Did you put the calipers on the correct sides? The bleeder screws must face up or you will trap air in the system.EightyNine240SeXi wrote:I just put on Q45 brake calipers with altima rotors and bled the brakes forever but still have almost no pedal. the master cylinder worked fine before the swap. any ideas?
I would suggest gravity bleeding, open all the bleed screws at once and allow it to drip for a while, make sure the master is kept full.
