MR. Q wrote:What did you use to clean your fuel rails? How did you clean your injectors? What about your fuel damper, those small canister things I think there's two of them. Looking good! i plan on posting some pictures of my plenum I got it real clean on the inside. Still dirty by the 8 holes though. More cleaner. In a minute my sir!
My fuel rails I used brake cleaner then ended up sanding them but it doesn't really do much except turn them silver.My injectors soaked them in Redline SI-1 complete fuel system cleaner it's like $8 I think a bottle.I just used the whole bottle in 2-3 different cups.I soaked the whole thing but somebody told me not to get the connectors wet so keep that in mind it was too late for me.I ohmed them again to make sure they weren't bad either.The fuel damper I sanded it down that's all.It came out silver I was like
Thanks and I sandblasted the Plenum,If you do that don't sandblast the inside because if you leave some of the sanblast inside it'll tear the pistons into dust.
You can email me for faster replies at
[email protected] more to come.
edit:Knock sensors came in aftermarket ones.Well sorry to disappoint you guys but I have to pur these on because I cant be with out a car anymore.If they fail well then I shall do double the work again.
Modified by unknown007 at 3:15 PM 3/2/2009
