Nope, not much at all. If you look at the manual, it says to cut about .5mm wide and 2~3mm long so its just getting rid of the tip of the legs of the rocker arm so that they don't dig into the shims with 12.5mm lift and solid lifters.C - ROD wrote:is that all, they hardly took anything off huh?
Alright, i read this over like 7 times and im still not quite sure if i get it. (Sticking with previous scenario) If you get those bad *** cams your basicly allowing more air into the engine, shifting your graph to the left (lower rpms), and hitting the turbo's max it the lower rpms (20lbs @ 4000rpm) which in some senses is good(if u want it that is). Was i in the ballpark at all on that one?karmakaze wrote:
think of it like this, your engine is a air pump. it flows so many lbs of air per minute and this number varies based on RPM. Theoretically speaking, (disclaimer: these are all made up numbers! i did no real math or research) lets assume that an engines cams allow for a max flows of 25lbs per minute @7000RPM and you are running a small t28 that puts out 20lbs per minute @7000RPM. Lets say that @ 6500 your engine is pumping air at 20lbs per min. this mean that above 6500 your not going to be gaining anything except for damage to your turbo by being out of its effenciency range. lets say you throw some bad *** cams in that flow 45lbs per min. This changes the "range" of your flow. so instead of having a range of 0-25lbs that corresponds to your RPM of 0-7000 you have a range of 0-45lbs in that same 0-7000 RPM range. If you plot this on a graph you will see that the engine will now be able to flow that 20lbs at like 4000RPM (thats a guess) so you will not really see any gains above that.
I think thats right. Someone doublecheck to make sure my logic is working today.
S13FASTBACKSR wrote:Say you have a small turbo..a t28 and you put on 270's or 272's or 280's..those high durations flow a loooooot of air..like karmakaze said x amount of lbs/minute..those cams flow a high # of lbs/min..and that turbo flows a small amount of lbs/minute..The reason you must match your cams with your turbo is because when all of that air that the cams are letting in get to that turbo its like hitting a brick wall ( well the flow does not stop completey but it slows down extremely if you will)..and if you put a huge turbo on and small duration cams its not enough air to match what the turbo desires so you are being robbed of power both ways
270s are definitely not an overkill for anything over 400 RWHP cars. Most of the dynos Ive seen with that much power have 270s or higher. Even with GT2871R .86 ex A/R, the boost should come on pretty strong and pull hard all the way to red line. Flowing up top is so important especially when you are increasing your rev range by going solid lifters so I wouldnt call 270s an overkill.cheapscheisst wrote:also, are you sure that 270s are overkill for a 450+whp sr?
