Me too, thats why I emailed a link for this to Greg.MagikDragon wrote:I think this needs some front page exposure!
e-mail sent! Look forward to hearing from you.
E85 is a great way of getting things done. MN has more E85 than anywhere.kenno470 wrote:OK...in the rule book for Pikes Peak Time Attack it says I'm not allowed to use Methanol. Which is a bummer because it's an easy 15% horsepower gain. HOWEVER...I am allowed to run E85. Let's look a the pro's: octane through the roof...free horsepower...It runs cooler than gas...and maybe the biggest pro: it's much cheaper than race gas.
The cons: I have no idea how to set it up in this application. Fuel pump requirements? Injector size? Will it play havoc on my O2 and other sensors?
It'll be fun to learn, but do I have time?
What do you think?
Down here (Texas)premium might not be a problem, depending on how much boost I decide to throw at it. But up there it's a whole new ball game. I've seen brake fluid boil up there, as well as some other crazy stuff. Keeping things cool is ALWAYS a problem. Race gas runs much, much cooler than premium and comes with the added advantage of eliminating detonation.Deatsch Works? I don't know them. I'll certainly try to look em' up. Thanks for the tip!MagikDragon wrote:why run race gas if you can run premium?
how much hp are we talkin here?I do not think e85 will reap havoc on most of the new fuel pumps/injectors. one call to deatsch works might give you some answers.
Think I won't be pinging you when it comes time to set this up? Rhys Millen ran E85 in his solstice this year, so I know it's possible. I'll have questions for you on that wideband O2 sensor...For the injectors viton o-rings should do the trick.I have no idea how to calculate injector size. This is my first go at electronic fuel injection. Our drag cars all used mechanical FI...we started with the mfgs base line and changed jets and bypass pills according to EGT, etc...So, I'll need to buy a vowel on this one...FlatBlackIan wrote:
Here is a quick rundown of what you need.
You need a high volume fuel pump, if you plan to run a fuel cell, make sure your pump is rated for alcohol, 95% of new ones are, so you should be fine.
All your rubber fuel lines must be alcohol rated, most performance fuel lines will do fine.
Injectors will need to be large, E85 requires about 30% more fuel to achieve stoich ratio. Calculate injector size for you desired power lever using gasoline, then add 30%. AFAIK, most aftermarket injectors are alcohol safe, just make sure to replace the o rings.
Tuning, you will need to tune just like you would with gas, except you will need to use a lambda based wideband o2 sensor.
One thing I do not know is altitudes effect on E85, it is possible this may cause problems, though Im guessing it has been done before.
Thanks. That little Hobart 140 is doing a great job for me. For the stuff I need to do on this project it'll work out really well!MagikDragon wrote:Awesome Job Ken, Nice welder, we used the same one for our car. Its a sweet little machine.
You guys are making great progress
You can use any power steering rack as manual as long as you modify it properly. To do things right, you should remove the flow control valve mounted in the base of the steering gear. Then take the high pressure line and cut the end off of it, then connect it to the power steering reservoir where the feed line would normally go. Leave the return line as it. Refill the reservoir with ATF. This creates a loop for fluid to flow, this way things stay lubricated, and you don't have to fight internal rack pressure to turn the wheels.kenno470 wrote:Does anyone know if I can use the factory power rack as a manual rack? Is it ok if I just block off the ports and run it as is? I'm still trying to decide if I need to keep the power steering or if I just ditch it.
On dirt, tire width isnt your biggest worry. You need to look at your scrub radius, its the distance between your steering axis, and the center line of your contact patch. The higher the scrub radius, the more effort will be required to turn the wheels. Also adding more caster will also increase steering effort.kenno470 wrote:That sounds easy enough. I am a bit concerned with how much effort will be required with an 8.5 to 9.5" front wheel. I'm thinking a 255/40 or 275/35 front tire...How much drag do I really save by eliminating the power steering? Enough to make it worth the extra effort?
Thanks!!
Not sure yet. Either 245/275 or 275/315, if they'll fit. I've always been a big fan of BF Goodrich tires having raced on them before, but we'll see. I'll use whatever works best!FlatBlackIan wrote:Glad to be of help, what do you plan to run for tires?
Ive seen open class guys do this before with very good results.kenno470 wrote:I'm allowed to groove an R Compound tire, so that's the way I expect to go.
Bye!
e-mail sent.Terrorinc17 wrote:Send me all your calipers and we will get them rebuilt and powdercoated.
I will also do some crew shirts and T shirts for you guys.
I will send you several cases of a new organic (Awesome Tasting) drink called "Sick Tea".
http://www.sicktea.comhttp://www.timmymegenbier.com
Send me an email at [email protected] with all your info.
Good Luck!
