OEM Nissan / Infiniti parts
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
(jd)
Car: 03 Chevy Silverado
/\NISSAN
(jd)
.akai wrote:1990 240SX hatchback:
Driver and Passanger side power window handle things, where the buttons are to make the windows go up and down. I need those, the handle and the buttons. the windsheild washer stick. and the driver console with the cruise control, emergency lights buttons, I forgets its name. thanks.
Driver switch- 25401-F6600 - $132.97Passenger switch - 25411-F6600 $29.38Washer switch - 25260-44F00 $44.56Console - 68260-40F00 - $92.94cluster lid - 68260-53F00 - $69.22
Let me know if I got everything.
John
.akai
Car: Take a wild guess
(jd) wrote:Driver switch- 25401-F6600 - $132.97Passenger switch - 25411-F6600 $29.38Washer switch - 25260-44F00 $44.56Console - 68260-40F00 - $92.94cluster lid - 68260-53F00 - $69.22
John
$132?!?! why so much, its just the buttons for the power windows and the trim around it. And is the console the area that goes around the radio, a/c, gear shift, and ashtray?
(jd)
/\The buttons are part of the switch assembly.The cluster lid is the part that goes around the radio. The console is the part that goes around the shifter.
jdmfreak
Hey (jd) did you ever find out about the bracket?
SilviaSativa
Car: '93 240sx
I need more little stuff! Foam sealant for hood/hatch hingesand is there a rubber distributor gasket(between dist. cap and the dist)? Thanks!
(jd)
jdmfreak03 wrote:Hey (jd) did you ever find out about the bracket?
Sorry I never got the email I don't know whats wrong.
Here is the two illusstraitions that I have.
(jd)
SilviaSativa wrote:I need more little stuff! Foam sealant for hood/hatch hingesand is there a rubber distributor gasket(between dist. cap and the dist)?
Thanks!
Hood Seal - $16.42
Dist gasket - $4.74
Do you need the hatch weatherstrip to or the hatch hinges?
Let me know
John
jdmfreak
Thanks man. Ill show my father when he gets home.
(jd)
/\ No problem anytime :)
frapjap
'07 Subaru Legacy
Output flanges compatible with a 300zx diff, but with the 240sx bolt pattern?
(jd)
/\ Use flanges from an S14 vlsd they will work with the z31 vlsd diff.
LH 38220-52F01 $113.50RH 38220-92L00 $139.20
frapjap
'07 Subaru Legacy
THANKS! I just might be seeing you soon. How the shipping?
(jd)
Ballpark around $9.00 for ground UPS.
RiceBurner98sC
Thanks for the great service on the floormats John. Curious to know the price if possible on a S14 VLSD
(jd)
/\ $632.50 for the R200 assembly from motorsports.NISMO R-TUNE $721.17 OE LSD
They are both basically the same spec wise 70ft/lb breakaway touque with 30mm x 29 teeth side gears.
VA240
14052-21R00 AIV plug. I need two shipped to 23103.
Thanks!-VA240
(jd)
^Shoot me an email this weekend and I'll get you taken care of on Monday.
VA240
(jd) wrote:^Shoot me an email this weekend and I'll get you taken care of on Monday.
Email sent!
-VA240
RiceBurner98sC
(jd) wrote:/\ $632.50 for the R200 assembly from motorsports.NISMO R-TUNE $721.17 OE LSD
John thanks for the info...though I've been searching, do you know which of the Nismo units is a direct bolt on to the S14 non-lsd/non-abs 240's? I didnt want to have to change my flanges if possible, but I cant find accurate information as to which one bolts right in. Its a big decision in making sure I get the right one. I need it mainly for dragging.
Jookmasta
hey john, thanks for the super fast shipping for the starter and for the great customer service. id give ya another positive feedback had this been ebay. lol. also i sent back the starter so will i receive an email stating that the core charge is refunded or how is that done? also could i get a quote for some tan floormats for a 93 240sx se? also did nissan happen to make seat covers for the 93 240sx? and also i know this is a shot in the dark, but there werent any factory din 3 gauge holders for any 240sx was there?
(jd)
VA240 wrote:Email sent!
-VA240
Got them ordered for you I should have them in a couple days.
thank you:)
TrunkMonkey
Car: 2000 Lincoln Navigator
i have a 93 240sx convertible. i'm looking for prices for...
all the weatherstrippingwindshield garnish moldingcarpet (grey. interior only. trunk not needed)
-demetrius
msg
pricing for front and rear 5 lug hubs?
(jd)
Jookmasta wrote:hey john, thanks for the super fast shipping for the starter and for the great customer service. id give ya another positive feedback had this been ebay. lol. also i sent back the starter so will i receive an email stating that the core charge is refunded or how is that done? also could i get a quote for some tan floormats for a 93 240sx se? also did nissan happen to make seat covers for the 93 240sx? and also i know this is a shot in the dark, but there werent any factory din 3 gauge holders for any 240sx was there?
No problem glad I could help out. I'll email you when I get the starter core credited and mail the copies to you.
Tan floor mats $51.00Sorry no factory seat covers.The 240's only had two meters available factory, fuel and water temp. To the best of my knowledge anyway.
I'll be in touch as soon as I get the core back.
Thank you
John
(jd)
RiceBurner98sC wrote:John thanks for the info...though I've been searching, do you know which of the Nismo units is a direct bolt on to the S14 non-lsd/non-abs 240's? I didnt want to have to change my flanges if possible, but I cant find accurate information as to which one bolts right in. Its a big decision in making sure I get the right one. I need it mainly for dragging.
Still researching you're question on the direct bolt in lsd's.
VA240
John,
Can you get Canadian-spec S13 coupe b-pillars? These are for S13's with manual seatbelts. I'm looking for a brown set.
Thanks,-VA240
Jookmasta
so the floormats are in stock?
msg
o yah, by anychance can you get skyline parts as well?
(jd)
Jookmasta wrote:so the floormats are in stock?
No I would have to order the floormats for you, and BTW I got the starter core back today so I will get you a credit headed to you in the mail.
John
Return to “Advertisers' Marketplace!”
