***UPDATE***
Well, the motor didn't check out. 3 cylinders had 150 psi and 1 had 30 psi so thats a no go. I am joining the military so I bought a new tv for when I get stationed somewhere. That was a bit of my cash but I think it was worth it. Especially when Call of Duty Black Ops comes out in 3d. Say goodbye to my old tv...
And say hello to the new one
It is a 65" Mitsubishi 120hz 1080p 3d tv. I also got this for free when I bought it...
but other than that, I have put some work in on my car and got some pics of the holes I shaved from the wing.
And here is the crush bender I now have...
and now the real update. Saturday was a little slow in the afternoon so I decided to pull my subframe. I did it by myself and used a motorcycle jack to aid.
In total, there are 4 large nuts for the subframe mounts, 4 medium bolts for the L-shaped bracket towards the front, the sway bar bolts, driveshaft bolts, fluid drain, vent hose, and two 10mm bolts that hold the e-brake lines I believe.
I did find the energy suspension bushings looked like they were in good condition so I think I will be keeping those and a Magnetic drain plug on the diff
I am selling my old sway bars so here is the link.
mo-s14-front-and-rear-sway-bars-t513511.html
