UPDATE: 1/3/2012
DIY FIX AVAILABLE:
- 1) Shifter Stuck In PARK Fix
2) or for the second type of shifter/park issue scroll down to page3
Actually it's not very common. I think have only heard of one other report on these forums about the shift interlock issue. And don't recall how it was fixed.1. Is this a common problem with the Rogue or is it just my luck? My car is fairly new and I'm not quite sure why this is happening.
You mean Toronto, Ontario, Canada. Just to clarify for our fellow American Rogue owners...2. Where can I find a good and trusted independent shop in the Toronto area specializing in Nissan vehicles? I dont want to bring it to the dealership anymore as they are charging me an arm and a leg to do the simplest of things.
Sounds like this tech is just taking a stab in the dark... yikes! The service manual has very specific procedures on how to troubleshoot the solenoid and related controls. Did he even perform this?paul_animo wrote:Any other suggestions guys?
The QR25DE motor and CVT used in the Rogue is shared with the Altima 2.5 and Sentra SE-R.TaiLuu wrote:Since I heard the Altima has the same motor and transmission as the Rogue Might wanna go to the forum to see if they have the same problem.
The Altima and Sentra have different shifters. It's possible that they could share parts, but not guaranteed.Solenoid should be the same but in different location.
The brake lights are completely separate system. Having one or both brake lamps burned out will not affect the shift lock system.otto888man wrote:Are all of your brake lights operational? If the bulbs are gone , the shift solenoid wont engage properly.
kerrton wrote:mstrmstr, Thanks so much for this contribution to the forum, this is really valuable information and like you said could save someone a lot of stress and the cost of a tow job!
camtris wrote:I am having the same problem shifting from Park to drive and I was told by the dealer it will cost me $750 for parts/labor and it would be a few days before they could order and get the part. Whats up with that, i'm about ready to trade-it in. Not covered under warranty and not a common problem. I think they should cover it.
