lethbridge »
https://forums.nicoclub.com/lethbridge-u191485.html
Fri Sep 30, 2011 7:36 am
Hi all, very glad I found this forum. I have been experiencing the problem with the brake shift interlock solenoid as well. Just want to give a bit of background first.
I bought a 2008 Nissan Rogue SL from Milton Nissan in Milton, Ontario. The first year things were pretty good, no real concerns, then one year at the start of winter, I had the problem where the d/s door wouldn't open from the outside. The handle would stick out about half an inch, it would move, but wouldn't engage the mechanism to open the door, still worked from the inside though. Contacted the dealer and they told me that Nissan had put out a service bulletin about this, and that it was the same as a recall, just that they didn't have to contact everybody because not all vehicles were affected. The dealership fixed it for me under warranty without an issue and I was on my way.
The next year at the start of winter again (actually on the first snowfall) I had the same problem with the d/s door not opening, with the same symptoms as the first time. I called the dealer again and they told me to bring it in. When they were done looking at it, they told me that this was different from the last time and I would need to pay to have this repaired. I asked how it was different when all of the symptoms were completely identical, and the service guy couldn't explain how it was different, his only answer was "it just is different". I flat out told him that there was no way this was different and quite frankly I knew he was lying to me. I told them to put the car back together and I will deal with it myself. I contacted Nissan's head office, and while they agreed that this was described in a service bulletin, which is the same as a recall, they said that because the car was out of warranty, they couldn't help me and I would have to sort it out with the dealership. They couldn't explain to me how if something was considered to be equivalent to a recall, then why would a warranty even matter.
Fortunately I was able to open the d/s door by reaching from the d/s back door and hopping in that way, so for the next 4 or 5 months I drove it that way. Finally I took it to a mechanic and he fixed it for me, explaining that this problem is exactly what was described in the service bulletin.
I should also explain that since about 6 months after delivery, I started to have the problem with the shifter, and when I took it to the dealer for the maintenance, they were able to reproduce the problem, but they didn't fix it because they said it would probably go away on its own. In the last few months, the problem with the shifter has become increasingly frequent. I normally have to turn the car off and on a few times before the shifter will engage. One time my wife put the car in park when going through a drive through ATM, and it took her over 10 minutes to get it out of park again, with a large lineup of cars waiting behind her. I am going to see if I can get this part and fix the car myself, as I have 0 trust in Milton Nissan. Overall I would say that I am very disappointed in Nissan and the chances of me purchasing another one of their vehicles is very low now.
Thanks for letting me rant, this thread has been a great source of info.
