OMG.....VERSA HEADER
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
superskunk
Car: '07 Nissan Versa S Hatch
'06 Nissan Murano SL
Red Devil wrote:
If it looks like this then it's normal, especially the "exhaust" sound....
http://upload.wikimedia.org/wi...1.jpg
Sorry, had to do it.
LOL!!! that is one expensive mod!
Skim302
Car: Nissan Versa S
Lol. I didn't understand it at first but after I read my post I laughed.
superskunk
you have your header installed already too?
viet510racer
Car: 08 Nissan Versa SL
are there any problems with urs SK?
Jus14
Car: 97' S14 and 08 Versa
I dont hear much of a buzz persay but where we got in hung so snug and tight got a little extra vibration i put the torque to mine so they should have seated well also lol
#1Tango
i got a leak coming from the header gasket connecting to the engine. gonna take it to a diff exhaust shop tday to see if they can help me out.
viet510racer
interesting... i guess i'll hold off on gettin this "OBX" header.
biggie
#1Tango wrote:i got a leak coming from the header gasket connecting to the engine. gonna take it to a diff exhaust shop tday to see if they can help me out.
What gasket was used? Normally best to use an OEM gasket instead of one that comes with the header.
#1Tango
ya i did more research online and found out it would be better to use OEM. i used the gasket it came with. i wonder how much an OEM gasket would be from the dealer
WORKS89
Car: EVO VIII GSR, 07' Versa 6spd, AND 92' Z32
probably not much. I just bought one for my car (not the versa) and it only cost me $20.
biggie
#1Tango wrote:ya i did more research online and found out it would be better to use OEM. i used the gasket it came with. i wonder how much an OEM gasket would be from the dealer
Looks like this could be it, for $27:http://www.courtesyparts.com/1...=6382&
Skim302
Car: Nissan Versa S
superskunk wrote:you have your header installed already too?
Yeah I have mine on. Mine is buzzing too so I guess I'll try to get the OEM gasket as well but I'll wait till someone else does it to see if it actually helps.
#1Tango
Well i found my problem. i changed my oil yesterday and since i had the car on jacks, i started it up and went under the car and noticed that the only thing that was leaking was the header to the exhaust gasket. it was leaking all around it. so im going to a different shop today and see wat they can do for me. so it wasn't the gasket on the header on the engine (for me it wasn't) its the gasket to the exhaust.
Jus14
They also make a high temp liquid gasket for like turbo downpipes if you cant get anyone to fix it try that i mean at 2000 Degrees this stuff isnt suppose to leak for any exhaust seems like a quick fix..... The techinical name for it is High Temp Stove and Gasket Cement
#1Tango
turns out the bolts couldn't take the stress and the heat and they just snapped off. twice... so far the 3rd set is holdn up
Skim302
Car: Nissan Versa S
#1Tango wrote:turns out the bolts couldn't take the stress and the heat and they just snapped off. twice... so far the 3rd set is holdn up
Thats weird that this isn't happening to anyone else.
#1Tango
what i mean by stress is that the exhaust and the header pull on eachother very slightly, the gap without the bolts isn't very flush there is like almost a 1/2 inch gap between them. maybe they are pulling on eachother so hard that when the bolts get hot they expand and snap? only thing i could think of
Red Devil
Car: 1990 240SX w/t SR20
2008 Nissan Versa SL
#1 reason why I leave my stuff stock.
blindsnyper
Car: 2007 versa
Red Devil wrote:#1 reason why I leave my stuff stock.
because he is making a hb header work on hus sedan???
Red Devil
No
That's why. I like having not broken things.
Shad0wXCalibur
Car: Nissan Versa SL Sedan
I do agree this seems like a lot of work and money for a dinky engine to make it go from slow to kinda slow... Only thing I'd do to mine is throw on a Magnaflow muffler.
nissan24009
Car: nissan 240sx
You should be more specific next time saying that. You're a hyprocrite by saying that when you have a modded 240sx.
blindsnyper
Car: 2007 versa
and this is a 240 guy saying this
Red Devil
How so? My Versa is a new car. I depend on it to get me to and from work every day. Something breaking on it isn't in my best intrest, neither is modding it.
That's why I have my 240. I can tool around on it without worry because I don't use it as daily transportation. It's my fast car that I can beat around on the backroads without worrying if I'll be able to drive it to work the next day.
I should have been more specific though. It's why I leave my Versa stock. I don't need something on it to break and have to pay out the a** for a part. In this case I only forsee a lot of financial woes. If something more serious on the engine breaks, it won't be warrantied. It's a perfect instance where the part leads to the component failure. Like I said, why I leave me V stock.
FYI, in no way am I trying to portray modding as a bad thing, just saying what's on my mind.
Skim302
Car: Nissan Versa S
Yeah I wish I had a project car. But I'm only 19 with a Versa so I'll do what I can for right now. I definatly don't want anything to break but I think I only have like 5k more miles on my warranty anyway.
#1Tango
well all i have to do is just put less stress on the header and exhaust. simply just extending/moving the exhaust so it isn't pulling as hard.
superskunk
hows it holding up so far?
#1Tango
yes it is it purrrrrs at me
Return to “Versa Technical Discussions”
