ssnnooppyy »
https://forums.nicoclub.com/ssnnooppyy-u1584.html
Sat Mar 22, 2003 12:41 pm
Okay, okay.... if you have ever broken your gas cap release handle, you know htat you can still get into the gas cap.... then, one word SUGAR. Also, the lighter trick is semi-true. It won't make the exhaust fall off, butit does make a rather large noise, with moderate fire. It has to be done shortly before they start the car to be truly effective. Cutting the valve stems is great. If you are really sadistic, a little slice will result in loss of air at an undetermined point. (slow leak, stuck on the road kind of thing). Also, for a little silly fun, but still a little dangerous, pour armor all or equivalent on top of each tire. (on the top of the tread area). This will be short lived fun, but when the tire rotates to the point of origin, it will tend to slide. (ever overspray tire wet??? gets slickery!) Sardines in the cowl, cat s*** under the door handles, and maybe some rotten eggs in the exhaust. It really would be in your best interest to get the m in the act via video tape, then add some "extra" damage to your car for effect, and turn the tape over to the cops. They will have to at least question them, and that makes people nervous. Well, it made me nervous!!!!
