OFFICIAL: NicoClub's Rally 240SX, by Finnish Fury Rallysport
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
I would've kept rear glass, rear quarter glass, trunk lid, etc. SO many parts on that bish.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
PapaSmurf2k3 wrote:Any reason you riveted the roof on as opposed to welding it?
I welded a panel on initially. It looked like garbage. The rivets look a lot better, plus the roof is much stiffer now because I was able to pull it tight.
Also, if and when I manage to take a tumble, replacing the roof panel will be as easy as drilling out the rivets.
breadbox wrote:I would've kept rear glass, rear quarter glass, trunk lid, etc. SO many parts on that bish.
The trunk was dented, and the clear coat was pealing. Plus I have no use for coupe pieces, I only have hatches now.
PS, have ever tried removing tempered glass from an S chassis? I have, and no thank you. :eek: :eek:
J14cm7
Car: 95 240sx S14 SR20det
FlatBlackIan wrote:PS, have ever tried removing tempered glass from an S chassis? I have, and no thank you. :eek: :eek:
agreed...havent been on in a while and the project looks great. Now when did you say you will be wrapping the entire car in carbon fiber again?
IanS
As soon as I get that shipment of carbon wrap from you. :gapteeth:
mRodiek
Car: Stock Hatch
Congrats on landing a spot in the new Burger King breakfast commercial
The project looks great, looks like you had some fun jumping the railroads lol
motoman399
Car: 98' wrecked (RHD coming soon) 240
mRodiek wrote:Congrats on landing a spot in the new Burger King breakfast commercial
did i miss something???
mRodiek
Car: Stock Hatch
Yeah I made a poor comparsion, saw a guy in the new commercial that kinda in a lil way looked like Ian, I saw it again & changed my mind lol
sorry
IanS
mRodiek wrote:Yeah I made a poor comparsion, saw a guy in the new commercial that kinda in a lil way looked like Ian, I saw it again & changed my mind lol
sorry
Nope, you were right the first time, just one of the many faces of the lumberjack.
:spitout:
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Now I'm really confused. So you WERE in a commercial? Or someone that resembles you was in a commercial?
IanS
PyR0NiAk wrote:Now I'm really confused. So you WERE in a commercial? Or someone that resembles you was in a commercial?
yep. :yesnod
motoman399
lol
J14cm7
yep. :yesnod
exactly
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
I like the new bumper on the truck, good to see some progress on the car too! :)
mRodiek
Car: Stock Hatch
Ok so I wasnt off base completely? lol Didnt want you to take it the wrong way
IanS
mRodiek wrote:Ok so I wasnt off base completely? lol Didnt want you to take it the wrong way
Hahahaha, I have no idea what commercial you are talking about. I just thought it would be fun to play along.
Dano
Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian
S13AL
Car: 1991 240sx hatch with blacktop s13 sr20det, HKS Hipermax III suspension, HKS Sport exhaust, Blitz downpipe, S15 Sylvia HLSD, 300zx/J30 5 lug and brakes, and mesh wheels
every post that bumps this thread has nothing to do with the build( like this one)
Need moar updates!!!
motoman399
agreed...
i dont know how it is on s13's, but on s14's its cake. they dont glue in, its like a foam tape that is easy to cut with a window removing wire. but the windows that were glued in (having been replaced) were a PAIN IN THE a**..
IanS
Dano wrote:Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian Ian
WHAT!!!!! :chuckle:
motoman399 wrote: i dont know how it is on s13's, but on s14's its cake. they dont glue in, its like a foam tape that is easy to cut with a window removing wire. but the windows that were glued in (having been replaced) were a PAIN IN THE a**..
Yah, S14s are easy. The S13 windows are glued in using polyurathane. The stuff is vicious.
More updates are coming. Bodywork has started, and I will be getting more done today.
IanS
We have skid plate.
I finally got around to getting the plate installed. Except there was a slight change in plans. Originally I had planned to use a single main skid plate, with a bend in the middle. After a few different attempts, I made a decision. Instead of bending the plate, I cut it. This will make removal for service much easier. The whole sheet would have been heavy, this way, its much lighter. Plus, the front portion should never need to come off.
Turning 2 into 1.
Then I marked out the mount points, and drilled holes. Uni bits FTW.
Test fitting the bolts. 5/8" diameter, grade 5.
Marking where I want nuts welded on.
I will be adding a fifth bolt all the way in front of the core support.
Then I repeated the whole process. Looks awesome with both plates installed.
Thats it for tonight. I need to get some lights so I can do some testing with the new rear springs before the snow flies.
Razi
Car: Moo
That's awesome!
Keep up the good work Ian! :D
IanS
Picking up some aux lights tonight. Finally time to build a light bar.
Cale is in the process of building the coolest shift knob ever. Just wait till you guys see it. I will try and update over the weekend.
RallyB13
Car: 2003 Nissan 350z Touring
2004 GMC Sierra 1500 SLT
2011 Toyota Sienna LE V6
2016 Subaru WRX Premium
Enjoy 'em!
I know you're looking at HID conversion, but if you don't, those FF1000 lights can be run up to 130W bulbs, as long as you only run them when you're moving, so that there's air moving over them to keep 'em cool. And as we talked about, the H1 HID retrofit kits work very well, since the HID capsule is a near perfect match for an H1 bulb.
Can't want to see how far a set of Rallye 4000 pencil beams with 55W HIDs can project.
FlatBlackIan wrote:Picking up some aux lights tonight. Finally time to build a light bar.
IanS
RallyB13 wrote:Enjoy 'em!
Bar is build, and lights are wired, but I may be doing HIDs sooner then I thought. The bulb in one of the pencils is burnt out. Im guessing the ride in the back of my truck had its way with it. I already have ballasts, hopefully I can find some HID bulbs locally. If not, halogens it will be.
Pictures are uploading.
IanS
Best idea ever.
So Cale and I were joking about shift knobs. Currently I had the plastic B&M that was in the coupe. So I was thinking of doing a small homage. Since Cale and I both put redbull back like water, it was only a short leap.
In the drifting world, everyone uses the big plastic dildo shift knobs. Well, an 8.3 oz can is about that size, lets see what we can do.
Punched a hole in the bottom of a full can.
Waste not.
Remove bottom.
Leftover fiberglass resin.
Voilà.
I can't wait to get the car out for some testing, to get a full idea of how well it will work.
MMMMM, HELLA.
Marking it out. Im running the 2 pencil beams in the middle, and the driving lamps on the outside.
Test fitting to make sure the hood will still open with the bar and lights on.
All the lights installed on the bar.
All mounted up.
Building the wiring harness.
For quick disconnects.
Like I said, one of the bulbs is burnt out, I will be fixing that today, look for lit pictures as early as tonight.
Im off to work on the exhaust.
King Ranzo
Car: 15 Ford Focus ST
Epic ish y0.
IanS
So bright.
Getting started on the exhaust.
Bung for the wideband.
Wideband Gauge installed.
Now I just need to get some bends done so I can finish the piping.
RallyB13
FlatBlackIan wrote:Like I said, one of the bulbs is burnt out, I will be fixing that today, look for lit pictures as early as tonight.
Argh. I must have grabbed a used bulb and stuck it in there. Sorry Ian.
It occurs to me that I have no need for H1 bulbs any longer as I'm going 100% HID, so email me your address and I'll send you my stash of six 130W H1 bulbs.
Hopefully it won't be too long before I can post pics of my setup. 2x Hella FF1000 Xenon driving lights (same as the ones Ian has on the outside, but with factory 35W HID), and 2x Hella Rallye 4000 pencil beams with 55W HID H1 conversion kits. (The FF1000 is a 7" light, the 4000 is a 9" light).
Ajax
Car: 1991 240sx SE
2010 Mazda 5
Don't know why I haven't gotten emails on these updates, the new format still appears to not like me.
Think you can get a pic of what the view looks like with the lights on? show what it would look like when driving toward a Cale sized object at 50 yards...
Razi
Car: Moo
Lmao @ Redbull shifter.
Those Hella lights look awesome!
