Sil240 »
https://forums.nicoclub.com/sil240-u6842.html
Tue Feb 27, 2007 7:16 pm
Part numbers for RB26DETT only, unless otherwise noted.
Ignitor pack- R32/33- 22020-05U00
Clutch Pull to push conversion-Late Model R32, R33 and R34’sFront cover assembly :32110-05U11 (japan part only)Gasket :32112-05U12Clutch fork :30531-01S00 (same part for a 1991-1993 240SX)Spring :30514-14600 Spring :30534-E9000T/O bearing :30502-14601 Bearing sleeve:30501-S0160 / 30501-N1601 (14mm for twin / trip disc)Bearing sleeve: 30501-K0404 (24mm for single disc)Dust cover :30542-31610Slave cylinder :30620-21U01Flywheel bolt: 12315-04U00
Factory ClutchR32 GTRDisc- C0100-05U15Cover-30210 - 05U01Bearing- 30502-21000
R33 GTSDisc- 30100-21U01Cover- 30210-21U00Throw out bearing- 30502-12U00 (300ZX part) or 30502-45P00 (300ZX part)Bearing Sleeve- 30501-S0200 (18mm)
R33 GTRDisc- 30100-0V708Cover- 30210-24U00 Bearing- 30502-12U00
R34 GTRDisc- 30100-0V708Cover-30210 - AA300Bearing- 30502-12U00
R32/33 Brembo Brake pads- F 41060-12U87R 44060-12U87
Belts- RB26 R32 4 RibsAC- 925 mmPower Steering- 950 mmFan- 880 mm
RB26 R33/R34- 4 RibsAC- 910 mmPower Steering- 969 mmFan- 875 mm
R32- RB25AC- 4 ribs 925mmPS- 3 ribs 845mmFan- 4 ribs 860mm
R32- RB20AC- 4 ribs 925mmPS- 3 ribs 855mmFan- 4 ribs 860mm
R33- RB25AC- 4 ribs 910mmPS- 3 ribs 845mmFan- 4 ribs 850mm
R33-RB20AC- 3 ribs 910mmPS- 3 ribs 855 mmFan- 4 ribs 850mm
R34- RB25/RB20 - 4 RibsAC- 910mmPS- 865mmFan- 890mm
Water Pump-21010-58S25N1 Water Pump- 21010-21U26N1 oil pump- 15010-24U01R32 Thermostat - 21200-42L06R32 ABS Unit- 47600-05U00R33 ABS Unit- 47600-15U00R32 Power steering pump- 49110-05U00Intake gasket- 16175-05U70 (3 needed)Nismo AFM’s 22680-RR580Standard AFM’s 22680-05U00Lower rad hose- 21603-72L00Upper rad hose- 21501-05U00R32 ATTESA valve- 49836-01U00R33 AC Compressor- 92600-24U15R32 Clutch master Cylinder- 30605-05U00R32/33 CAS 23731-02U10/1R32 Starter- 23300-20P00N1 Block- 11000-24U00Injector O-Rings- 16635-78A00Valve cover gasket- 13270-58S11 and 13270-58S01Valve cover half moon seal- 11051-58S00R32 AAC- 23781-05U11R32 GTR ECU- Hitachi- 23710-05U02/01R32/R33 Twin Cam valve cover strip- 13290-05U00R33 Front Hood Spoiler-65834-24U00R32 Oil Pressure Sender- 25070-30P01R33 AC HosesFlexible low pipe - 92480-98U00Front cooler high line- 92440-24U20Flexible low hose- 92490-24U10
R33 Heater core compatible with Z32 heater for you must reuse your plastic inlet and out lines- TBARB26 Dip Stick- 11140-05U02R32/33 Starter- 23300-20P05R32 Alternator (Mitsu unit) 23100-20P10 (90 amps) 23100-86L11 Mitsu (90 amps) and 23100-86L12 MitsuR33 Alternator 23100-70T13 Mitsu (80 amps) 23100-70T03 hitachi (80 amps) 2/97~up 23100-0V010 Mitsu (80 amps)R34 Alternator 23100-0V016R32 2WD model Alternators23100-59S01, 23100-85L00 Hitachi23100-85L10, 23100-85L11, 23100-85L11 Mitsu
Found this on GTR UK BNR32Part Number Item Description Common To Other Source Notes 13028-20P25- Belt - Timing no 16400-72L00- Strainer Assy - Fuel U13 21200-42L05- Thermostat Assy Y32 22401-58S15- Plug - Spark KN13 w/CA18DE 28890-01U00- Blade Assy - Windshield no 28890-51S10- Blade Assy - Windshield B13 28790-56E00- Blade Assy - Rear Window U12? 30100-04U00- Disc Assy - Clutch no 30210-73L00- Cover Assy - Clutch no 30502-21000- Bearing - Clutch Release Z31 turbo 46210-04U00- Hose Assy - Brake, Front no 46214-01A11- Hose Assy - Brake, Rear B13 37521-01U26- Bearing Kit - Center (Driveshaft) no from 89/11 to 90/08 38300-84M79- Final Drive Assy no without EAL sensor 39241-73L25- Repair Kit - Seal, Outer (outer CV boot, rear) Z32 non-turbo 39741-03P27- Repair Kit - Seal, Inner (inner CV boot, rear) Z32 non-turbo 30611-71L25- Piston Kit - Clutch Master Cylinder WD21 '90-'91 30621-26E25- Piston Kit - Clutch Operating Cylinder no 32114-Y4000- Seal - Oil, Front Cover (Transmission) D22 '00+ KA24DE 32112-04U00- Gasket - Front Cover (Transmission) S13? 32136-U0100- Seal - Oil, Rear Extension (Transmission) D22 '00+ KA24DE 32870-V5003- Socket Assy - Control Lever (shifter bushing) S13 32862-V5001- Boot - Control Lever (inner shift boot) S12 38342-P9000- Seal - Oil, Differential Side Z32 non-turbo 38440-N3100- Bearing - Differential Side WD21 '90-'93 38189-21G00- Seal - Oil, Drive Pinion WD21 '88-'90 38120-13210- Bearing, Drive Pinion, Front Z32 non-turbo 38120-10V00- Bearing, Drive Pinion, Rear Z32 non-turbo 39711-73L00- Joint Assy - Inner (rear CV joint) Y32 43210-AA000- Bearing - Rear Axle, Inner no 43206-01U00- Rotor - Disc Brake, Rear Z32 '90 40210-33P02- Bearing Assy - Front Wheel Z32 40206-04U00- Rotor - Disc Brake, Front no 54524-01U67- Link Complete - Front Suspension, Upper RH no 54524N 54524-01U67- Link Complete - Front Suspension, Upper LH no 54500-01U01- Link Complete - Transverse, RH no 54500 54501-01U01- Link Complete - Transverse, LH no 54590-01U25- Extension Complete - Knuckle Arm, RH no 54590 54591-01U25- Extension Complete - Knuckle Arm, LH no 56112-A0100- Bush P11 56112 54618-56S11- Rod Assy - Connecting, Stabilizer S14 56112-V0100- Bush P11 56112+A 54468-01U00- Rod Complete - Tension, Front Suspension no 54476-35F20- Bush - Mounting, Tension Rod G50 54613-01U11- Bush - Stabilizer no 54050-01U11- Bumper Assy - Bound no 43252-30P00- Seal - Grease, Rear Hub Z32 non-turbo 55157-33P00- Bush Z32 43052E 55152-35F00- Bush G50 43052D 56219-33P00- Bush Z32 43052F 55130-32P00- Link Complete - Upper, Rear Suspension Rear Z32 8903 - 9008 55130M 55120-71L00- Link Complete - Upper, Rear Suspension Z32 8903 - 9006 55120 56113-33P00- Washer - Rear Stabilizer S13 56113M 54612-35F00- Bush - Rear Stabilizer Z32 56243+A 54612-01P00- Bush - Rear Stabilizer Z32 56243 55501-35F00- Arm Assy - Rear Suspension, RH Z32 non-turbo to 9006 55501 55502-35F00- Arm Assy - Rear Suspension, LH Z32 non-turbo to 9006 55502 54613-71L10- Bush - Rear Stabilizer S13 56243+B 55490-01U00- Damper Assy - Dynamic, Rear Suspension no 55475-35F00- Stopper - Member Mounting Lower S13 55475M 56217-71L00- Bush - Rear Shock Absorber P11 55154-30P00- Ball Joint Assy - Rear Axle Z32 turbo 55114-39F10- Link - Lower, Rear Suspension S13 55114+A 55114-39F00- Link - Lower, Rear Suspension S13 55114 48203-39F25- Boot Kit - HICAS Actuator S13 36530-71L00- Cable Assy - Brake, Rear Right no 36531-71L00- Cable Assy - Brake, Rear Left no 46011-30P25- Piston Kit - Tandem Brake Master Cylinder no same as GT-R 46010-04U20- Cylinder Assy - Brake Master no Three different brake master cylinders listed - check first48080-50M11- Joint Assy - Steering, Lower KN13 49110-04U00- Pump Assy - Power Steering no 49200-04U00- Gear Assy - Power Steering (steering rack) no 49271-04U00- Rack Assy - Power Steering no 48521-72E00- Socket Assy - Tie Rod, Inner P10 48520-71L25- Socket Kit - Tie Rod, Outer no 49365-10V26- Seal Kit - Oil, Rear Housing (of steering rack) B14 49277-42L00- Seal Set - Piston Z32 '90-'92 49297-10V25- Seal Kit - Housing, Power Steering Gear U12? 48203-10V25- Boot Kit - Power Steering Z32 22433-60U01- Coil Assy - Ignition G50 '91 does not include protector 22020-05U00- Transistor Ignition Unit no same as GT-R 23731-79S10- Camshaft Position Sensor no two listed, check first 25080-89903- Sensor - Temperature Z32 25080X 25070-55S60- Sensor - Oil Pressure Z32 '90 25085-89900- Sensor - Boost Z32 23100-59S01- Alternator Assy no 23300-20P00- Motor Assy - Starter no 23343-20P00- Switch Assy - Magnetic (starter solenoid) B14 '94 GA16DE MT 25567-71L01- Body - Combination Switch no 25570-71L00- Switch Assy - Mirror Control no 24345-51E60- Cover - Connector (for battery connector) P10 24080-01U00- Cable Assy - Battery Earth no 24077-01U00- Harness Assy - Engine no 24022-F6100- Wire Assy - Fusible Link F31 24022 24022-55S60- Wire Assy - Fusible Link no 24022+A 24010-01U13- Harness Assy - Main no 25560-02U00- Switch Assy - Combination no 25260-01U00- Switch Assy - Wiper no 25260P 25260-01U10- Switch Assy - Wiper no 25260PA 25290-01U00- Switch Assy - Hazard no 25160-01U00- Switch Assy - Lighting no 25350-01U00- Switch Assy - Rear Defogger no 25540-01U22- Switch Assy - Turn Signal no 25450-01U10- Switch - Sunroof no 25401-04U00- Switch Assy - Power Window, Main no 25431-01U00- Switch Assy - Power Window, Assist no 28515-01U00- Amplifier Assy - Auto Power Window no 28511-01U01- Amplifier Assy - Windshield Wiper no 28475-01U00- Sensor Assy - Steering no 26025-01U00- Housing Assy - Head Lamp, RH no three kinds listed, check first 26075-01U00- Housing Assy - Head Lamp, LH no 26719-C9946- Bulb (headlight) G50 '91-'93 26011AD 26124-01U00- Body Assy - Combination Lamp, RH (front) no 26129-01U00- Body Assy - Combination Lamp, LH (front) no B6554-04U00- Body Assy - Combination Lamp, RH (rear) no B6559-04U00- Body Assy - Combination Lamp, LH (rear) no 26552-04U04- Rim - Combination Lamp, RH (rear) no 26557-04U04- Rim - Combination Lamp, LH (rear) no 28930-01U00- Nozzle Assy - Washer, No. 1 (driver's side) no 28931-01U00- Nozzle Assy - Washer, No. 2 no 28970-01U00- Nozzle Assy - Rear Window Washer no 28920-71L10- Pump Assy - Washer no 27140-71L10- Core Assy - Front Heater U12 27220-91L00- Motor & Fan Assy - Blower P10 21410-04U00- Radiator Assy no 21501-04U00- Hose - Radiator, Upper no 21503-72L00- Hose - Radiator, Lower no 21430-01F01- Cap Assy - Radiator B13 48470-04U00- Cover Set - Steering Column no G2716-89901- Dam Rubber - Sealant S13 72750-04U10- Moulding Set - Windshield no 72712-05U05- Glass - Windshield no 72725-04U10- Fastener - Moulding no G2716-89902- Dam Rubber - Sealant (rear window) D21 79780-04U10- Fastener - Moulding no 79712-04U17- Glass - Rear Window no 79750-04U10- Moulding - Rear Window no 80730-F6100- Motor Assy - Regulator, RH S13 80731-F6100- Motor Assy - Regulator, LH S13 80720-04U00- Regulator Assy - Door Window, LH no 80721-04U00- Regulator Assy - Door Window, LH no 80300-04U00- Glass Assy - Door Window, RH no 80301-04U00- Glass Assy - Door Window, LH no 83306-04U10- Glass Assy - Side Window, RH no 83307-04U10- Glass Assy - Side Window, LH no 96365-35F00- Glass - Mirror, RH Z32 96366-35F00- Glass - Mirror, LH Z32 96321-01U00- Mirror Assy - Inside no 10101-73L25- Gasket Kit - Engine Repair no 11042-72L25- Gasket Kit - Valve Regrind no 12279-42L00- Seal - Oil, Crankshaft Rear no 11121-42L00- Gasket - Oil Pan no 11044-58S01- Gasket - Cylinder Head no 13270-58S01- Gasket - Rocker Cover no 13270-58S11- Gasket - Rocker Cover no 15255-40F00- Cap Assy - Oil Filler B13 w/GA16DE 11220-02U02- Insulator - Engine Mount, Front no 89-'91 11320-41L03- Insulator - Engine Mount, Rear no 13231-58S12- Lifter - Valve no same as twin-cam CA engines 13070-73L00- Tensioner Assy - Belt (timing belt) no 14035-72L10- Gasket - Manifold (intake manifold to head) no 14032-72L00- Gasket - Intake Manifold (intermediate) no 14036-58S00- Gasket - Exhaust Manifold no 14415-V5300- Turbocharger Inlet Gasket Z31 turbo 14445-V2700- Turbocharger Outlet Gasket no 14465-26E00- Gasket - Inlet Tube (turbo compressor) Z32 turbo 8907-8912 15196-P7600- Turbocharger Oil Outlet Gasket Z31 turbo 14401-72L26- Turbocharger Gasket Kit no 15010-79S05- Pump Assy - Oil no 13510-19V00- Seal - Oil, Crankshaft Front no 22620-02U00- Throttle Position Switch no 16175-79S00- Gasket - Throttle Chamber no 22670-72L02- Regulator Assy - Pressure (fuel pressure) no 25060-01U00- Sender Unit - Fuel Gauge no 21010-42L25- Pump Assy - Water no 17042-73L02- Pump Assy - Fuel no 17251-79915- Cap Assy - Filler B12
BCNR33 Suspension part numbers54618-05U00- front anti-roll bar link (goes on the end of the roll bar)40160-AR510 front inner ball joint 40160-05U00 front outer ball joint 54613-01U11 front anti-roll bar bush 54614-05U00 front anti-roll bar bracket
R32/33/34Wheel bearings40210-05U00- Front43280-AA3001- rear43281-AA3001- rear
Hub seals40232-33P55- front43252-40P00- rear
R34 CAS- 23731-5L300
Updated 3rd, 4th and 5th gear trans part (R32-R33)32606-30P10 Coupling sleave32251-30P14 2nd gear32604-30P60 ring 5th32261-12014 3rd gear32604-30P61 ring32811-05U10 shift fork32611-AA510 Coupling sleave32609-70L15 Shifting insulator X332201-05U71 Main drive gear 32604-40P61 ring32605-30P11 Hub32603-30P00 Spring shifting X232212-AA504 Counter gear 32230-054U24 First gear32137-AA500 Plate 32341-30P04 Over drive gear ( 5th gear ) 32245-30P60 Reverse gear32220-30P60 Reverse gear 32614-30P60 Ring32615-30P60 Shifting insulator X332214-01G21 Corn counter32616-30P20 Coupling sleave32282-30P61 Reverse gear32320-VB361 Shaft32139-VB300 retainer32312-30P24 gear32320-VB361 shaft32139-VB300 retainer
just got off the phone with 2 nissan dealers, they said that:
(Throw out bearing) 30502-21U00 was not a good part #
They said that Clutch Bearing- 30502-45P00 ($33) was a good # and they called this one the throw out bearing???
also, P/N 30501-S0200 has been replaced with P/N 30501-S0284 ($26)
They gave me part # 32202-B9500 for a pilot bearing??
Could somebody with more knowledge than me clear this up? Thanks!
R33 GTSDisc- 30100-21U01Cover- 30210-21U00Throw out bearing- 30502-21U00 (300ZX part)Clutch Bearing- 30502-45P00 (300ZX part)Bearing Sleeve- 30501-S0200 (18mm)
