Here are some pix of the install
The obx header
My Car that needs a wash, bad.
took out the oem cats
The oem header after the cats were taken out
The cats and the straight pipe side by side. i noticed that the straight pipe and the oem pipe have the same diameter
The heatshield (i didn't have them install this back on the obx header)
Oem header taken out, notice in the 4 pipes they are crimped at the end to fit in together, and then tightly packed in.Notice the difference inside the OEM header compared to the Obx header at the beginning of the post. These look really small and restrictive.
Side by side comparison
Welded the flange from the down pipe onto the pre-cat
Obx header now installed and in place
Cut and adjusted my exhaust to make sure everything fit
Obx Header installed
So that's it for the pictures. The whole install took 2hrs 50min. and it costed me $130. i tried to get the pictures in some sort of order. . Hope everyone likes the pictures.
Ok heres the exhaust video, first with the OEM header and then the OBX header and then some sound bytes at the end. hope you guys like it
http://www.youtube.com/watch?v=E8LWufKBhDA
Modified by #1Tango at 4:19 AM 3/10/2009
