In your neck of the woods, perhaps they don't. In US states that have strict emission control, such as CA, they do check to see if your car has catalytic converter(s).mightyversa wrote:its illegal yes but who cares its not like the authorities are watching for people with cats taken off.
It varies from state to state, and in some cases just cities. Some have their own rules, some have adopted the same rules as CA (like greater Portland metro area in Oregon). Here in LA smog checks are required every two years (in addition to annual registration renewal). Failure to pass means you do not get your registration renewal until you pass. Test entails sniffer, OBD2 hook-up and visual inspection. In my BMW the cats are bolted right to the headers, not easily seen, and the tech nearly gave me a fail thinking that I had removed them and installed headers... that is until another tech who was more familiar with the engine (same as E46 M3) came over to point out the cat. My tech wasn't about to take my word. Yah, it's pretty strict. Testing stations are pretty much state sanctioned monopolies. They get guaranteed income as long as they play by the books (or don't get caught). It's a pretty good money making scheme and doesn't really have any impact on air quality (or lack of it).mightyversa wrote:Really? Wow, I guess this Header will benefit us Canucks more than anything I guess. Is the rest of the states as strict as Cali? Or is it just Cali with the strict emissions?
This is what we do with lancers and Evos when we run test pipes instead of CAT's. first remove the O2 sensor that comes after the CAT and then in it's place screw in a anti-foul plug that you can get at a local parts store. then screw the O2 sensor into the anti-foul plug. The idea is that you move the O2 sensor out of a pipe just enough so that the O2 picks up exhaust coming out of the motor, but not all of it, so thinks the car is burning really clean because it's only getting a fraction of the air. So guys that are running really awesome setups have to double stack 2 plugs. If I can find the write up I'll post a link.mightyversa wrote:How do you trick it? Cut the sensor off and cross the wires?
Dude, you dont need to be so negitive. Most Versa people I know are really eger to get tuning, and this I just the thing they've been looking for. Besides, OBX is actually a really good brand. They only get a bad name because they are mostly sold on Ebay. That doesnt make them bad. Every 240sx own that I know that has used them said that OBX was better then any aftermarket header they've used, this includes performance, looks, and durability. I'm personally exited to see stuff like this finally coming out for the versa, so were you choose to doubt it, I choose to welcome this advancement in the market and I'll place my judgement after OBX has had a chance to prove itself on the Versa, not before.Red Devil wrote:yeah, let me know how it goes once you get the CEL, worse gas mileage, rusty header(it doesn't say what grade stainless) and I don't know what quality you expect from a $200 header but you'll probably only get 5-10hp.
yes, unless they moved the cat for some reasonmanvan wrote:ok, so lets say i do get the headers, will it fit on mine and blindsnipers and who ever has a cat back with custom piping?????????????
The exhausts are slightly different lengths between the 2. Although I would think from header to cat would be the same and the catback would be the difference.MinisterofDOOM wrote:Why would they claim it fits the HB but not sedan?
That was my assumption as well. Could be wrong, but I don't see any reason why Nissan would change things in front of the cat between the two cars. Plus if it was that different you'd likely see different HP ratings for the two versions.biggie wrote:Although I would think from header to cat would be the same and the catback would be the difference.
