alright time for some updates.
i figured out all my last minute wiring problems.
my stupid nub a** had the hazard plug backwards so now it works. headlight motor was dead which caused it to wink constantly.
should have it fired up this weekend, and make sure its running up to par.
still gotta wait a few weeks for money for a driveshaft and then scheduling the exhaust shop/ inspection and getting all the paperwork ready, with classes just starting im broke as usual
ooo hai its alive
at least its vital signs.
ok
now i got the trans mount just about finished; i need to notch the holes bigger and then im going to run some exstended nuts; and cut them to be flush with the plate. then ill have my friend weld some plates to it sits flush with the plate and doesnt move.
honestly i dont even think i need to bolt them down. considering there is no clearance for it to move up/down to move the whole trans.
pics
[IMG]
http://i174.photobucket.com/albums/w92/ ... CN0655.jpg][/IMG]
here you can see where my drill kept slipping' as its a piece of s*** and this is really thick aluminum. o well function over form right?
i only have one concern and that is that the trans is facing too far up, since the mount is pretty far up the tunnel.
any thoughts? i mean the plate is milimeters below where it comes into the cabin? with a one piece, it SHOULD line up fine; but it does worry me a bit.
finally i started fabbing up the rad mount.
the lower mount is in, i took a 90 degree bent piece of metal to make a cradle for the KA rad to sit it (the stock holes were too far apart for the little plastic nobs to be incerted.) i cut those nobs off so the rad sits flush with the top of the upper rad support
now all i have to do is make tabs that slide over those stock rubber things and bolt them to the upper rad support.
