Jacko3 wrote:C-Kwik:
I am not going to beat a dead horse with you. I ma glad you stuck only to the physics portion of your argument, and not the heat trasfer portion and chemistry portion. I will grant you that the facts you present as fas as density and thermal conductivity is correct. However, you have failed to describe your findings in terms of heat transfer.
I don't follow you as thermal conductivity relates quite highly to heat transfer. In particular, conductive heat transfer.
Jacko3 wrote:First of all, thermal conductivity leads to either cubic expansitivities for gases or linear expansivities for metals. When two pieces of metals or solids are interacting, heat is genrally trasferred between the two metals/solid, and heat is dissipated in either direction of the two friction filled metals or solids. To stop heat from moving by conduction through both metals/solid, seperating both metals so that air or a gas either naturally aspirated or through forced convection (much better technique), is used to dissipate the heat away from both metals.
Expansivities? I don't think that's actually a word. But it sounds like you are trying to describe thermal expansion. Which has no relevance in this discussion.
Friction certainly has a place here, but your application of it (If I am interpreting what you are saying correctly) is off. Friction in that of itself does not generate heat. There needs to be a net force of more than zero for heat to be generated. Think of it this way. If you park a car on a hill, the parking brake is set. The car remains stopped as there is frictional force between the tires and the ground. No heat is generated here as the net force on the car is zero. On the other hand, if you were to drive along at 30 mph and yank up the parking brake locking the tires, the car would begin to decelerate due to the frictional forces between the ground and the tires. The energy kinetic energy from the movement of the car is converted to heat, sound, and perhaps mechanical energy that begins to tear off molecules of rubber.
This applies to clutches as well. When a clutch is fully engaged, the net force is zero as the flywheel and pressure plate are (should be) moving at the same speed. When partially engaged, the clutch disc will be rubbing against the pressure plate and flywheel, generating heat because there is a net force other than zero.
Jacko3 wrote:So, however, poor the heat transfer charcteristics of air is, matters little to the extent that the air truncates the dissipation of heat either way between two solids.
My argument here is twofold. A flywheel typically represents a considerable amount of mass (20 lbs in most small cars and something like 30 on the G35). As a result, it functions effectively as a heat sink. It would take a considerable amount of energy to heat it up significantly (a least to a point where it starts to affect/degrade performance). However, the local temperature at the surface of the flywheel and clutch disc can be overheated with relative ease if one tried to do so (or drove very poorly). As the clutch disc is relatively light and uses a a composite of materials whose average density is fairly light, it tends to hold little heat energy. As such, allowing the clutch disc and flywheel to remain in contact would reduce the local temperature of the clutch disc effectively while the flywheel's overall temperature is affected by only a small amount. The only way your argument can hold water is if the clutch disc and flywheel were at the same temperature, in which case convection could not occur.
But the problem is that your flywheel should never reach or even come close to such a high temperature that would cause a problem with its operation. Therefore its a moot argument to make.
Jacko3 wrote:Secondly, your argument fails to show that the most effective way for metals to dissipate heat during a heat transfer process is by contact with a fluid. A fluid is any substance that has viscosity and can exert pressure. This includes gases and liquids. Thus, the more abundant fluid to aid in the effective heat transfer when cooling solid substances is air. It occurs naturally.
Convection involves movement of the fluid itself as a medium for heat transfer. But it does not occur independently. At the surface And to some extent throughout the volume of air) conduction will also occur. Molecules in air are quite far apart. Molecules in liquids are closer but still relatively far apart. Solids are quite tightly packed. This is very evident by simply looking at the density of substances in various forms. That said, heat is simply the result of excited electrons that move faster. Conduction occurs as these electrons collide with electrons from other atoms causing them to move faster as well.
Jacko3 wrote:While I take you explanations seriously, one is not truely compelled by them. And then, I thought we were done with this argument. So, you are unable to let sleeping dogs lie. And you feel a strong urge to continue to beat a dead horse. Well, to each his own.
We were done according to whom? You? As far as I can tell, the thread was closed due to poor behavior, a new thread was started regarding the closure of the thread and then it was merged with the old thread with a warning to play nice. I do not know what comments were made and by whom. I don't see why this discussion can't continue as long as everyone remains mature about it.
Jacko3 wrote:I would still love to hear your chemsitry portion of your explanations. Of course, I expect you will study hard to provide a good explanantion. Nonetheless, nice attempt. If I had to give you a grade for your physics, I would assign a greade of 6 out of 10, because you have not satisfactorily provided a robust explanation for the heat transfer process. Read my previous comment again, and read my present comment, and you will come to have a good understanding of heat transfer. I won't even bother you with the mass transfer portion of this whole deal.
Much of the discussion we are having at the atomic level is considered chemistry. So I'm not sure what you mean by "chemistry portion." Frankly, chemistry and physics do not exist in vacuums (except maybe in theory). They are intertwined in nature, It is no different in a car.
I'll end this post with a challenge to you, since you are so critical of the info I post. If you are right and I am wrong, please feel free to provide a technical explanation. I am all ears.
