RB series replacement part numbers, etc
Neejay
Anyone know the part number for the 3 black hard plastic spacers that the fuel rail bolts to?
eh?
Neejay wrote:Anyone know the part number for the 3 black hard plastic spacers that the fuel rail bolts to?
Just for youhttp://www.rbforums.org/INJ.html
Neejay
17522-10V00 Thanks a lot man!
mattleegee
Car: s13+19 corolla
eh? wrote:
You can go to a hardware store and pick up most of the missing bolts and nuts, but if you want OEM part numbers check out this:http://www.rbforums.org/mounts.htmlNot done yet but getting there..
thats the problem i dont know the sizes because i dont have any, or maybe i do but cannot find them
sleepyeyed240
Car: 1993 rb20 vert, 1989 hatch
dont know if someone asked already but what is the part number for the bolts that hold the starter in on rb20?
kumasan616
More research found the following matches to the RB20DET:
NapaAAC valve 1993 nissan d21 pickup w/ V6: CRB 219435Air Regulator (not sure vehicle): CRB 219408
Also, the 300ZX TPS will NOT work, it rotates backwards to the RB20... use the 1993 Infiniti Q45 one instead
WHYTEBO1
Car: 93 240sx
where can i find rb26 injector seals
zerodameaon
Car: 1990 S13 Black Hatch with a currently NR RB25DET
1993 Red Vert
jrb92se wrote:probly already been covered but the sparkplugs for the 92 300zx turbo work for thes2 rb25det i cross reffed with napa from autolite to ngk the autolite plugs part# is 3924-11 the ngk iridium part# is bkr5eix-11 stock # 5464
rb25det transmission tail shaft seal oem nissan part #32136-01g10napa cross ref part# 16511Modified by jrb92se at 1:05 PM 10/31/2006
Modified by jrb92se at 4:39 PM 11/3/2006
Modified by jrb92se at 4:42 PM 11/3/2006
Seal #16511 will not fit the RB25det. its to small on the OD. this is from my own observations.
I want to say i was wrong. but i did have to modify this seal. had to take off about .5mm of material all the way around with a grider to get it to fit right.
Modified by zerodameaon at 9:42 PM 2/14/2009
mattleegee
Car: s13+19 corolla
Anyone know where to find heater hoses?I can only find them on eBay for $60 shipped and its for a sr20 swap, mine are a few inches short..... any help/ideas?(rb25det in s13)
(just got the harness all installed, picking up custom driveshaft tommarow, getting close!! time to get all the hoses complete and finish welding the no leak intercooler pipeing)
mattleegee
Car: s13+19 corolla
^well i found some at a local shop that would work....
So part numbers out of the rbforum directory, would a nissan dealership be able to get those, i called on one part and they had no idea what i was talking aboutrb25det11826-a PCV U hose11826-b PCV S hose11510BA R33 nuts
Any help on how to order these?
eh?
mattleegee wrote:^well i found some at a local shop that would work....
Those are the Crankcase ventilation hoses (PCV), not the heater hoses. I think I found them and I'll have an image up tomorrow.
mattleegee
Car: s13+19 corolla
Yes i know they are, and i have seen the diagrams but dont have full part numbers, if you re-read i was trying to find heater hoses a few weeks ago now im looking for PCV
thank you
eh?
thank you
Okay was a bit confusing, sorry. To get the full part number for any part, put your mouse pointer over the part code.A bit of a "how to" here: http://www.rbforums.org/how.htmlI know some browsers/settings may not work.The 11826+A is a part code, though you should be able to tell a nissan dealership parts person that code and they should be able to pull it up in fast.
kumasan616
RB20DET Rear main seal... same as a 300ZX?
mattleegee
Car: s13+19 corolla
Thank you! that is a 10digit part number now! haha
kumasan616
I need an RB20DET transmission mount, but not sure what it matches up to in the U.S. I have the PN for it (11320-41L03)... anyone replace theirs? What part did you use, KA? VG?
EDIT: the rubber piece is a match to the KA24DE woot
Modified by kumasan616 at 10:48 PM 3/13/2009
tgxlayzie
Car: 89 nissan 240 sx
mine also works fine no noises a bit bigger but works nontheless. thanx gawdzilla
tonyss13
rb25det flywheel and clutch bolts
need to find out where i can get them and any info on them ,cross ref or anything please
tonyss13
z flywheels worked the clutch bolts no good
NASTY
I have been searching for days and have gotten no definitive answers. I have an RB25 in my S14. Took the speed sensor out to test why the speedo wasn't working and found a mangled pinion gear on the end. Ordered a new one for an N\A 300z as that is supposed to be the interchangeable part and the gear is much larger. Anyone know what is the actual replacement or do I need both the sensor and the gear?
trynam4size
Car: 240sx
IAC sensor: Can use a 93' Sentra IAC
jetdriver
Car: 1998 S14 RB25DET
NASTY wrote:I have been searching for days and have gotten no definitive answers. I have an RB25 in my S14. Took the speed sensor out to test why the speedo wasn't working and found a mangled pinion gear on the end. Ordered a new one for an N\A 300z as that is supposed to be the interchangeable part and the gear is much larger. Anyone know what is the actual replacement or do I need both the sensor and the gear?
from RBforums.org/tranny3.html32743-30P20
http://www.courtesyparts.com/p....html
Lozer
Car: vroom vroom hissssss *POP "awww s***"
300zx and any vg30 maxima TPS works with some minor internal modification.
Drill out the rivits. Cut off the lower tang on the track (or you wont get maximum travel) now get a drill or a dremel and chew out a little of the plastic on the top side of the round track (make it mach your dead one)
I'm running one right now and it was 10 bucks at pick and pull. grab the cable connector too.
Justin Duncklee
Anyone know what to use for the little black rubber peices that the injectors sit on on a greddy manifold for the RB25. Mine keep blowing out.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Justin Duncklee wrote:Anyone know what to use for the little black rubber pieces that the injectors sit on on a greddy manifold for the RB25. Mine keep blowing out.
The injector isolator? I used the ones from my stock manifold. Oddly enough, it's not listed on RBForums.. Nothing related to fuel or injectors are.
eh?
l0nestar
2004 Toyota Altezza
Am I completely blind, or did you just add that?? :paranoid:
eh?
It's not listed yet but I posted the link a few posts up. If I could ever get my hard drives to stop failing I'll try to update the parts links...
SuicidnS13
Car: SC300 2jz, 93 Vert (RB), AcuraTL
So guys will the KA24E lower radiator hose. My ka24de does not? Its a hair to small. I also do not have the original piece to use an adaptor with.
Also SR Downpipes do not bolt up. I found this answer on a few threads, and no they do not bolt up. Shoots the downpipe towards the passenger side-
Justin Duncklee
are they off any other car here? part #?
