karay240 wrote:why don't you want to keep them dry sump? I'm seeing more pros than cons w/ dry sump. . .
well, with a dry sump, the biggest con is complexity,
this is from an article in HotRod magazine which explains how to build your own 357ci 650HP Chevy SB2 small block...with an 8,000 RPM redline...and it runs on pump gas
"the dry sump system has a belt-driven, multistage pump bolted to the front of the engine that is essentially four oil pumps spinning on one shaft. Three of the stages are used to suck oil and vapor out of the engine and one stage is used to pump oil from the large cylindrical oil tank into the engine"
plus, the belts can break easily if a rock or something gets in there...but dry sumps can be worth 30-40 hp
