Jacko3 wrote:However, the heat from the engine heats up both materials. Thus, when both materials are clamped together, the flywheel will accumulate slightly more heat than the clutch because the thermal conductivity of the flywheel is usually higher than that of the clutch. This is why your clutch is made of a material that naturally does not conduct as much heat as the flywheel, while some level of grip is sacrificed, thus leading to potentially to slipping. There are better materials than the materials used in making your clutch. But the engineers have to consider how much heat that material can absorb and dissipate before the clutch starts to fail. This is why your clutch is made of an asbstos type material that is less prone ot heat absorption and quick to heat dissipation. Ceramic materials are even better, but they are expensive. Ceramic means clay. Clay is a good conductor and dissipator of heat.
Heat that originates in the engine is going to have little significant effect on the flywheel or clutch. Lets assume for a moment that the engine is a big block of metal. It's temperature will remain within a relatively small range as it is regulated by the cooling system. As a result, the temperature of the flywheel can only get as high as the temperature of the engine.
It gets even better. The primary source of heat transfer to the flywheel would be through conduction which would occur at the point at which the flywheel is connected to the end of the crankshaft. This point is maybe 4 inches in diameter at most. This is effectively a heat dam. It reduces the amount of heat transfer that can occur. Imagine you are freezing cold and find a very warm wall that you can press against to absorb some its heat. If you press only the tip of your finger against it, you'll probably never warm up. But if you press your entire body against it, you'll probably be warm in no time. Ultimately, between these two factors alone, the flywheel should be cooler than the engine, and by mechanical standards, is already fairly cool.
Better materials for a clutch is relative to what one considers to be better. Are there materials that have higher coefficients of friction and better ability to handle heat and abuse? Absolutely. Are there drawbacks? Most certainly. Higher coeffecients of friction can be one cause of clutch chatter. While you might be okay with it, most average consumers will not. In severe cases (which I have experienced), it is down right uncomfortable. And better heat load capacity may come in the form of more mass (perhaps copper ceramic pucks). Keep in mind that extra weight on the clutch disc can affect the operation of your transmission's syncros as it adds additional inertial loads that the syncros must overcome.
Last I checked, ceramics were insulators. They are poor conductors of heat. Try holding a tin cup filled with a hot cup of coffee and a ceramic cup of hot coffee. While eventually, the temperatures will be the same at the surface, you'll notice that with the metal cup, it will feel hotter. when you pick up either cup, your hands start to absorb heat from it. The surface of the cup where you are holding it will drop in temperature, so the heat from the coffee will begin transferring to the surface again. In the metal cup, this will happen pretty quickly. With the ceramic cup, it will occur at a slower rate so the surface temperature of the ceramic cup will be lower.
Jacko3 wrote:In the process of the clutch and flywheel spinning, the linear expansivity of the flywheel will be greater than that of the clutch, thus increasing its surface area for more heat accumulation, while the surface area of your clutch isn't as affected because of the relatively lower thermal conductivity of the clutch material. Your flywheel does expand as a result of heat absorption, but your clutch does so only in smaller amounts.
When the flywheel and the clutch are clamped together, on either side of the flywheel and the clutch system walls, you have a thin wall of air on both sides. That thin wall of air is called a thermal boundary layer.
The rate of heat transfer per unit area, called the heat flux on the side of the flywheel is usually slower and less than the heat flux on the side of the clutch. And according to Fourier's law, which is dq/da = -k dt/dn, heat will move from a region of a hotter surface to a region of a colder surface. Assume the surface of the flywheel to be isothermal regardless of the heat it is absorbing from the engine, for ease of understanding.
Thus, the heat flux on the side of the clutch system, as a result of the heat transfer from the flywheel to the clutch system, based on Fouriers law, increases the temperature gradient of the air at the thermal boundaries on either side of the clutch and the flywheel.
This heat gradient in addition to the heat continuously generated by the engine, causes expansion of the surface area of the flywheel and the clutch, thus reducing grip and clutch reliability---this is what partly leads to slipping of the clutch. Slipping is accelerated under these conditions if the clutch is not fully depressed or fully engaged. Clutches don't slip by themselves, they do so slip as a result of improper engagement or disengagement in addition to the effects of temperature on the flywheel and the clutch material itself. During this phenomenon, the porous material of your clutch will tend to disintegrate, which is what causes the burnt clutch smell. Slippage may not have occured at that time. However, this process is a precursor to slippage.
In order for any clutch to slip, the lateral load across the friction surfaces would have to overcome the pressure the pressure plate exerts on clutch disc coupled with the coefficient of friction of the materials. Thermal expansion is not what you need to look at here. Perhaps it may have an effect on the coefficient of friction, which it might (brake pads coefficient of friction vary with temperature), but ultimately, the coefficient of friction and pressure plate clamping force determines the load at which the clutch would slip.
I'm not quite sure if you are referring to the thermal expansion as a phenomenom, or clutch slip as the phenomenom. In any case, while thermal expansion will occur, it's going to be a relatively small amount. Both materials will expand to some extent as well (if we assume both are at the same temperature), so regardless of which one expands more, the actual difference in size change between them will still be smaller than the distance the material with the higher expansion rate expands to.
But then how exactly would this accelerate clutch slippage. The pressure plate still exerts the same pressure on the disc. The load from the engine is not changed. The only thing left to change then is the coefficient of friction. My thought is that this would perhaps go up slightly with temperature, but even if we entertained the idea that it went down, wouldn't you think that the engineers would not have thought about this already? Since most cars spends most of it's mileage in a warmed up state, do you not think that engineers would make sure that the materiels used would provide a reasonably adequate amount of friction at the temperatures it will operate at while even leaving a bit of headroom?
Jacko3 wrote:Thus, in order to reduce slippage or the potential for slippage, a third thermal boundary has to be introduced. That thermal boundary is in between the clutch system and the flywheel when they are disengaged. It is a small area for the air. Air will fill up any area if a vacum does not exist. However, what is important is that the small area contributes another area for further heat transfer away from either the cluth material or flywheel, from a region of cold to a region of warmth, according to Fouriers law.
During this period, the air inside and close to the walls of the bell housing which covers the flywheel and the clutch system, are touching the bell housing metal, and consequently loosing heat by conduction to the bell housing, while air on the outside and close to the bell housing, is absorbing the heat being conducted by the bell housing. All this is happening as the engine continues to generate more heat.
Thus, the air in side and close to the bell housing gets cooler and returns to the clutch system and flywheel by convection to absorb more heat to be transferred outwards through the bell housing. This is why the bell housing is made of a material which has a higher thermal conductivity than the cast iron used in making many flywheels. This material has to be able to dissipate heat very fast. Cast iron is also cheaper to make.
What you describe is a very general process about how heat naturally dissapates from the clutch system. And it's true. But the difference here is that you are assuming that the heat that exists in the flywheel once everything has warmed up is actually enough to cause the clutch to burn. If cooling the clutch system were actually a big enough concern to engineers, then a more effective method than the one you describe would be to allow air from outside the transmission into the bell housing. It would reduce any thermal loading on the transmission and bellhousing casing and be much more effective as air outside the case would be cooler. And engineers have done very little to allow outside air in. While it's certainly not air tight, there are few gaps that air can flow in and out of in the bellhousing of a transmission.
Jacko3 wrote:The more a thermal boundary is introduced close to the gripping surfaces of the flywheel and clutch system, the better heat can be transferred from the clutch, and the less damage you do to your clutch, assuming the clutch is operated porperly.
You don't need a thermal boundaray if your clutch isn't above it's intended operating temperature in the first place.
Jacko3 wrote:The clutch is subject to heat impact. And because a clutch is made up of a porous material, the dust form the clutch in an enclosed chamber can actually ignite on its own. When you have an enclosed space with powdery substances, explosions are common, especially if you don't have an efffective ventilator. This is what led to the recent explosion of a sugar factory in Savannah Georgia. Thus, among one of many reasons why clutches can ignite on their own, without explanation and forewarning. Much of the heat from a clutch does not come from its spining with the flywheel. Much of its heat comes from the engine. And to reduce this heat, you will have to increase the surface area for cooler air to come in contact with the clutch and flywheel, no matter how small the area. Thus, the reason to disenage the clutch from the flywheel for a few seconds.
While I doubt there is much material in a clutch disc that can actually catch fire, even if it could, it would probably be at extreme temperatures. One which an engine's heat ouside of the combustion chambers would ever actually reach.
Jacko3 wrote:When a clutch is clamped to a flywheel you effectively have only two surface (outer surfaces) areas for heat to be effectively dissipated by the air. When you disengage the clutch from the flywheel, you increase the surface area for heat dissipation to four (two inner surfaces and two outer surfaces), and your Fouriers law holds in this case because, the heated surfaces of the clutch and flywheel automatically is absorbed by the air in between the two surfaces, thus reducing the possibility of slip from heated surfaces.
My argument was and still is that any cooling effects that any air between and even flowing between the friction surfaces provides will be slower than that of conduction into the flywheel and pressure plate masses. Both will provide a heat sink effect that allows for more immediate temperature reductions at the frictiion surfaces, but naturally they will radiate and convect heat to eventually shed this heat. In order for convection between the friction surfaces to be more effective than conduction is if the temperature of the flywheel and pressure plates are the same as the disc. This is because if they are at the same temperature, there would essentially be no conduction. But to reach such a point where this would be the case and the clutch disc material were burning would mean that a lot more heat than the engine could provide through conduction, convection or radiation could possiblty provide. Meaning the only other soource for the amount of heat necessary for this condition would be by causing an unreasonable amount of clutch slippage.
Jacko3 wrote:As you will recall, I drive very hard, so my car will generate more heat than those who drive normally. Thus, the burnt clutch smell I had earlier noted. Burnt clutch smell does not mean slippage is occuring. It means that the condition for slippage is ripe, that is if you ride your clutch or engage or disengage your clutch improperly.
Driving hard and abusing a car are not the same thing. There is no condition that your car could probably see as harsh as a road race rack. If you drive like you do on a track, it's likely that you'll be way behind every other driver on the course and/or you'll be replacing the clutch the next day. Driving fast is about being smooth and deliberate. Harsh movements and transitions only result in wasted movement and energy.
Jacko3 wrote:It should also be noted that the temperature differences we are talking about maybe as small as 1 degree celsius or less. However, that is enough to make a difference in the linear expansivity of the clutch since it has a lower thermal conductivity than the flywheel.
Thermal expansion occurs with even the slightest changes in temperature. But a clutch disc doesn't burn because of a 1 degree Celsius change in temperature.
