Re-Tuning G35 engines to run on lower Octane
C-Kwik
Jacko3 wrote:2. I used the word "slightly" because I was trying to show the difference between pulverized material that has been put together by a bonding agent (clutch) and a piece of metal (fly wheel) which is a product of processed Iron III Oxide. A clutch surface is simply dusty material bonded together under pressure and heat treated, to keep it together, while cast iron is simply cooled liquid metal. Yes, their conductivities are way apart than I had suggested.
Generally, in frictional devices like this, it's the vaporization of these bonding agents you describe that you smell.
Jacko3 wrote:4. You said, ".....i have to question if those tempatures could even be generated, if they could it would be during severe slipping, not from microscopic heating and expanding." You are right to the extent that the vehicle is properly maintained. A vehicle that is not well maintained as a result of a lack of changing the oil religiously, or a fouling of the inner engine wall cooling heat exchange surfaces as a result of not changing your cooling fluids as specified, will cause the engine to generate more heat than it was designed for. Every engine can tolerate more heat than the cooling sytem is designed for. However, it degrades the life span of your engine, and sends more heat than is necessary to parts that have been designed to wear out with time such as the clutch system.
If there was a problem with a motor that caused this type of excess heat, I'd be far more concerned about my heads warping or the engine detonating than any clutch heat. Even then, you have to consider that the further away from a heat source an object is, less of the heat will actually make it to that object. Every part from the combustion chamber back to the flywheel has mass, volume and surface area. Every part will spread out any heat it has through conduction, convection and radiation. The portion that actually connects to the flywheel will act as a heat dam as I already mentioned. Any increase in temperature in the engine would have a proportional effect. Not a direct one. As an engine can start to overheat when the coolant temperature is as little as 265 degrees F, a small proportion of the 45 to 75 degrees of higher temperature would even make it to the clutch.
Jacko3 wrote:This is enough heat to aid in the process of an explosion of small microscopic matter. Microscopic matter does not explode from the heat. They explode from their creation of electric charges within the atmosphere of their creation inside the bell housing. The excess heat only aids in the creation of more microscopic matter by detioriorating the clutch more rapidly than normal. The explosion in the suger factory in Georgia from small particles, occured at night when it was actually cooler. This is another reason why auto manufacturers have to design clutches to erode slowly rather than quickly.
The sugar factory in Georgia involved volatile particles. I highly doubt there to be significant amount of volatile particulate matter (if at all) in a clutch disc that can be combusted in the same process (or any for that matter).
Jacko3
My dear C-Kwik:
Where do I begin?
1. What does big block, small block, medium block have to do with heat dissipation and conduction? Does cast iron decide where it wants to take heat from or where it wants to let heat go or does the engines aluminium walls make that decision? I doubt it.
2. When you drop of your car after driving for say, about 30 minutes, and you open up the hood, do you feel some heat or not, inspite of the very good cooling system you have in your car? And you really feel any metal component of the car does not feel that same heat? Please explain to us more about this anomalous explanation? Invariably, you are saying that the flywheel is somewhat insulated from the very same heat anyone can feel when they open the hood of a car that has recently been driven.
3. Engine is made up of some aluminium, and fly wheel is made up of Iron. Both are metals and so both will get heated at any rate. Engine will give away heat faster than Flywheel and will absorb heat faster than flywheel. Thus, a flywheel is a sitting heat sink and duck. Btw, no one ever uses the term heating dam. We call it heat sink or heat dump in the world of engineering. A refrigerator compressor is a classic heat sink.
4. Primary source of heat to flywheel is by convection and secondarily by conduction. Thus my earlier focus on convection. Why? The surface area of the crankshaft in contact with the any surface area of the flywheel is very small. But the surface area of the flywheel in contact with the heated air from the engine wall is in totality of the area of the flywheel. So the crankshaft could not possibly heat up the flywheel as effectively as you have erroneously described. The main heat to the flywheel comes from the heat accumulated or developed on the outside walls of the engine that is being transmitted by convection or air to the walls of the flywheel and other parts of the car. When you open up the hood of your car after driving, the heat you experience is by convection. Your flywheel experiences that same heat. There is no insulation b/w the engine wall and the flywheel that is effective enough to reduce the heat. If you know of one, please tell me.
5. Better materials are absolute. What you are talking about is individual comfort. Yes, some people may prefer OEM clutches to ceramic based clutches which might chatter a little more. Certainly some people will be comfortable with some types of materials than others. A better material is simply one that can dissipate heat fast and absorb heat less. This charateristics is absolute. I really wouldn't like to go into the theories of heat absorption. There is no need for it.
6. Ceramics have been known to be great at this heat characteristics. They also double as insulators as well. Haven't you heard that ceramic breaks don't wear out as fast as the asbestos brakes? why do you think this is so? So you think, the after market guys are just deceiving the buyers of ceramic brakes? I just explained why, in my write up above. The reason they have ceramic materials is because it is a good insulator of heat because it does not absorb heat very quickly. And when it does, it dissipates the heat very fast. the same ceramic materials are used as heat shields in NASA's space crafts. Ceramics don't yield to expansion as quickly as asbestos do.
7. Thermal expansion naturally reduces the tendency of a material to maintain its lateral load when coupled with another material with a different coefficient of friction and atomic make up. Another simple reason for this is that particle sizes and arrangement, of both the flywheel cast iron and the asbestos, on the clutch, are different. Thus, heat will render the particles of the least packed atoms (clutch particles), more prone to disintegration than the particles of the most packed atoms (flywheel). The physics you describe only aids in speeding up that process. This issue is first and foremost a material science issue and not a physics issue. You can throw in all the lateral load you want, if the material is not stable under increasing levels of heat conduction, your laterally loaded material will fail. Every material is subject to the effects of heat and its properties. Load only speeds up the detiororation process, and it is the job of the engineers to find a material that will withstand the lateral load for a specific amount of time, as dictated by the manufacturer. Thus, material science tests are always crucial, and conducted, in any part of a machinery that will experience some type of heat absorption, and yet accept some load.
8. Engineers are bound moreso than any other set of factors, by safety and cost. Any engineering feat that fails to live up to safety and cost, is almost always shelved, regardless of how good the technology might be. For example, it has taken forever for run flat tires to make it to main stream auto world. Well, the safety issues of run flats are pretty good an obvious, but the costs still remain prohibitive. So, run flats are only found in cars associated with thew wealthy who have an income inelasticities to any good or product they demand. Asbestos in most clutch systems has been shown to be relatively safe and inexpensive, ceteris paribus. So, why mess with it if it ain't broke? Asbestos is so cheap and so convenient that it took law suits to remove them from paint and roofing materials in homes in the US. Yet, they are still popular outside the US.
9. You will need a thermal boundary once the clutch smell occurs, only for a short duration dissipation of heat built up between the clutch and the flywheel. That heat build up is not from the interaction of the flywheel and clutch. Rather, it is from the heat absorbed by both the flywheel and the clutch that slowly degenerates the clutch, since the clutch itself has less packed atoms than the flywheel.
10. I am fully aware of driving hard and abusig a car.
telcoman
DaveGreg
I hope you got all of this? There will be a quiz soon
Jacko3
1. I have worked with bonding agents to know how they smell. What I smell, is consistent across states, across time, and across different car models. All the auto manufacturers could not possibly use the same bonding agents for eternity. When I was a kid the clutch smell my olfactory organs picked up then, is the same smell I am picking up in my car today.
2. It takes a lot higher temperatures than you stated to warp the heads of a car. A failed radiator fan, old engine oil, a failed radiator, or any number of things could cause a significant rise in temperature. By the way, by the time your car shows sign of a warped head, or overhetaing, the temperature was already too high for many minutes, before it becomes obvious to the driver. An overheating car does not just suddenly show up immediately. I can see this becasue when I once had a broken radiator in my little Nissan, I was cruising at about 70 miles per hour for about 20 minutes. At the moment I stopped, the radiator just went bad. So, if you are driving around, the air coming form the outside works to keep the head going bad for as long as it can before it eventually becomes obvious to the driver, many minutes later.
3. Asbestos is a volatile particulate matter fused together by heat treatment and pressure onto your clutch. If allowed to disintegrate too much, it can combust. Teh more efficient heat transfer in modern cars, is making it hard for this phenomenon to occur as regularly as they once did on older cars. Again, fuel fumes or leaking oil seals can sip into the flywheel and ignite. I only mentioned the asbestos ignition because it is a possibility under the right condition. Afterall, who could have imagined that particulate sugar matter can cause an explosion? If I had made this remark a few days before the explosion, no one would beleive me.
rn79870
Car: 2008 G35 & 2005 Vette C6 vert.
telcoman wrote:DaveGreg
I'm a little stuck on the law of increasing entropy as defined by the second law of thermodynamics as it relates to the expanding universe theory. I don't think that was covered too well.
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
I thought I would share this
http://www.asbestos.com/produc...s.php
It's an article on the use of asbestos for fire blankets.
Does that mean that the transmission bellhousing and crankshaft are capable of transferring more heat than a burning building?
I find that hard to believe.
smockers83
Car: 2006 G35 Coupe
I'm gonna fail because I don't even know what we're debating anymore, whether its how the flywheel/clutch heat up or why the clutch was slipping
But I can tell you this--gravity is a constant acceleration (on Earth its 9.8 m/s/s). If one were to be in a rocket traveling at 9.8 m/s/s they would feel the same as they would on Earth.
I feel like we're moving to hypotheticals now to back the arguments.
heat dam: a thin groove cut into the head of a piston between the top ring groove and the top of the piston. The heat, instead of passing through the aluminum of the piston to the ring, encounters the heat dam. This helps to minimize heat transfer.
Also a patent for a heat dam design in a metal halide lamp was filed March 25, 1997. Looking at other patents for heat dams, looks like it may just be an older term instead of a non-existent term in engineering.
And choosing sides is the point of making arguments in a debate. If no one chooses sides, what's the point of making arguments? Also its pure human nature to do so, whether one thinks its premature or not. Are you going to fault 2.5 millenniums (9-8th century BC to the 16th century) worth of mankind for going back to what they believe and "know" for not believing in the heliocentric model of the solar system (where we orbit the sun, not the sun orbiting us)? Imagine the debates that followed when people talked about the heliocentric system during those times...wow! Is that going to be on the quiz?
Maybe I'll just copy/paste part of this and send it to a professor in the automotive engineering department here at Michigan, ask him to comment on this.
Sentientbydesign
96 I30 - Sold
That idea (minus the Michigan part) has been buzzing around in my head for a couple of pages now.
Unfortunately, even with a PhD stating otherwise, Jacko would disagree and find a tangent to disprove the situation (despite the fact that it realistically does not exist).
W661335PF
Car: 2004 G35 sport sedan-- Mod money goes to 401K
I think everyone should disclose their "size" and leave it at that-- this has been the most testosterone driven debate I've seen in years!!!
rn79870
Good idea...::looks for yard stick::
W661335PF
Better yet.... can anyone lick their eyebrows????? Now that's something to write home about!
Jacko3
Smockers83:
Wisdom is when you take the middle road rather than mortgage your person to any side. We call this independent thinking.
Jacko3
Sentientbydesign:
Yes, in the field of engineering, many phenomenon can be explained using different techniques. So, it matters little who you take the information to verify them. I will find another technique to disprove it. Consequently, each explanation also has a mathematical technique to deal with the situation. All I have explained so far are just linear systems. In non-linear systems, the equations I presented are a lot more complex. I am sure as a scholar in mathematics, you would aware of this. Btw, don't fear too much about me being right.
And the information you presented about asbestos, is all about fibres. My discussion was about asbestos particles. There is a difference. You can't have fibres in a clutch system. And, a crank shaft does not produce more heat than a house. However, I have said before that the asbestos clutch conducts less heat than the flywheel. However, ths does not stop the asbestos particles from expanding.
I know it is hard to accept all this coming from Jacko3. Anyway, that is life. I may not know much about cars, but i do know much about mechanisms when I get a chance to discuss them.
BTW, I am a business major.
C-Kwik
Jacko3 wrote:My dear C-Kwik:
Where do I begin?
I apologize, I should have elaborated. A motor's expulsion of heat is quite complex. The point of convieving the motor as a solid block was to simplyify the discussion. We could go on and on about how heat leaves through the cooling system, exhaust system and through radiating and convecting heat out of it's many parts and into many mediums, but that would be largely irrelevant. Even given the fact that the crank itself can only transfer so much heat through it's relatively narrow cross sections.
Jacko3 wrote:2. When you drop of your car after driving for say, about 30 minutes, and you open up the hood, do you feel some heat or not, inspite of the very good cooling system you have in your car? And you really feel any metal component of the car does not feel that same heat? Please explain to us more about this anomalous explanation? Invariably, you are saying that the flywheel is somewhat insulated from the very same heat anyone can feel when they open the hood of a car that has recently been driven.
There are two things you appear to be ignoring. First of all, when an engine is running, the radiator fan will kick on as it needs to. And while the car moves, it inevitably gets a stream of air flowing through the radiator. Both of which essentially pumps hot air throughout the engine compartment. So, this combined with radiated heat, will combine to make parts inside the engine compartment warm or hot despite being in direct contact. But the temperature of this air is likely lower than the temperature of the water in the cooling system by a small percent.
When you shut down the motor, radiant heat will of course heat up parts on the engine compartment as it has been doing even while the car is running.
But what you fail to miss here is that even with radiant heat and heat passed through convection, the temperature of the flywheel can only get as high as the temperature of the sources of heat. Due to the thermal barriers that exist, this temperature will likely be lower, but for argument's sake, lets say that it is the same. Assuming the cooling system is doing it's job correctly, then you're talking about a flywheel temperature of about 195 to 220 degrees F. The effect on the flywheel and clutch from heat sourced from the engine, regardless of if it is through conduction, convection or radiation, is not going to be high enough to become a major source of slippage or breakdown of the chemical composition of the clutch's materials.
This is actually a good time to bring up some facts about asbestos. First, it is not flammable. Period (http://www.btinternet.com/~ibas/lka_prop.htm). It does not oxidize at high temperature. In fact, it decomposes at high temperature. The temperature may vary with the type of asbestos involved, but we are talking 1,000 plus degrees Celsius here. Since we've been using Farhenheit more, that equates to 1,832 degrees Farhenheit. Turbo manifolds, which tend to run very hot, typically reach about 1,400 degrees Farhenheit. Think about that.
Jacko3 wrote:3. Engine is made up of some aluminium, and fly wheel is made up of Iron. Both are metals and so both will get heated at any rate. Engine will give away heat faster than Flywheel and will absorb heat faster than flywheel. Thus, a flywheel is a sitting heat sink and duck. Btw, no one ever uses the term heating dam. We call it heat sink or heat dump in the world of engineering. A refrigerator compressor is a classic heat sink.
Once the flywheel reaches a certain temperature, (which will not be higher than the temperature of the source), it will reject heat. Think of it this way. If you heat up your oven to 500 degrees, and stick something in it, that something will not ever become a higher temperature than the air around it.
Jacko3 wrote:4. Primary source of heat to flywheel is by convection and secondarily by conduction. Thus my earlier focus on convection. Why? The surface area of the crankshaft in contact with the any surface area of the flywheel is very small. But the surface area of the flywheel in contact with the heated air from the engine wall is in totality of the area of the flywheel. So the crankshaft could not possibly heat up the flywheel as effectively as you have erroneously described. The main heat to the flywheel comes from the heat accumulated or developed on the outside walls of the engine that is being transmitted by convection or air to the walls of the flywheel and other parts of the car. When you open up the hood of your car after driving, the heat you experience is by convection. Your flywheel experiences that same heat. There is no insulation b/w the engine wall and the flywheel that is effective enough to reduce the heat. If you know of one, please tell me.
Lets just assume your are right about where the heat in a flywheel is generated from (aside from and frictional heat induced by clutch slip). As I said, since the temperature will be no higher than the temperature of the air around it, than in order to bring the clutch and flywheel temperature up even more is to cause it to become a source of heat by slipping the clutch. This, more than any other source has the potential to heat the flywheel and clutch up to a temperature where things start to go awry. But as I stated before, if you are driving correctly and everything is working properly, this should never happen. And if you do slip the clutch a bit, and generate some heat, it will occur at the contact surfaces. Then, it will start to spread into the surrounding materials. Some will go into the clutch disc (many organic disc manufacturers embed strands of metal into the disc to help pull heat away from the surface of the disc quicker). Some will go into the pressure plate's disc, and some will go to the flywheel. But since the flywheel has the greatest mass, the tendency will be that most of the heat will go there as the temperature increase from a given amount of energy will be small.
Jacko3 wrote:5. Better materials are absolute. What you are talking about is individual comfort. Yes, some people may prefer OEM clutches to ceramic based clutches which might chatter a little more. Certainly some people will be comfortable with some types of materials than others. A better material is simply one that can dissipate heat fast and absorb heat less. This charateristics is absolute. I really wouldn't like to go into the theories of heat absorption. There is no need for it.
How can it be absolute. Better, in that of itself is a term that describes an opinion. An opinion is largely or sometimes wholly based on personal choices. So better materials can't be absolute unless the word better is qualified. If you are looking for a clutch that has a higher coefficient of friction, then yes, there is a better material than the OE materials. If you want a clutch that lasts longer, there is a better material than OE and even metallic clutches. If you want a clutch that can hold a little better than stock without sacrificing comfort, yes, there is a better clutch for that too. It's all a matter of perspective.
Jacko3 wrote:6. Ceramics have been known to be great at this heat characteristics. They also double as insulators as well. Haven't you heard that ceramic breaks don't wear out as fast as the asbestos brakes? why do you think this is so? So you think, the after market guys are just deceiving the buyers of ceramic brakes? I just explained why, in my write up above. The reason they have ceramic materials is because it is a good insulator of heat because it does not absorb heat very quickly. And when it does, it dissipates the heat very fast. the same ceramic materials are used as heat shields in NASA's space crafts. Ceramics don't yield to expansion as quickly as asbestos do.
No material can be a good insulator and good conductor of heat at the same time. They are inversely proportional traits. Readup:
http://theory.uwinnipeg.ca/mod_tech/node75.html
What asbestos brakes? I doubt very many brakes contain any asbestos now or even for some time. Bear in mind that ceramic brakes tend to have a soft metal (such as copper embedded to provide an adequate level of heat transfer).
Jacko3 wrote:7. Thermal expansion naturally reduces the tendency of a material to maintain its lateral load when coupled with another material with a different coefficient of friction and atomic make up. Another simple reason for this is that particle sizes and arrangement, of both the flywheel cast iron and the asbestos, on the clutch, are different. Thus, heat will render the particles of the least packed atoms (clutch particles), more prone to disintegration than the particles of the most packed atoms (flywheel). The physics you describe only aids in speeding up that process. This issue is first and foremost a material science issue and not a physics issue. You can throw in all the lateral load you want, if the material is not stable under increasing levels of heat conduction, your laterally loaded material will fail. Every material is subject to the effects of heat and its properties. Load only speeds up the detiororation process, and it is the job of the engineers to find a material that will withstand the lateral load for a specific amount of time, as dictated by the manufacturer. Thus, material science tests are always crucial, and conducted, in any part of a machinery that will experience some type of heat absorption, and yet accept some load.
Lets assume this is true. Are you saying that engineers are using unstable components that will fail in our cars? Not likely. Any effect this might have would be minimal/negligible. Your last line in this paragraph indirectly asserts what I am saying here.
Jacko3 wrote:8. Engineers are bound moreso than any other set of factors, by safety and cost. Any engineering feat that fails to live up to safety and cost, is almost always shelved, regardless of how good the technology might be. For example, it has taken forever for run flat tires to make it to main stream auto world. Well, the safety issues of run flats are pretty good an obvious, but the costs still remain prohibitive. So, run flats are only found in cars associated with thew wealthy who have an income inelasticities to any good or product they demand. Asbestos in most clutch systems has been shown to be relatively safe and inexpensive, ceteris paribus. So, why mess with it if it ain't broke? Asbestos is so cheap and so convenient that it took law suits to remove them from paint and roofing materials in homes in the US. Yet, they are still popular outside the US.
Engineers are bound by the requirements put on them by the company they work for. Safety and cost are most certainly something most companies will put at least some attention on and in most cases, a lot of attention on. But a product still has to reasonably perform to be successful. Run flat tires are typically only used by cars that don't have room for a spare. Many of these are high end sports cars that actually perform quite well. The Corvettes and even the upcoming GT-R are examples...
Jacko3 wrote:9. You will need a thermal boundary once the clutch smell occurs, only for a short duration dissipation of heat built up between the clutch and the flywheel. That heat build up is not from the interaction of the flywheel and clutch. Rather, it is from the heat absorbed by both the flywheel and the clutch that slowly degenerates the clutch, since the clutch itself has less packed atoms than the flywheel.
How can a level of heat that would cause one to approach a point where the clutch smells occur from any source other than the frictional interaction of the clutch system? Heat always transfers from hot to cold. When you put two objects with different temperatures together, the hot one begins to cool as it transfers heat to the cold object. The cold object begins to go up in temperature. Eventually, both objects will equalize in temperature and then heat transfer stops. Even if one of the objects continually emits heat at a certain temperature, then the colder object will increase in themperature until it becomes the same temperature. And again, the heat transfer stops. This means that unless there is a hotter temperature source added to the equation, the temperature of either object can not increase. Ther must be another source of heat energy available to increase the temperature of the clutch and flywheel and pressure plate higher than that of the engine. It's a relatively simple concept. You can argue tooth and nail here, but you can't bend the laws of physics.
Jacko3 wrote:10. I am fully aware of driving hard and abusig a car.
If you say so...
C-Kwik
Jacko3 wrote:Sentientbydesign:
Problem is your arguments for your "linear" systems are flawed. Greatly. The most complex science doesn't defy the most basic laws of science. Unless of course your name is God...
Jacko3
C-Kwik:
You said, "Unless of course your name is God..." So far on this forum, I would dare to say that many have tacitly ascribed the attribute you mention to you. I don't know why they do it!
Jacko3
C-Kwik:
I am glad I have forced you to go searching for relevant information, albeit still basic. I am satisfied with the explanation I have provided in the past based on sound heat transfer principles. I urge you to continue to educate yourself on more advanced topics. I hope I have enabled your learning experience, and elevated your consciousness on issues related to cars, beyond the everyday considerations you have provided to your subjects.
I hope your subjects have a different view in the future about others who post information on this forum--hopefully for the better--but I doubt it judging from the comments I have read so far. Again, i would like to have the honor of resting my case, as I have nothing else to prove anymore. Humility is a character of nobles. Endless arguments tend to be futile. Someone has to be the big person around this forum. Will it be you--I doubt it or will it be me?
Btw, I hope I have not convinced any of your subjects to switch sides. That was not my aim or intention at any point. You can keep your subjects. I doubt they will be happy to be leaderless on this forum. As you will agree, your subjects have learnt a great deal, especially in the areas of heat transfer and fluid mechanics, which had been denied them, for many moons and years. If I had not raised it, they probably would never have known such information existed, or at least to the extent I presented them. So, I am proud of my little achievements. I showed them that one day, the King can also be dethroned. But, as I intend not to take your crown, since I prefer to act as a noble and a free thinker, I shall leave you intact with your crown and dignity on this matter. I shall not be the one to say that the emperor has no clothes. I shall let your subjects determine that. it won't do anyone any good to know that their champion is on the verge of being beheaded. I don't want to take hope away from the people. People need hope from their leaders, even if that hope is false and untrue. I have no subjects and I have no kingdom, so I do not have the burden of maintaining my crown, my dignity, and my person, as a King would. I will always leave a king for its people/subjects.
smockers83
Car: 2006 G35 Coupe
Jacko3 wrote:So, run flats are only found in cars associated with thew wealthy who have an income inelasticities to any good or product they demand.
If you're a business major, you need to go back to Econ 101 chief and stop studying mechanics. First, to be income inelastic, the good in question has to be a normal (0<E<1) or inferior good (E<0). For a good to be a luxury good (E>1), such as run flats as a stated luxury good, it has to be income elastic. Also, income elasticities deal with quantity demanded as income changes as the general formula is E = %d in Qd/%d in I (d=delta, Qd=quantity demanded). It doesn't determine what goods are demanded, that's based on preferences, utility functions, indifference curves, and budget constraints (now we're moving into Econ 401/402 and consumer theory) as elasticities are purely ex post computations, not what determines demand and consumption. What this formula says is that if income rises a little, demand for elastic goods will rise a lot, such as precious metals. If a good is inelastic, if income falls or rises, demand doesn't change much, such as cigarettes. I think what you're getting at is substitution, purchasing power or something dealing with a demand function, but not elasticity unless you are trying to say luxury goods for one individual are normal goods for the wealthy.
Also, there are no real apparent safety issues for run flats, in fact that's why people use them, for convenience and safety. Now there are performance issues for sure as they last about 1/4 as long as conventional tires and reduce gas mileage, which is where the backlash is forming for the market. The reason run flats haven't taken off is because companies won't supply the market demand which keeps the price high, pricing individuals out of the market who may otherwise want to participate, and it is difficult and expensive to service them (very few trained shops), and coupled with the performance, dollar for dollar they aren't worth the investment. At least that's my independent thinking and speculation as I don't have any specific market data. But with the performance issues, who would want to buy such a tire? I'm not sure where you are pulling your information from.
Now, going back to my freshman year of high school in physical science, I have to say C-Kwik is right about the flywheel--it can only get as hot as the air around it, any additional heat has to come from another source like the clutch slipping. The clutch should be able to tolerate this heat from the flywheel, as that is the operating temperature, with quite a bit (or maybe just a little, I have no idea) of leeway. If I'm going in the right direction with this argument, if a clutch burned because of heat it absorbed from the engine and flywheel, it was a poorly designed clutch and if that happens to all clutches, I feel that we wouldn't have manual transmissions now. Yes? If that's completely wrong, completely ignore it.
Modified by smockers83 at 10:11 AM 2/14/2008
Modified by smockers83 at 10:13 AM 2/14/2008
adren77
Car: 2004 G35 Laser Red Coupe 6MT
Jacko3 wrote:C-Kwik:
I find it amusing that you can express yourself so well when it comes to slamming someone, but when you have to explain a technical concept you sound like a complete retard.
Maybe you can impress a few people on this forum because they are not engineers, but for those of us who are familiar with concepts you claim to have mastered, you sound like an arrogant prick. You have no idea wtf you are talking about, and I am not going to waste my time explaining it to you. Just stfu already. I don't see why anyone is still arguing with you.
Jacko3
Smockers83:
You get my drift, as you said, "....but not elasticity unless you are trying to say luxury goods for one individual are normal goods for the wealthy."
Btw, I nevr said, as you suggested, "there are no real apparent safety issues for run flats" I don't know where you got that from!
I expect no less from you and other subjects as you said, "I have to say C-Kwik is right about the flywheel--it can only get as hot as the air around it,"
Jacko3
adren77:
You said, "you sound like an arrogant prick. You have no idea wtf you are talking about, and I am not going to waste my time explaining it to you. Just stfu already. I don't see why anyone is still arguing with you."
I expected no less! When a person is down on ideas, they will resort to languages and mannerisms of thuggery.
Jacko3
My dear friend adren77:
Take solace in knowing that I make many people mad everyday. So, you won't be the first and you won't be the last. I have been called a prick so many times. I have been called arrogant so many times. I am fully conscious of these commenst. But as always, as a free thinker, my job is to bring the obvious to the surface. And when I do, I get all kinds of people mad at me. So, I am not surpised at the effects I have had on you, to the extent that you will use thug language such as stfu, prick, arrogant, etc. By using those street words the way you have done, you will find that it allows you to deal with inner anger that has always been there, deep inside of you, for a long time. So, you should be thanking me for helping you stay in touch with the inner anger you have habored for years. What do you think?
Jacko3
Smockers83:
In addition, I beleive someone had offered us a red and blue pill. Well, I took the red pill and I showed you how deep the rabbit hole is. It would appear to me that you have chosen the blue pill, and so you go back to your room and forget any discussions ever took place. I can't determine which pill any of the subjects will take. I can only determine which pill i shall take. I chose to take the red pill. remember, all I offer you is the truth.
W661335PF
Awhile back I had asked that maybe this thread be locked given the personalities engaged in the debate. I think it's probably time for a moderator to step in. None of this can be of use to this forum.
W661335PF
Jacko3
Adren77:
I wasn't slamming anyone, as you haev suggested. I was using my literary license to express the culture, ethos, values, semantics, etc, which I have observed so far on this forum.
As I have said before, I make a lot of people mad everyday simply becasue I am used to being the one to point to the Elephant in the room. I am the one who is likely to say that the emperor has no clothes. I am the one who will refuse to jump off a cliff with the rest of the Lemmins out there. I am not sheep. I maybe a cow or a goat or both---i really don't know. But what I do know is that cows and goats don't need a shepherd. Independent thinking is a very powerful tool and attribute, which I will not trade for anything else in this world.
G_whizz
Car: 2010 G37 Coupe Sport
Welll Joe and I agree... it's time for this to be locked.
DO NOT START A NEW THREAD TO CONTINUE THE BICKERING!
nchopp
Jacko3 wrote:My dear friend adren77:
I think you should consider the possibility that because so many people consider you to be a prick or arrogant, they may be right. That's what I think.
Edit: Oops, in after the lock. Sorry.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
pwned....
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
I post a warning, stating CLEARLY that anyone who made personal attacks, or acted like a douche would get banned. I thought I made this message crystal clear. I guess I didn't. I will now waste more of my time, seeing who didn't heed my warning. To those who didn't listen, we'll see you in a week.
If you start another thread that even remotely touches this subject, like two members did, last time this was locked, you will get a weeks vacation. Let the subject die for a few weeks.
