sil80drifter »
https://forums.nicoclub.com/sil80drifter-u622.html
Tue Mar 30, 2004 1:35 pm
This is my own list for turboing my SOHC, and it shouldn’t vary much for a DOHC, since the only different part required is the shape of the manifold and IC piping (no extra costs either way).
FUEL/TIMING:Fuel Pump (recommended for KA-T AND SR, hence can technically be deducted from turbo price, since both will get it anyway)$100
Fuel Injectors (KA-T only but assume bigger size than SRs stock ones, since it's an upgrade, usually 440cc+)$150
SAFCII (controlling the fuel)$300
MSD Universal Adjustable Timing Module (timing retard)$100
Tuning (an hour at a local dyno, can be more depending where you go)$50
TURBINE/EXHAUSTTurbo (used, otherwise assume higher price and much better performance than stock SR turbo)$100
Manifold (assume access to some home made welding)$120
Exhaust, with DP+SP/Cat muffler (can be subtracted from both totals, since SR will require exhaust as well, same assumption as above about welding)$200
INTAKE:FMIC (used, still better than stock SR SMIC, for larger size assume higher cost)$70
FMIC piping (includes hose connectors, rings, and air filter)$135
BOV (used, better than stock plastic SR)$30
Home Depot style MBC$10
MISC LINES, GAUGES, CLUTCH, PLUGSOil Lines (includes turbo oil flanges and Tees)$50
Water Lines (includes turbo coolant flanges and Tees)$50
Gauges (oil temp, oil pressure, water temp, boost)$150
Clutch (can also be subtracted from both totals, since SR will require upgraded clutch as well)$300
Plugs$10
Total:$1925
Total with similar SR items subtracted (Fuel pump, exhaust and clutch):$1325
Total of getting an SR with transmission/ECU/harness:$2000
The differences in the first two totals mean that a BASIC cost of upgrading power will be $600, no matter which path you choose KA or SR, to which you should add the price of work, unless you do all the installations (not manufacturing) yourself.
If you disagree on some of the prices on the list, remember, they ARE attainable, but you will have to put some time and work into making it happen, because even though we assume we do our own work, not everyone has good access to welding, but you CAN get access to it, if you network a little and find some people who will do it for cheap, to justify the manifold/exhaust costs.This is a tentative list, it assumes that you're working with a KA in ok shape, or putting in a stock SR, and doing nothing to it except for clutch/fuel pump/exhaust which are reaquired out of mostly "solidifying" reasons (clutch wears fast, the SR injectors can use a better fuel pump, and you will need a DP to connect to stock ex-KA exhaust, so you may just do the rest as well, because if you don't then whoever is building the KA may also just make a DP, and be done with it, so cost is still the same).
I fully support the argument that cost is only one of the factors for choosing either one, but for a lot of us it is a very important factor, since the $ to HP ratio is what decides our goals for us in the end. I really liked someone’s quote who said a car can be cheap, fast, reliable, pick any two. You can have something reliable and fast, but it won’t be cheap. You can have something cheap and fast, but it won’t be reliable. You can have something cheap and reliable but it won’t be fast. You get the point.
I for my part am not bound by high HP goals, and I think the highest I would want to go for is around 300-350 WHP. That’s long term though, short term is 200 WHP and eventually 250 WHP. After this, if the KA doesn’t blow due to my inexperience with tuning (!), I know that in order to have a more or less happy engine at 300-350WHP it needs some rebuilds, especially if it’s a tired KA, with compression numbers that are not that great (sigh). A cam (SOHC remember), maybe some DIY port and polish, and new pistons rings would do the car some good at those levels. But those things can be done to an SR as well, just to err on the safe side. Again, I am not worried about the KA reliability, because a KA with around 50k miles on it can do just as well with it’s stock bottom end as an SR with similar mileage (and you usually get them with 30-40k), for even high HP numbers, and such a KA can be found for 500 shipped, or even less if you can get it in your area. So the only reason I would rebuild my KA is because it’s old. Then again, I have block with 70k miles on it that I got for free (that’s how cheap they can be), that has good compression numbers and which I wouldn’t be afraid to take to 350 WHP on stock bottom end. Yes, I can hear you yell “Not everyone can get free KAs!” Maybe. But I looked hard. And I’ve seen them go for 100 bucks for the block itself and 200 for the whole engine.
I guess I’m done rambling, and I hope that you guy see my point (as finance related as it is). As a final note, my setup will be approximately rated at 200-220WHP for that $1875 shown above. That’s pretty good for me, assuming I could go up to 250WHP by just upping the boost (from ~7psi to ~10psi), and getting the most out of that particular kit. Keep in mind that includes things that are usually not part of most kits, such as clutch and exhaust (2.5” in my case, can be 3” for same price), and things that SR owners also may invest in (I still count them as part of the KA-T cost because we cannot do without them) such as the SAFC, MBC, and MSD Timing Module.
Ok, now I’m done.
sil80
