It is update time again and I have some good/bad news. The good news is that I pulled the gas tank, used the old gas to put a 1/4 tank in my camry.lol. The bad news is what I found after all was done and said.
So it isn't lookin good from the get go...
The filler neck is done for. I also found that almost every clamp fitting on the brake lines and so on are rusted and broke...
The gas line fittings are the best ones I had seen
After I removed all of the gas lines, I lowered the front half of the drive shaft and pulled the heat shield off of the tank.
I don't know if I had said anything before but I accidentally hit the 4 wires going to the fuel pump with my grinder(with wire brush) while I was removing seam sealer for stitch welding. Since the wires were already a little mangeled, I decided to cut them and then I pulled the fuel pump cover off and pulled the wire thru.
Once that was done, I dropped the gas tank.
From there, I hit the leads to the fuel pump with my electric impact battery and shot the fuel into a gas can to transfer it to my camry...
And that is when I took a peek at my underbody...Go figure...more rust
And how my garage was left last night. The pic doesn't include every rear multi link suspension part by my feet but i do have some room to move around...Thats always a plus.
And check out my How To remove a subframe page and give me some feedback...how-to-s14-subframe-removal-t513733.html
