Q45 Brake Upgrade!!!
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
FlatBlackIan wrote:
The J30 rotors arent quite as thick, this means they can hold less thermal energy, making them not as efficient. Its a minuscule difference though.
double post ftw. I was under the impression that the J30 and Q45 rotors were the same part. Whenever I go to a parts store (advance, autozone, oreilly's, etc.) they have the same part #.
got chub
Car: pearl white 95 240sx
Infiniti J30 1990-1994 280mm x 22mm Rotor
Infiniti Q45 1990-1996 (G50) 280mm x 28mm Rotor
EviL inside
Car: 90 240sx
the J30 rotors are in fact thinner. i've had them sitting side by side and could SEE the difference without a micrometer. i've sold a few sets of Q45 brakes on ebay, i get them from the junkyard, blast them, paint them, and rebuild them. the rebuild kits are like $5 from autozone, and it's easy. the J30 calipers are slightly different, but just in the slider pins and a couple small details, but the piston diameter and pad size are identical.
advance auto parts has the speed bleeders on their website for .95 each, autozone sells the pair for $9. i got a friendly autozoner to price match them for me, and got a pair for $1.90. thinking about ordering a bunch of them and reselling on ebay, i don't know if advance's price is a mistake.
EviL inside
Car: 90 240sx
FlatBlackIan wrote:
Hahahaha, as did I.
I wonder if they will catch the fact that they are attempting to re-man the wrong calipers
i did the same thing when i did an upgrade on my z, turned in the 2-piston non-floating caliper as a core for the toyota 4X4 4-piston calipers. i've done it on 3 cars and noone has said a thing. they are MUCH smaller, no confusing the 2.
homeslicej2
chub, can you check on the sizes of 1993-1997 J30 rotors (or 1995-1997). I was under the impression that 90-96 Q45 and 93-97 J30 rotors where the same.
got chub
homeslicej2 wrote:chub, can you check on the sizes of 1993-1997 J30 rotors (or 1995-1997). I was under the impression that 90-96 Q45 and 93-97 J30 rotors where the same.
they are the same
EviL inside wrote:advance auto parts has the speed bleeders on their website for .95 each, autozone sells the pair for $9. i got a friendly autozoner to price match them for me, and got a pair for $1.90. thinking about ordering a bunch of them and reselling on ebay, i don't know if advance's price is a mistake.
the price actually went down. i saw them for .23 cents and asked how many were left in the US. i ordered all remaining speed bleeders
Modified by got_chub at 9:47 AM 9/8/2008
homeslicej2
got_chub wrote:they are the same
That's what I thought, bc the J30 was only sold as 1993-1997 year models before the I30 replaced it.
Dittoz7
Car: 1997 2f0WtY SE!
So....Which Is Better?J30 Or Q45
You Guys Got Me Confused, When You Started To Throw Numbers At Me.
It Sounds Like A Nicer/Cheaper Option Then The Z Brakes.If I Figure It Out, It's Something Defiantly Going On My Car.
spooled240
Car: kouki s14
Q45's are better as they use a slightly bigger caliper and thicker rotors, which are more resistant to brake fade.
I have q45 brakes on my s14 also and braking feels a lot easier and stronger.
Another thing to consider with the q45 brakes is that they use the same brake lines as our stock calipers so there will be no need to use conversion lines like the z32 brakes require. Just food for thought since these conversion lines are like 40-50 bucks for the fronts.
It is basically a "plug and play" upgrade, the one thing that will take the most time is cutting or removing the dust shields to make room for the larger rotor.
Here's some pics of when I did my upgrade, notice how much larger the rotors are.BEFOREAFTERThis is all you need to run these brakes on your car. Modification to backing plates are required.
hope this helps
The only drawback to these brakes are the performance pad availability, I do believe you can get hawk hps pads for these calipers though.
got chub
q45 stop tech rotors and hawk HPS padshttp://www.zeckhausen.com/Infiniti/Q45_gen1.htm
endless q45/j30 padshttp://www.upgrademotoring.com...i.htm
EBC, endless, hawk q45 pads & rotora, EBC, Powerslot rotorshttp://www.horsepowerfreaks.co..._Pads
there are plenty of good performance options you just have to know where to look. i have well over 300 website for 240sx, 300zx, j30, q45, g35,350z and m35 performance parts. just about anything i need from brakes, motor, suspension anything
midnightouge
Car: 91 Fastback
got_chub wrote:Infiniti J30 1990-1994 280mm x 22mm Rotor
Are you sure about that? Last time i checked they were exactly the same thing.
spooled240
Car: kouki s14
got_chub wrote:q45 stop tech rotors and hawk HPS padshttp://www.zeckhausen.com/Infiniti/Q45_gen1.htm
sweet thanks
got chub
yes i am sure those number are correct. those are for the front. iirc the rear are 12mm or 18mm which is still good compared to the 9mm the 240 comes stock with
White Comet
Car: fc, s13 and mazda6, Sierra
chub is def right about the sizes and props for the links for parts
homeslicej2
You guys are killing me. Stop with the mis-information. The J30 was made from 1992-1997, but was sold as 1993-1997 year models (all made in 1992 were sold as 1993 models). It replaced the M30 model; the J30 was not produced for 1990, 91, or 92 year models (according to NICO and Infiniti parts). Chub, you said in a previous post after I first mentioned they used the same rotors that
I thought you were acknowledging the fact that the J30 and 90-96 Q45 use the same front rotors, but I guess you were saying that your original post was correct. To put this to rest, I called the parts dept. of Nalley Infiniti of Marietta and was told that the 93-97 J30 and the 90-96 Q45 used the same front rotors I was given the same part # for each 40206-AG020. I asked, "do these models use the same front rotors?" and was told yes. I asked what year model he used to do the search, I was told that the same front rotor was used for both cars through their entire model life. The Q45 has slightly larger calipers, but they share the exact same front rotor with the J30. The J30 calipers use the same style brake line fittings as the 240sx/Q45 as well.
got chub
90-92 Q45 use the same rotor as the J30 all years but in 92 the Q had a vin split and the Q45 got the larger rotors for 92.5-96 model years. so yes my numbers are correct(Q yr was early) and my previous post was also correct.
i calledinfiniti parts USA 1.888216.5328lake norman infiniti 1.888.496.3184advanced auto (national wearhouse) 1.877.808.0698
all gave me the same answer for the split vin and same year
240lookis
Car: 1990 240sx hatch
wow! this seems like a really good upgrade for the price. i might have to look for these when i go to the junkyard
homeslicej2
got_chub wrote:90-92 Q45 use the same rotor as the J30 all years but in 92 the Q had a vin split and the Q45 got the larger rotors for 92.5-96 model years. so yes my numbers are correct(Q yr was early) and my previous post was also correct.
Well, I guess Infiniti doesn't know for sure either, bc I was told by my Infiniti dealer that they were the same for both cars for each's entire model life. I also use the thicker rotors for the Q45 and have no problems (no issues with getting caliper on, no dragging, etc.). It's interesting that advanced auto said they are different, bc on their site they list the same part number for the front rotors for all years of Q45 and J30. I used Infiniti parts USA's site and saw that they list a different front rotor for the Q45's with active suspension versus the rest of the Q45's, I don't know.
Ohio_S13
Car: 1990 R32 GT-R, 1999 Ford F150, 2002 Infiniti G20, 2013 Honda Pilot
Are the 03 sentra SER rotors the same size as the Q45?
CRIPES
Car: 98 S14
midnightouge wrote:You guys are forgetting about the J30's, its the same thing besides the brackets.Best $50 i've spent
same i've got on mine.... already locked them up twice and it was very very easy. very hard to fade as well
CRIPES
Car: 98 S14
very minuscule indeed. mine never give up.
i've seen the J30 and Q side by side and you can't tell the difference in size by eye balling. it's retarded to even argue the sizes between the two.
wingFeather
Car: Current: 05 G35 Coupe
Previous: M35, M35 Sport, cube, J30, s13 sr20det, s13 rb20det, s14 zenki
I believe my car has Q45 calipers with Altima rotors up front.
They obviously work better than stock, but I find that they grip too much... causing the front wheels to lock under hard braking.
DRIFTERSWANTED wrote:Q45 brake upgade is nice but make sure you upgrade your pads in the back or you will lock up very easy.
Brakes systems are made to have a certain balance. throwing off that balance will upset the car when driving hard.
+1 I ma in this situation right now
Modified by wingFeather at 2:25 PM 9/11/2008
Ohio_S13
Does anybody know for sure if the 03 Sentra SER rotors are the same size or close to the same size as the Q45's? I guess I am gonna have to go to the parts store .
Pento240sx
Car: 1995 Nissan 240SX SE, 1981 Datsun 210 Deluxe, 1981 Datsun 810 Maxima Deluxe and 1999 Infiniti Q45t.
Hey Can I Have One Please
got chub
why dont you call infiniti usa the numbers are listed in this thread
night240
Car: Nissan 95
time to get me some q45 brakes.
got chub
yeah $5 and you can have a set or $10 for the entire cars worth
White Comet
really? where do i paypal to?
got chub
White Comet wrote:really? where do i paypal to?
ok speed bleeders
$10+ $2 shipping for 4 bleeder screws
i don't want to sell on someone else thread so just email me for details and paypal address(same as email)
Modified by got_chub at 12:12 PM 9/11/2008
mig240sx
Car: 468hp 240sx
spooled240 wrote:This is all you need to run these brakes on your car. Modification to backing plates are required.
What modification do you need? How is it done? Thanks.
