ehh it was a little but it was a PITA takin the stock 4 lug unit off that was not funpositronone wrote:Fun putting those rear brakes on huh?
Ok sweet so i just need to get the Z32 2+2 ebrake line now and put them on, adjust it, then my ebrake will work?positronone wrote:Mine went straight to the T-bracket and then I just needed to adjust the tension with the adjustment nut on the e-brake handle.
Yeah, there's even a stock hole in the subframe that the lines run through and then straight to the T-bracket. I had no problems after I did that. I've parked on hills and everywhere.Slideways^Jordan wrote:
yes takeing the steering wheel off does make it super easy i usally drop the steering colum a litle bit for a little more ease.inkslingers13 wrote:or as a said above SHARPIE works great, does noone read? if you take your steering wheel off its very easy...
idahotuner wrote:isnt it a top speed intake mani?
thanks dude i will hit up those links i think read will look sweet. my dash is installed but i have pulled my cluster out before so that is probably all i would have to do
umm idk for sure but im just useing the cluster that came off my front clip and then i just swaped out the kilometer faceplate to the MPH.SRspoolin wrote:when you switch the 7.5k tach into the usdm cluster, there's nothin else you gotta do right?
yeah its awsome cuase i know the exact milage on my engine around 75000 miles .idahotuner wrote:^ werd up using the one that comes with clip. i dont know about swaping out the face plates though. it would still be off. just ride jdm.
