Someone needs to clean up this forum!
audtatious
Good deal....
For now I've added your list to the FAQ thread. If you find more stuff you can post it in this tread and I'll simply add it to Wes's post.
fueler
Car: 2 Nissan's
2 BMW's
slickroger
Car: 2001 Nissan Pathfinder
Window Trim Thread - zerothread/359249
Tint Thread - zer...ights
BOSE Stereo Thread - zerothread/304088
Stereo Upgrade - zerothread/350117
Empty V
Car: 2001 Infiniti QX4
1982 Chevy Corvette C3 Shark
slickroger wrote:Window Trim Thread - zerothread/359249
Thanks Roger! I updated the post with the window trim thread, the others don't really have any "How To:" type info unless I missed it and if I did I apologize.
Billy
slickroger
I think some of the subjects should have multiple threads under them because there are different methods used.
Im saying this because there are multiple window trim, fog, dash and tint threads. Including ones i haven't mentioned yet
Empty V
slickroger wrote:I think some of the subjects should have multiple threads under them because there are different methods used.
Yup we've already got 2 seam foam threads and just put of Brian's window trim thread.
Billy
Empty V
Okay now what about creating the sticky for this, just use the list posted and we can keep adding in the new stick thread.
Billy
Empty V
Bump, mods where you at?
Empty V
fueler wrote:well the links need to be cleaned up first.
instead of
Replace Window Trimhttp://forums.nicoclub.com/zerothread/359249http://forums.nicoclub.com/zer...46113
u need to put it like
QX4 / PATHFINDER - REPLACE WINDOW TRIM
How's this?
INDEX OF FSM'S
Maintenance
SEA FOAMING YOUR QX4/PATHY 1SEA FOAMING YOUR QX4/PATHY 2
RESETTING THE WINDOW LIMITER SWITCH
FIX SLOW WINDOWS
BRAKE ROTOR AND PAD REPLACEMENT
REMOVING THE INSIDE DOOR PANEL
IN-CABIN AIR FILTER REPLCAEMENT
THROTTLE BODY CLEANING
REPLACE THE PCV VALVE
CLEAR THE ECU MEMORY
RE-LEARNING THE ECU
REPLACE THE WINDOW TRIM 1REPLACE THE WINDOW TRIM 2
Modifications
TWEETER MOD
CHANGE OUT THE SECURITY LED
CHANGE OUT WINDOW SWITCH/DOOR LOCK LED'S
SWAPPING OUT STOCK GAUGE/DASH LIGHTS FOR LED'S
FOG LIGHT MOD - RUN FOGS AS DRL'S
AIR BOX MOD
Upgrades
HEAD UNIT REPLACEMENT
Modified by Empty V at 7:28 PM 9/9/2009
audtatious
I've updated the FAQ stickie with the above.
Empty V
audtatious wrote:I've updated the FAQ stickie with the above.
Thanks but can you create a "HOW TO:" sticky so it's easier to find? I also corrected the spelling of Index for the first link and the AIR BOX MOD link
Billy
jsm02cpa
Car: 2000 QX4
Another fix to add is the one that WOT did on how to take out headlight lens scratches.
Someone just asked about it, and it would be something that many people would think they couldn't fix, and blow money unnecessarily. One of the neat things about this site, helps us all save money on fixing stuff ourselves. Thanks guys.
slickroger
i thought what we had here gets added to to the *pathfinder/qx4 faq*
Empty V
MODs are you getting this? Come on guys lets get moving! Since you haven't appointed a dedicated MOD to our forum you will have to keep updating the thread that you have yet to create, which obviously includes inserting suggestions like Roger's for content.
Billy
fueler
Car: 2 Nissan's
2 BMW's
i suggest we insert a link about the death sway which is a very common problem in R50's, probably the most conmmon problenm
slickroger
Please Add
How To: Add extra Alarm lights
How To: Hook up Trailer light How To: Changing cigarette lighter ring, heated seat, and rear defrost lights w/leds
Modified by slickroger at 2:44 AM 9/12/2009
slickroger
Bump
slickroger
How To: Clean Climate Control Sensor
How To: Painting Stock Rims
Modified by slickroger at 1:46 PM 9/22/2009
Empty V
slickroger wrote: How To: Clean Climate Control Sensor
Thanks for those Roger. It's a shame the mods have forgotten about us again and we still don't have a dedicated "Hot To: List" sticky. I also think Fueler has something with the Death Sway. Maybe we should also add in the blower motor issue and the stuck seat motor issue.
Billy
slickroger
How To: Add extra Alarm lights How To: Hook up Trailer light How To: Changing cigarette lighter ring, heated seat, and rear defrost lights w/leds How To: Clean Climate Control Sensor How To: Painting Stock Rims
Whats the deal here there is tons of stuff in here that should be in the FAQ
What the F?
Modified by slickroger at 1:50 PM 9/22/2009
Empty V
slickroger wrote:Whats the deal here there is tons of stuff in here that should be in the FAQ
Whats the F?
You got me, I think once again the MOD's have forgotten us. This is supposed to be it's own sticky not in the FAQ. There's no reason to make it difficult to find.
Billy
Empty V
Here's another one:
How To Detail Like A Pro
Billy
slickroger
BUMP BUMP BUMP
How To: Add extra Alarm lights How To: Hook up Trailer light How To: Changing cigarette lighter ring, heated seat, and rear defrost lights w/leds How To: Clean Climate Control Sensor How To: Painting Stock Rims How To: Detail like a Pro
ADD TO FAQ PLEASE!!!!!!!!!!!!!!!!!
Empty V
slickroger wrote: BUMP BUMP BUMPADD TO FAQ PLEASE!!!!!!!!!!!!!!!!!
Dude it's not the FAQ it needs to be added to. They need to create a sticky for it. They've obviously forgot about us so we've just got to keep bumping this thread until they figure it out.
Billy
Empty V
Well I emailed Greg from NICO last week about this thread and haven't gotten a response. I'm sure he's just really busy with all of the important sections of NICO. And they say we don't need a PM system.
Billy
Empty V
Here's another one thanks Roger!
Changing Green Displays to Blue
Billy
sicwitit
Car: part fabricator
So, do you have to be a mod to make changes to the forum or is there someone else thats responsibe for the frontpage? If mods can do it, how do you become one? I spend enough time just sitting on the forum, I could use some of that time to do something constructive.
Empty V
sicwitit wrote:So, do you have to be a mod to make changes to the forum or is there someone else thats responsibe for the frontpage? If mods can do it, how do you become one? I spend enough time just sitting on the forum, I could use some of that time to do something constructive.
Only a mod can edit other member's posts, create sticky threads, threaten members and generally change things around. They don't pay attention to our section so them appointing a suitable pathy/qx4 owner to take over is doubtful. We campaigned for Fueler a while back but they weren't having it and made it totally clear that we have no vote. It is what it is. If it's any consolation I'd vote for ya bro. If I was a mod I'd be banning people who habitually have poor grammar and ignore their spell checker.
Billy
Pwnin O'Brien
NPORA got a facelift today. C'mon NICO, get it together!
That's all I have to say.
Empty V
Here's one more. How To: Changing the Fuel Filter
Can we get a status on this? These are some really useful walk-throughs that need to be permanently posted at the top of the forum. Come on NICO help us out!
Billy
