YEah man lol i was surprised how clean they were I open the box they were shipped in littlerly brand new.idahotuner wrote:dude those are soem nice bricks. i want to get bricks so bad.
Wow yeah ive seen those before how much are they on zilvia and who sells them whats their screen namecodyace wrote:Be leery of those cut and clamp style water temp gauge things. They are just asking for leeks and wierd readings.
Your best bet would be to get one from custom steel, or off Zilvia that bolts between the factory water neck and the head
Pics of mine:
dude thanks alot. i am going to get one of those as soon as my water temp gauge comes in. i didnt like the idea of cutting my hose either. this is really cleancodyace wrote:http://www.customsteel.com/sr20
That is for the FWD Sentra one (like mine) that hids the sender under the cas, keeping it clean.
http://www.zilvia.net/f/showth...apter
For the Zilvia one by Touge Factory (which puts the sender ontop)
Yeah thats totally tru Its the best bang for buck typa thing lol.codyace wrote:In most cases, this little add on is cheaper than the in hose pieces as well. Plus then you don't have that ugly clampped section and random ground wire running along it
OMG Hey man im sorry i never got around to posting why i stitch welded it and how i did it.inkslingers13 wrote:can you please explain the stitch welds? how do i go about doing it?
Yeah thats exactly why i did it cause i dont want to see that happen to my car again ever.GTR PrYdE wrote:You're talking about the OLD couple right? Your new couple was stitched to prevent that, correct?
Yeah i need to buy me a waterneck adapter realy soon but maybe after the starup idk.idahotuner wrote:well i ordered the little adapter for my car today it is going to be nice and clean i am excited. also made a check list of tiny things i have to do before i can start my car.
those are some nice stiches man. i kinda wis hi could do that to my car. but no reason to since i wont be trackign it super hard.
Hey Thanks man, umm yeah their is a little bit of room but not much my dump pipe elbow actually touches the brake booster and the firewall But im wrapping the elbow and i have a turbo blanket for the turbine side of the turbo. so it should work.white90esex wrote:sweet build up man.
Quick question. Does that Peak Boost Turbo Mani leave enough room between the turbo exhaust housing and the brake lines?
-Thanks-
If it's touching now, it'll touch more when revving.Slideways^Jordan wrote: Hey Thanks man, umm yeah their is a little bit of room but not much my dump pipe elbow actually touches the brake booster and the firewall But im wrapping the elbow and i have a turbo blanket for the turbine side of the turbo. so it should work.
I strongly suggest removing that tube and purposely denting it in that area to keep it from rubbing. If that touches, it'll only promite cracking and make bat rattly noises
As far as the brake lines are concerned, I would sugest looking into DEI or similar heat sheath for them.
