sil80drifter wrote:Btw, the trannys are the same. The bellhousings may be different, but the gear ratios inside them are identical. As are the differential gears, unless you are talking about an LSD s13 vs. a non-LSD S13. Still the ratios are close enough to be considered identical even in that case. If he passes you "at 125" there must be another reason for it. Like top end.
sil80
Yes, the gears are the same. But the SR revs a lot higher, thus it has a higher top speed. My KA redlined at about 6400, my SR is 7500. Same gears. SR can do 40mph in 1st gear, the KA can only do 35 or so. (yes, I feel 900rpm is a lot higher)
However, the top speed on a KA isnt 125, it's much higher. Like 145, the top on the SR is like 170. These are redlining 5th gear. I might be a little off, but you see the point.
I'm not hating on either motor btw
