RB series replacement part numbers, etc
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
Exhaust studs for rb25, are they available in the US?
gawdzilla
Car: none
dohclover wrote:anyone know the part number for a rb20det knock sensor or detination sensor?
p/n 22060-56S10 $150.02Electrical - Powertrain control - Powertrain control - Knock sensorKnock sensor, maxima 1989 - 1990
better off buying used probably
gawdzilla
Car: none
nissans13240sx wrote:Exhaust studs for rb25, are they available in the US?
they dont directly cross reference to a usdm part, but not saying there isnt something that won't work. your best bet might be to call ARP or visit an ace hardware
imotion s14
Car: 1997 240SX
http://www.nismoparts.com/cata...#1697
sleepyeyed240
Car: 1993 rb20 vert, 1989 hatch
gawdzilla wrote:it works. running it myself. zerothread?id=313291
will this fit rb20??
kumasan616
anyone know the matching water temp sensor for an RB20DET? I assume 300Zx
darksurfer81
Car: 1990 S13 RB26DETT
I have looked pretty close at this thread and unless Im missing it I cant find a corresponding part for an RB26 fuel filter and crank pulley. Anyone know if the Z32 fuel filter will work or not? I still need to do more searching for the crank pulley answer.
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
darksurfer81 wrote:I have looked pretty close at this thread and unless Im missing it I cant find a corresponding part for an RB26 fuel filter and crank pulley. Anyone know if the Z32 fuel filter will work or not? I still need to do more searching for the crank pulley answer.
z32 yes, not sure about the crank pulley though.
RB24D
Car: 1996 rb25det 240
Paradox wrote:
Does anyone have the above information on Power steering? What about rear main seal? I ordered a Z32 NA clutch kit, I hope that works.
RB25 rear main seal part # is12279-2B500 avalible at all nissan delarships very common seal same as vg engines .
Modified by RB24D at 6:53 AM 11/13/2008
darksurfer81
Thanks nissans13240sx
tgxlayzie
Car: 89 nissan 240 sx
i talkd to a guy from napa n gave him the part number for the starter n he said it was special order and theres different part numbers that they go by 16201,16210,16212 and he doesnt know if those 3 are interchangeable do you have any idea
gawdzilla
Car: none
tgxlayzie wrote:i talkd to a guy from napa n gave him the part number for the starter n he said it was special order and theres different part numbers that they go by 16201,16210,16212 and he doesnt know if those 3 are interchangeable do you have any idea
no idea about those extra pn's. i ordered mine online through the link i posted in that thread.
kumasan616
I am not finding in this thread of others a cross check of a couple of engine sensors for the RB20DET... needed are as follows:
AAC (EDIT: the DOHC KA unit from an S13 works) Water Temp Sensor (EDIT: N/A Z32 works fine)
Modified by kumasan616 at 9:06 PM 11/17/2008
Modified by kumasan616 at 9:20 PM 2/2/2009
tgxlayzie
ill just do the same dont want to take any chances thanx
darksurfer81
The Z32 filter works like a charm. Correct me i should work if im wrong but the Z32 MAF should work on the RB26 right?
Modified by darksurfer81 at 9:59 AM 11/14/2008
sleepyeyed240
gawdzilla wrote:no idea about those extra pn's. i ordered mine online through the link i posted in that thread.
i got that starter its a little long and it bolts in perfect but clunks and **** idk i just took it out and im trying to find a actual rb20 starter
NismoJunky
Car: 1993 240sx Hatchback. RB25DET, 5 LUG
what about valves!!?? I bent mine
240z4u
Car: '95 Nissan 240SX
sleepyeyed240 wrote: i got that starter its a little long and it bolts in perfect but clunks and **** idk i just took it out and im trying to find a actual rb20 starter
There is no USDM part number for an RB starter.
Evan
NismoJunky
Evan
your right, but I heard that you can use a starter from a 1965 Datsun 411, with the 1.6ltr engine. but there harder to find in the US than a RB starter, lol.
the NAPA part # for it is: RAY2444514
mine was bad too, and I got tired of looking for one, so I took mine apart, and found 2 brushes that were seized, fixed that, cleaned and lubricated everything (with wheel bearing greese), and now it works great.
kumasan616
you can always take a bad starter to your local auto electric shop and they can rebuild it very easily for you
S14eva1
Car: S14 aka "The black bandit"
I im the process of 5spd swap...
what is the part # for RB25 transmission bolts(bellhousing to engine bolts)...?
nyc240sx
Car: 1995 Nissan 240SX SE
RB25DET series 2
autozone or any other auto parts storeM10 x 1.5 60mm
nyc240sx
RB25DET series 2
rb25det oem throw out bearing p#30502-45P00-aftermarket rb25det throw out bearings:Green -P# CB1706-CAetna -P# A3735 Ina -P# F221440 Ichiban -P# CB-10288Valeo -P# 23079Daikin -P# BRG309Other -P # TK40-16K Koyo -P# RCT40SA3Nsk -P# 62TKC4001Gmb -P# GC71029Skf -P# VKC3565Nskf -P# NCR1029
S14eva1
thanks........
rblover
Car: 89 silvia RB20DET
yes thats the part number that fits, the RB it does make noise like a rip cord but it will spin the engine over with no problem everytime. I've been using this starter for 6 months now and now problems at all, just tell people about the starting noise is it has to spin up the power, lol,
I did go around to a few auto electric companies to see about a rebuild and they all wanted 85-120 bucks, and I picked up a reman from napa for like 87 bucks next day.
nyc240sx
RB25DET series 2
nice
gawdzilla
Car: none
rblover wrote:yes thats the part number that fits, the RB it does make noise like a rip cord but it will spin the engine over with no problem everytime.
mine sounds and works perfectly normal. weird.
Neejay
I haven't seen this anywhere in here.
RB25DET PCV valve = 1995-1998 200SX, 1995-2003 SENTRA
mattleegee
Car: s13+19 corolla
Yeah now that the motor is in bolts are missing, i even sandwhiched bagged them with labels, anyone help me out?
info: rb25det s1 with rb25 transmission
r33 mounts- the 4 nuts to bolt it down to crossmember
rb25 transmission- the 2 bolts in the middle of the transmission bracket
those little black screws for the coil pack cover (only came with 4)
anyone know the size of our fuel lines?
(maybe running in FEB!)
eh?
mattleegee wrote:Yeah now that the motor is in bolts are missing, i even sandwhiched bagged them with labels, anyone help me out?
You can go to a hardware store and pick up most of the missing bolts and nuts, but if you want OEM part numbers check out this:http://www.rbforums.org/mounts.htmlNot done yet but getting there..
