05civse »
https://forums.nicoclub.com/05civse-u39056.html
Tue May 02, 2006 3:40 pm
I am installing the DCC from a 180sx front clip in my 240sx. Should I use the JDM main harness or just use the USDM main harness? (The JDM harness is cut where the back of the car was cut off under the driver’s seat) Anyway, I am trying it with the USDM harness and am very confused now (not with the harness thing). I swapped the JDM blower speed sensor, installed the mix door motor, sun load sensor, cabin air temp sensor, hooked up the three positive wires (single red, blue/red, and green/white). I also went to the JDM thermo sensor. My first problem is the usual when I plug in the fan motor plug (USDM) it goes to full blower (people have talked about this before, but I never found out how to fix it). My second problem is I had the DCC powered up but it flickered on and off before, but now it wont even turn on. What is up? I just want to finish this so I can put my car back together (no dash). Thank you very much for any information anyone has, I really appreciate it. Have a great day!
