Yes, you will need to replace all the O-rings if you pull the rail out. They typically expand in a fuel environment. Don't forget to lubricate them with something before putting them back in so you don't tear another one.mechanicalmoron wrote:I (still) have a slight shaking engine problem:
I was just checking my TPS (.46v, close enough?) and just monkeying around, I opened the throttle..... and realized my manifold has fresh gas fumes in it. The ignition was on, so priming/primed, but the car has not been started since yesterday.
Injectors should not ooze at ALL, right? These are essentially brand new ones.
I'm thinking my problem the whole time might be one of the o-rings I put in got knicked.... but I only have ONE injectors worth of replacement O-rings.....
So if I pull the fuel rail to take a gander at the bottom, will I need new O-rings to mate it back up to the manifold? Or are those reusable?
Or is it even a potential cause? I don't have gas in my oil, but I burn through a lot of oil, this is the kind of car that changes it's own oil..... so I might not notice a little gas in it.
It looks like the rail is on 2 bolts only, if I take them out can I just slip it out to where I can see the injector tips without breaking anything or whatevers?
I kinda need to see the cam lobes instead of the sprocket in order to give you a more accurate answer. Theoretically if you line everything up the way it was when you took it out, you should be fine.danshaz82 wrote:i just want someone to double check this for me.
i put the head back on tonight and ive been playing around with the cam positions and timing (KA). i set this to what i believe is exactly how the JWT diagram shows. what do you guys think? yay or nay?
and the white marks are exactly where i marked them when i removed the chain.
Oil feed on the block as in, engine block?allenms240 wrote:So I was putting on my oil feed banjo bolt for the s15BB turbo, and the oil feed on the block is stripped. I have two choices the way I see it:
Heli-coil, or
tap to AN fittings.
I want to use the same braided line (which has a banjo connector to it) and put an AN fitting in its place, and tap the block and screw it in. The banjo fitting has an end that I believe to be -3an. So I was a -3an 14x1.25 fitting. What is your guys' take on this idea? Also, I've looked everywhere for this fitting and cannot for the life of me find anything close to it, let alone something that is -3an.
Please let me know.
_allen
You could always go with BRM exhaust too. I've never heard anything but praise about them.Toxsyl wrote:The Isis exhaust
That is the way I went. It sucks that each kit is about $40-50 for different sizes. I just fixed my stripped exhaust stud home on the engine block, and now I have to buy a whole nother kid for the oil feed. But I want to do it right, not have leaks pissing everywhere, so pay to play.PapaSmurf2k3 wrote:Oil feed on the block as in, engine block?allenms240 wrote:So I was putting on my oil feed banjo bolt for the s15BB turbo, and the oil feed on the block is stripped. I have two choices the way I see it:
Heli-coil, or
tap to AN fittings.
Please let me know.
_allen
I'd heli-coil first. If it leaks, then do something else.
I think this is the radiator I'm using, same price as the one you linked but designed for the RB, not the KA:Toxsyl wrote:I've seen this on some builds on this site so buy this radiator would be a good idea?
http://www.enjukuracing.com/products/Mi ... -KA24.html
The coilpack and injector harness are just additional sub-harnesses that do not come with the new engine harness. Most people re-use their old ones as others replace them with new ones. No additional wiring is required with either option.Toxsyl wrote:So in the Raw Brokerage RB25DET Deluxe swap kit I noticed a Coilpack and Injector harness options. What would those do, and am I better off grabbing those in the package?
Also noticed something whats the difference between the R33 RB25DET S1 and S2?
Papasmurf, I'm from the Netherlands.PapaSmurf2k3 wrote:if I were you, I'd stick with the CA as long as it is in good knack. Also, I'm no CA expert by any means, but you might be better off saving money on the head swap and putting it into more/better turbo goodies, fuel system, engine management, etc.
What country are you in?
