P_Productions wrote:Hello,
I'm attempting to convert my analog climate control into a digital climate control. I purchased a semi complete Digital controller. I'm a little confused on what parts I need to have everything needed.I have been reading this thread for a while but I want to make sure I have a complete understanding of what I am going to do.
According to member ericherm1, I need this following parts
1. Japanese Digital Climate Control I have
2. Plug to fit Japanese Digital Climate Control (from 89 Infiniti i-30) I have
3. Sunload sensor* (from 96 Maxima) I have 4. Plug for Sunload sensor* Need to get
5. Ambeint Air Temp Sensor* (from 96 Maxima) Where is it located on the Maxima, what does it look like? 6. Plug for Ambient Air Temp Sensor*
7. In-Vehicle Air Temp Sensor* (from 96 Maxima) ) Where is it located on the Maxima, what does it look like? 8. Plug for In-Vehicle Air Temp Sensor*
9. Aspirator* (from 89 Infiniti i-30) Where is it located on the i-30, what does it look like?
10.Thermo Control Amp (from 96 Maxima) ) Where is it located on the Maxima, what does it look like? 11. Plug for Thermo Control Amp
12. Thermal Transmiter (from 89 240sx) ) Where is it located on the 240sx, what does it look like? 13. Plug for Thermal Transmiter
* = Not needed if you do not wish the AUTO function to work. AUTO fuction keeps interior at a selected air temperature.
Will I still need these parts even though I already have a JDM harness?-Extra Parts you need to make a new harness 14. Plug for Intake Door Motor 15. Plug for Door Mode Motor 16. Plug for Air-Mix Door Motor 17. Plug for Bi-level Door Motor 18. Plug for Blower Motor
Heres a pic of what I got. ANy help, suggestions.
P.S If I get everything working I will make a Write up with alot of pics and credit those who have helpedThanks in advance
Yes and no, all the sensors for the auto feature will work ie, outside temp sensor, inside temp sensor, and sun sensor. The only thing that you will need is the mode door motor.P_Productions wrote:Will the sensors and motors from a JDM analog climate control work with the digital? The JDM Analog control has the auto funtions.Thanks
Yes, I only need a redtop compressor and bracket. I tested the wire that goes to the compressor with a multimeter and it does work like normal. So anyone out there have a good redtop a/c compressor with the bracket.Dammitboy wrote:Read somwhere those components were not compatible. You'd still be lacking your sensors for the auto function.
Eric, does your a/c work in your swap?
