RB series replacement part numbers, etc
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Marmo. wrote: Can anyone confirm if KA24DE flywheel is the same as RB20DET?
No. They are not.
*edit* Or maybe they are apparently..
Modified by l0nestar at 9:31 AM 4/10/2008
nosanhere
300Plus wrote:
If someone else can confirm this, or just post pics this would be an awesome find!
So far from the ones I have tried they don't even come close. I have a strong feeling no subaru starter will work on the rbs. I did my testing on an rb25det btw. Waste of money but hey someone had to do it
mello88
Car: s13
For RB26 or R34 ps pump on a r32/r33 RB20 or RB25, use a 36.5" 3 rib belt. The RB26 and R34 motors use a 4 rib belt while the R32 and R33 crank pulley uses a shorter 3 rib belt. The 36.5 fits nicely, it is used on a 90-96 Z32 N/A power steering pump! K030365 is a gates PN.
I slotted my PS tensioner bracket, but in retrospect that wasn't even needed!
Hope nobody else has to deal with this pump/motor mismatch, but if they do here's your answer....
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
well ive got me some great news...for those people who are looking for a IAC valve for the RB25DET look no more...as it turns out its the exact same part as what you can find in a 91-94 sentra with a 1.6L its even available aftermarket. here is a AC Delco part number for those who dont want to pay dealer prices...the part number is AC85 and ive seen them on Ebay for as low as 80.00 and if you want a good used one you can find them for as low as 10.00 ..if you ask me this is a damn nice find...both Carl and I deserve a cookie on this one...ill take a chocolate chip please....lmao
Shocker
Car: 89 240sxHB rb26/30
S14-NEO wrote:well ive got me some great news...for those people who are looking for a IAC valve for the RB25DET look no more...as it turns out its the exact same part as what you can find in a 91-94 sentra with a 1.6L its even available aftermarket. here is a AC Delco part number for those who dont want to pay dealer prices...the part number is AC85 and ive seen them on Ebay for as low as 80.00 and if you want a good used one you can find them for as low as 10.00 ..if you ask me this is a damn nice find...both Carl and I deserve a cookie on this one...ill take a chocolate chip please....lmao
good find... if your running a stock ECU or piggy back. :P
S14-NEO
well EXCUSE MEEEEEE big baller..lol but yeah its also good to have if your rocking a Power FC too..
Shocker
S14-NEO wrote:well EXCUSE MEEEEEE big baller..lol but yeah its also good to have if your rocking a Power FC too..
Ahh yeah forgot about that one as well... and technically your bigger since your motor just made the power mine was supposed to 8 months ago!
S14-NEO
oh yeah and dont forget ive got a boat load more boost to throw at it my man...lol
craz4240
Car: 1995 240sx w/rb20det
I'm in desperate need of the nissan part number for the rb20det engine gasket set...I have to order one locally.
Paradox
Car: Cars, computers...
I have searched and cannot find good information on the rear main seal for RB20 engine.
Does anyone have a US equivilant part #? I heard the KA24DE rear main seal is a replacement, is this true? (Just like for clutch, the Z32 N/A is supposed to be a direct replacement...)
Also, has anyone modified the S13 KA24DE power steering pump to fit a RB20 (in a S13)? I got a RB20 without PS bracket/pump, and want to find a solution. This is going into a S13 convertible.
Thank you for your help!
s13point5
Car: 89 240sx
Napa starter part number 2444514 bolts up to the RB25. i have yet to start my car but was excited to see it bolt up perfectly. its for some datsun made from 1965-1969
Shocker
s13point5 wrote:Napa starter part number 2444514 bolts up to the RB25. i have yet to start my car but was excited to see it bolt up perfectly. its for some datsun made from 1965-1969
nice have you tried to turn her over yet? If not update if it works flawless please lol.
s13point5
Car: 89 240sx
no i havent. i still have a few small things i got to get done before i can start here. im still trying to figure out if there is any special precautions i need to take in to account when extending my maf wires or is it as simple as just soldering in the extra length
gawdzilla
Car: none
it works. running it myself. zerothread?id=313291
Shocker
awesome to hear! whats it run?
Sil240
Car: Nissan S13 "The One Cam Wonder"
Maybe a repostBosch O2 sensor13276
I believe its from a 84 CA18ET 200sx.
Paradox
Paradox wrote:I have searched and cannot find good information on the rear main seal for RB20 engine.
Does anyone have the above information on Power steering? What about rear main seal? I ordered a Z32 NA clutch kit, I hope that works.
l2u4k0assx
Car: s13 240sx
does anyone know where or how to get a rb20det starter????
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
I think I need an RB20DET pilot bearing, the one that guides the input shaft...
l0nestar
2004 Toyota Altezza
Acecool wrote:I think I need an RB20DET pilot bearing, the one that guides the input shaft...
Z32 N/A? I know that works for 25 trans.
What does the RB20 trans cross-ref with? I don't have FAST installed here.
Acecool
I just installed Fast :-)
I see part number 32272-36910 for pilot bearing which is for 2wd+hi.2wd (CA18I+RB20E+RB20DE+RB25DE).MT.F5 +GTST.M.MT.F5
Which should also be for the RB20DET 5 speed manual transmission R32 skyline with hicas, 2 wheel drive...
I dont have a file for cross referencing... which one is used for that?
l0nestar
2004 Toyota Altezza
Man, I'm shooting in the dark here, but could you possibly use one from an S12 (84-86 200sx USDM) with CA18ET Turbo? I don't know anything about RB20 transmissions Carl H might...
Could you pull it out and compare it to a Z32 NA? or KA? Is it even out of the chassis?
And apparently all pilot bearings for Nissan are the same.. who knew!
jdmser
Car: duh
RB20 pilot bushing is the same as the na z32. I just used the one that came with my clutch kit.
got2b240
Car: 91' RPS13 = GT28R, 525cc, Z32 Mafs & SAFC, Blitz EXST & FMIC, Silvia VLSD
In Search of a new Throttle Position Sensor:
We have been all over on searching many forums and search engines for this answer. Still we are unable to locate the correct part number for the TPS (throttle position sensor) of my friend's Nissan Skyline R33 GTS25T Series 1 (RB25DET).
I work for an auto parts company here in New York, USA. The easiest answer would be either:
- an aftermarket Part Number- the original equipment manufacturer Part Number- a vehicle offered in the United States with the same TPS
There is no such thing as giving up even after you have tried google.com.au and yahoo.com.au and translating Japanese websites!
Please help a fellow owner out!
imotion s14
Car: 1997 240SX
common knowledge that S1 and Q45 TPS are interchangeable.. so one would reason to follow that a Q45 TPS would work.
got2b240
Thank you for the info...
What year Q45 would that be?
imotion s14
Car: 1997 240SX
1990-96 iirc.
got2b240
Thank you imotion s14
I was able to get this in yesterday and now no check engine light!
K++++
evildave29
Car: 91 nissan 240sx
i need the oil filter adapter so i can put a filter on
dohclover
Car: 1992 240sx screw you mother nature!!!!! rb20 89 coupe ^_^
anyone know the part number for a rb20det knock sensor or detination sensor?
