Yes it clears most wheels, even stock SE. My q45 brakes are from a 95. So I believe its anywhere from 94-96 q45 brakes calipers, rotors, and pads.Ninjamasta wrote:Does the q45 calipers clear SE wheels? What year is that pair of calipers from?
Instead of redrilling q45 rotors you can always just buy 03 sentra SER rotors. The lug pattern is the same for s13/14 4 lug. I think it was like 50 bucks for both rotors at autozone.rico05 wrote:Nice. I had to redrill my rotors for my 4 lug S13. It will be a lot easier for you. Get some stainless lines and Motul RBF and have fun. I loved this upgrade. I got lucky and scored a rebuilt set off of eBay for $95 shipped with pads.
Hahahaha, as did I.White Comet wrote:i too rock q45 brakes. but i went baller (as baller as you can get with a cheap brake upgrade) and got new calipers and **** instead of junkyard stuff
yup this really cool place called infiniti dealershipashoe wrote:anyone know where i can get a rebuild kit?
The J30 rotors arent quite as thick, this means they can hold less thermal energy, making them not as efficient. Its a minuscule difference though.midnightouge wrote:You guys are forgetting about the J30's, its the same thing besides the brackets.Best $50 i've spent
IIRC they do. Unlike the Z brakes, with Q45 or J30, the calipers are like the stockers, with most of the caliper sitting inward towards the knuckle.callmeweezy724 wrote:not to thread jack but does anyone kno if q45 brakes will clear stock teardrops?
That is the point of using J30 (which i have) or Q45 front brakes. Unlike the Z32 upgrade, the stock BMC retains the stock braking bias on Q45/J30 calipers. The thing is though, your tires are the most important aspect of your braking performance (and handling, etc.) If you're running crappy or skinny tires, the extra stopping power up front will cause you to lock up easier. The only real downside to the J30/Q45 brakes are the extra unsprung weight, but $ for $ they are the best upgrade for a street 240 or a mildly tracked 240 IMO.DRIFTERSWANTED wrote:Q45 brake upgade is nice but make sure you upgrade your pads in the back or you will lock up very easy.
Brakes systems are made to have a certain balance. throwing off that balance will upset the car when driving hard.
