RB series replacement part numbers, etc
Joe
kevsster wrote:Q45 coils 1&2 work for the RB25det as well as the RB20. Part # 22433 - 60U02 is a valid Infiniti number, Nissan dealers couldnt find it but Infiniti had it.
important to note that it will only work on the series 1 rb25's.
NOT series 2.
Spazz
Rb25det series 1Alternator rebuild -Power regulator, out of the transpo catalogue;
Mitsubishi # IM 830 -14.4volts
Modified by Spazz at 2:26 PM 12/16/2005
Shocker
Car: 89 240sxHB rb26/30
Spazz wrote:Rb25detAlternator rebuild -Power regulator, out of the transpo catalogue;
spazz if that works.. thats huge, have you tried and done it?
Spazz
Yes i had my alternator bench tested. The guy i dealt with couldnt match the part number up. so he went thru the catalogue and looked for a mitsubishi regulator that not only visually matched up, but had identically the same specs. the regulator came out of 2nd gen ford probes and mazda mx'6s, which are 2.5L's?
http://www.transpo.de/cgi-win/product.exe?IM830
RB20DETURBO
Car: 240sx
This is my first post Woo Hoo!
In case you guys need to replace your clutch pivot ball you can use the 3rd Generation Nissan Maxima OEM Nissan P/N 30537-03E00
Edit: I made the mistake of using the N/A 300zx and I couldn't get the slave M/C to bolt back up.
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
13070-42L00 rb series timing belt tensioner. Same part number as VG30E (84-89 300zx)
RB20DETURBO
Car: 240sx
The Nissan Fast program is perfect for finding interchangeable parts! That's what I'm using
http://forums.skylinesdownunde...04218
These are the files that you need for the NISSAN FAST program!
Follow the directions step by step!
OKRB20DET
Car: 1990 S13 coupe
anyone know the part # for rb20 motor mounts?
and dont tell me 2 buy a mount kit..cuz im not
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
I found out that the 91-94 Z32 speed sensor WILL work with an RB25DET transmission.
Modified by Kansei240sx at 2:50 PM 1/26/2006
MarcBergeon
Car: Formula D ProAm spec RB25 S13 hatch drift sled
so who can make a nice and neat long list of part numbers, parts that work and dont, crossreference ect... im a lil lost, haha
edit: for RB25DET that is
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Vkoslak I will confirm that the tensioner is the same as that found on the 84-89 300ZX as I compared it to the RB25DET tensioner at O'Reilly Auto parts and it had the same part number stamped into the rubber and had "Made In Japan" stamped on it as well. Can anybody cross-reference an idler part number that would match a USDM motor part?
Kansei240sx
Shouldnt this topic be stickied?
Sil240
Car: Nissan S13 "The One Cam Wonder"
Probably a repost butRB20DET Oil pump- 1501079505(6)Rod Bolts- 12109-59500Crank Timing Gear- 1302142L01Rod Bolt Nuts- 12112V5201Oil Squirter- 1156059S00Intake Valve Guides- 1321258560Exhuast Valve Guides- 1321358560
Kansei240sx
KA24DE Slave Cylinder Fits the RB25DET.
Another question are the NGK coppers for the RB25DET PFR6A-11And does the KA24DE oil filter work?
BTW...
PLEASE STICKY THIS THREAD
Vkoslak
Actually, it is stickied. Under "Read Here First, RB Info". Second link down on that page.
I'm using the KA24DE Slave Cylinder on my RB20DET and the KA24DE oil filter.
Acuratechva
Car: Black Kouki
I am trying to compile a list of all major maintenance parts but info some members gave does nto match also i ahve some questions of my own that i didnt see a direct answer to in this post so please answer those if you can.
Belt tentioner descreptancy: two people gave 2 diff part numbers but nobody confirmed which one is the right one.
1)13070-42L00 rb series timing belt tensioner. Same part number as VG30E (84-89 300zx)2)13070-5L300 rb25 tent
Similar issue with coil packs which is the right one?1)91-93 Q45 coils 1&2 work for the RB25det as well as the RB20.2)RB20DET coils (22433 60U01 or 22433 60U02) are the same as 1994 infiniti Q45 coils 1 and 2
Did anybody confirm if this part number for idler pully is correct and if its compatible with any US cars?Idler pully 13074-58S00
All RB20 /25s use same crank and cam seals and T belts correct?
RB25 camseal-2ppl gave two different part numbers:RB25DET Front Nissan PN#: 13510-10Y10RB25DET Cam Seals Nissan P/N 13042-16V00 (stated that they are same as the Z32 crank seal but # dont match with one above)
Someone gave a T-belt part nubmer but did not say what US car it is from...i think it woudl help some i know id like to know:Timing belt 13028-20P10
RB20DETURBO
Car: 240sx
KA24DE short shifter doesn't work on the RB20
OKRB20DET
Car: 1990 S13 coupe
RB20DETURBO wrote:KA24DE short shifter doesn't work on the RB20
haha why do u say this? im pretty sure theres people on here using KA short shifters with their RB's with some small modification
rb20detsilvia
Car: 92 nissan 240sx
OK i heard all these responses on diferant plugs to use what is the bes irridium seems to be and then there are colder and hotter what is better also what o2 sensor for the rb20det
RB20DETURBO
Car: 240sx
I say this because mine doesn't work properly and if it needs to be modified then it's not a direct fit and someone should post how it needs to be modified. Unless it's some kind of big secret.....
DoriftWolf
Car: 1992 Lexus SC300, asst Nissan Skylines when that car is down (which is often)
Acuratechva wrote:RB25 camseal-2ppl gave two different part numbers:RB25DET Front Nissan PN#: 13510-10Y10RB25DET Cam Seals Nissan P/N 13042-16V00 (stated that they are same as the Z32 crank seal but # dont match with one above)
For the cam seals, 13042-16V00 IS the correct P/N .
I had a set sent at great cost to the customer from Japan, only to find that it was the same part # when they arrived as the Z32 cam seals. Of course, this was after exhausting myself trying to get the part #'s to try to cross reference to the USDM part #'s. Having this information before I ordered these would've saved a significant shipping bill for the customer.
Nissan does supercede part #'s, found that a lot with the CA18DET stuff as well, so in this case, both part #'s could refer to the same part, one is just a newer version that works better, but is same fitment.
Valley
Car: 00 celica gt-s 89 240sx hatch
s1 rb25det lower rad hose
GAT 21159
you have to cut off about 4" to get it to fit, but it fits with 0 kinks.
i paid $17 without any special discounts.
anyotherone
Car: '93 S13 coupe VH45
Is it just me or do we need all of this stuff sorted and seperated by engine... this thread is kind of cluttered.
RB280SX
Very cluttered but I'll add more to it xP. Does the TPS and Engine Coolant Temperature from a Z32 fit onto an RB20?
nismo13s
Car: 1990 nissan 240sx fastback
does anyone have a cross reference for a rb20 throttle postion sensor or know where to get one.
blk90s13
Yellow4g63 wrote:
Tensioner part # is wrong I think looking for the right #.
ever got the right numbers ?
wantsansr
Car: 1993 nissan 240sx se coupe
my rb20 came with denso vq22 iridium tough plugs when i cross refrenced them the ngk # was bcpr7eix-11
impreziv
Car: 1990 Nissan Skyline GT-R
i hate to reply to a 3 year old post, but just for future referance: all RB engines share the same starter as most longitudinal Subaru drivetrains. all the 2.5RS, WRX, STi, 2.5 legacys have the same one.
300Plus
Car: 1995 S14 w/ Rb25det Series II
impreziv wrote:i hate to reply to a 3 year old post, but just for future referance: all RB engines share the same starter as most longitudinal Subaru drivetrains. all the 2.5RS, WRX, STi, 2.5 legacys have the same one.
If someone else can confirm this, or just post pics this would be an awesome find!
craz4240
Car: 1995 240sx w/rb20det
Can anyone get me the part #'s for the piston rings,connecting rod and main bearings for rb20det???
