A solid valvetrain is the only setup that would require reshim/readjustment....Hijacker wrote:You should only have to reshim if you change valves train components. Most notably valve replacements or valve spring changes.
I don't quite comprehend why you would be in a situation where you'd need to reshim your head within 15k miles of using the same compenents
Did you turn the fuel pressure up to normal yet, so we can see the new numbers?ZL-Auto wrote:
If you need help with your build give me a call.Thanks,Robert
469rwhp SR -Bored & Built - 3071R -
Not according to the service manual. I just finished translating the S13 shimming section and compared it to the S14 section.codyace wrote:A solid valvetrain is the only setup that would require reshim/readjustment....
The shims are designed to be the same height as the shallow section of the rocker arm guide (the shim with two tabs on top of it) The point of using the dial gauge is that you 0 it on top of the of the rocker guide and then compare it to the height of the other valve that the rocker would interract with. The measured distance (T) is the height of your shim (T1). The shims are supposed to be within .025mm plus/minus of the number you find on your dial gauge.S14 Service Manual wrote:4)Determine proper shim size when replacing valve, cylnder head, shim, rocker arm guide, or valve seat.
Haha, you're right, but to restate my point, you will need to reshim for solid valvetrains.Hijacker wrote:Not according to the service manual. I just finished translating the S13 shimming section and compared it to the S14 section.
The point of shimming is to make the rocker sit flat across the valve pair. The height of the lifter/pivot has little bearing on that and doesn't even factor into the shimming process that Nissan laid out. While I have always said that you should reshim for solid lifters, I'm starting to question that method now. After reading the factory shimming method, it almost seems like a lesson in futility to reshim for solids.codyace wrote:Haha, you're right, but to restate my point, you will need to reshim for solid valvetrains.
The tool Nissan states you need is just a stand that screws onto a standard dial gauge and then the unit sits in the hole for the HLA. I didn't see any tools on the site you linked, and I am interested in the homemade thing you mentioned from FA. I wonder if it's along the same lines as what I was thinking of making with some spare, blown HLAs I have lying around.codyace wrote:http://www.customsteel.com/sr20 sells a slick little height tool. You can also make a homebrew style one, using the one writeup on Fresh Ally (I know, cross posting a forum, but it's still good information). Lstly, if you're even luckier, you can do it per FSM, but finding a shop with the nice Nissan valve measure plate stuff is rare at best, and buying one is uber pricey!
Get a student loan then blow it on your car. Short term gains ftwredtop91 wrote:Mazworx will reshim heads on the cheap. I'm lazy so that's the route I'll be going. Once I've paid for all my books for this semester they'll be an update guys.
I read that article on FA about the homemade shim tool a while back. I'd be really cautious about using a homemade tool on shim work, being that it's so precise. But there's probably people more confident in their tool-making skillz then me haha.codyace wrote:You can also make a homebrew style one, using the one writeup on Fresh Ally (I know, cross posting a forum, but it's still good information). Lstly, if you're even luckier, you can do it per FSM, but finding a shop with the nice Nissan valve measure plate stuff is rare at best, and buying one is uber pricey!
thisis how it is for most people and their builds right now. just slowing down due to lack of funds and crappy weather.redtop91 wrote:LOL. It's not right now. I'm penniless and it's freakin cold!
Don't forget waiting on parts. I've been waiting on bearings since before New Years.idahotuner wrote:thisis how it is for most people and their builds right now. just slowing down due to lack of funds and crappy weather.
