I have never herd of this being a problem. How on earth would you get death sway on a R50???fueler wrote:i suggest we insert a link about the death sway which is a very common problem in R50's, probably the most conmmon problenm
It's a pretty big issue. It was extremely severe on my Q because of worn Trailing Arm Bushings, others get it from worn control arm bushings(I think). Fueler got any good links? Maybe that would be a good one for common issues.Fisherdude wrote:
Thanks dude! There's a ton of more content in this thread that needs to be added. If you could go through it, it would be a great help.audtatious wrote:You should see a new How To sticky and I've cleaned up the FAQ thread.
Splain.alexf20c wrote:oh look, another redundant and poorly organized thread!
You can add links in replies to the thread and I'll make an effort to check into here more often to combine them until we come up with another solution.Empty V wrote:
Billy
