattern and repeat, right?
This actually happened to a co-worker I know. I managed to get the broken shank out with a pencil eraser. Fortunately the bolt snaps before it strips the threads in the headjbreze wrote:I broke a fricken cam bracket bolt... i feel so stupid.. there's nothing i can grab with pliers and i've never drilled out a bolt before.
Is this bolt extraction kit enough? Theres a 10pc kit but thats double the price
"Four-piece bit set includes all you need to remove damaged bolts
Includes #1, #2, #3 & #4 bits, and plastic case
Works with most types of broken bolts that are No. 5 and 6 - 1/4" (3mm-6mm) "
if the overflow is BOILING, I think you're in trouble, like your motor is melted.speakeasy wrote:So... I was driving around the block, not pushing the engine very hard at all, when I noticed smoke coming out from under my hood after about 30 mins... Popped the hood and saw it was coming from the overflow tank (my tank is cracked). The tank is only about a little under half filled with coolant, but the stuff that is in there is boiling.
What steps should I take to troubleshoot this? Or is there only smoke coming out cause my tank is cracked?
[edit]just checked, radiator fans aren't spinning...
It should warm up to about half way, and stop. It will get just as hot if not hotter at low speed, becuase there is less airflow through the radiator.speakeasy wrote:I didn't catch the temp gauge while there was still smoke coming out, but when I went back 30 mins later the gauge read a little bit past halfway. When I first start it up, it's on C so I'm pretty sure the gauge works.
Tried again today and did 2 laps around my street. Car starts and drives just fine for the 10 mins I was in it, though the temp gauge got to halfway again. Don't think it should be that hot for a low speed drive of about a quarter mile...
You might have skipped a tooth on your timing chain or something. With that many miles on it, your tensioners are probably maxed out. Over-revving a KA could be the (quite large) straw that breaks the proverbial camel's back. I'd pull your valve cover, put the engine at TDC on the compression stroke for cyl #1 and look at your cams. Intake cam lobe should be pointing between 9 and 10 o clock on cyl 1, and exhaust should be between 2 and 3 o clock.alfsnissan wrote:So, long story short, I over reved for a little, i have a tin can ratte noise when i acclerate and a little loss of power. Little loss in feul economy. When going steady speed, no noise. What does that sound like could be wrong??? Its a stock KA with round 200kmiles.Thanks.
99.9999999999999% sure it was from the tank. Smoke was coming from the crack in the tank and the coolant was bubbling in there, made it look like a tea kettle.mechanicalmoron wrote:It should warm up to about half way, and stop. It will get just as hot if not hotter at low speed, becuase there is less airflow through the radiator.speakeasy wrote:I didn't catch the temp gauge while there was still smoke coming out, but when I went back 30 mins later the gauge read a little bit past halfway. When I first start it up, it's on C so I'm pretty sure the gauge works.
If there's nothing funny feeling about the motor and no exhaust smoke or smell out of the ordinary, I expect the motor's fine.
Are you sure the tank's where the vapor came from? Maybe you had a small electrical fire from the wires near the tank, if the tank's cracked and it splashed over and caused a short? Check for burned insulation or gummy congealed antifreeze around the tank, bare wires, or other damage. There should be wiring and relays in the corner near the battery, in front of the tank, and a fuzebox beside it.
You could also have something totally different, if your clutch was burning the smoke can be blown by a breeze from the back of the car along the side of the motor, and come up near the front of the engine bay.
Have the cap, and if they can, the system, pressure tested, to see that it's not leaking before it reaches full pressure, and in doing so, not cooling as well.speakeasy wrote:
Yeah, actually to be honest as I was watching the smoke rise my heart was sinking because I thought it was the clutch (I'm teaching myself how to drive manual transmission), but after popping the hood I don't think that was it. I'll have the coolant drained and replaced, hopefully that's all it is.
You just line it up with the mark on the crank pulley. That's how you know you're at TDC. 9 and 2 is a bit off, but it sounds like you're just not on TDC.alfsnissan wrote:I feel that i have it as close as i can to TDC and the cams are it looks like 9 and 2. ???
I didnt. I redid it and am on TDC. The cam lobs are now pointed at about 10 and 2. Everything looks like it should as far as sprocket markings. I forgot to metion that the exhaust sounds diferant now also after the over rev. Could this be a broken valve spring or something???PapaSmurf2k3 wrote:You just line it up with the mark on the crank pulley. That's how you know you're at TDC. 9 and 2 is a bit off, but it sounds like you're just not on TDC.alfsnissan wrote:I feel that i have it as close as i can to TDC and the cams are it looks like 9 and 2. ???
