OEM Nissan / Infiniti parts
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
(jd)
Car: 03 Chevy Silverado
Yep you bet we are still 25% off.
The breakdown is FAN BLADE 56.47CLUTCH 152.96PUMP 58.75FREIGHT 7.50
TOTAL 275.68
I have all of this in stock and ready to ship if you need it.
Let me know.
John
parker
not exactly sure what they're called.but i need the sills on the doors (shiny metal) for a 240SX fastback.shipping to 07205 thanks!
(jd)
/\What year 240?
discusfa
How much is 1998 240sx LE manual cluth pedal assembly.can i just replace the pedal instead of whole assembly
(jd)
discusfa wrote:How much is 1998 240sx LE manual cluth pedal assembly.can i just replace the pedal instead of whole assembly
The assembly is $29.27 the only other servicealbe parts are bushings and the pad itself.
John
dr!ft
Car: 1988 Isuzu Trooper II, wish it was a 240...
How much for a S13 SE rear spoiler (coupe)? And if it cost extra, how much for the 3rd brakelight? (the one inside the spoiler) Thanks...
Wai_Pang2
i need the sunroof glass and i dont know if it is just the glass or glass with stripe. also, i need the defroster vent covers near the windshield, dont know the name of it. but its a one piece and i guess its called a defroster vent cover. had no illustration or pics of it. and does anyone here know where a good place to look for carpets.
Tsukai240
i need a quote on power steering lines for a 91 240 w/hicasthanks john
(jd)
dr!ft wrote:How much for a S13 SE rear spoiler (coupe)? And if it cost extra, how much for the 3rd brakelight? (the one inside the spoiler) Thanks...
The spoiler is $253.93The lamp in the spoiler is $90.17
I would have to order them for you let me know.
John
(jd)
Wai_Pang2 wrote:i need the sunroof glass and i dont know if it is just the glass or glass with stripe. also, i need the defroster vent covers near the windshield, dont know the name of it. but its a one piece and i guess its called a defroster vent cover. had no illustration or pics of it. and does anyone here know where a good place to look for carpets.
Let me know what year and model you have.
Thx
John
(jd)
Tsukai240 wrote:i need a quote on power steering lines for a 91 240 w/hicasthanks john
I'm attatching a pic let me know what numbers you need.
Thank you
andrave
Car: 1989 Nissan 240SX Coupe
Hey I have a rare car, 1990 Infiniti M30, having trouble finding some parts. I'm actually getting ready to order a speedo cable and a door jamb switch from your website, but I also need the driver's side front turn signal and the driver's side front mudflap from the wheelwell. They aren't listed on your site but I'm sure you could look them up. I don't know if you sell them, but my car is also missing the trim around the radio as well.Thanks
Wai_Pang2
john, its a 90 240sx coupe. it doesn't say if it is a se or what.
sleepyRPS13
Car: to sleep
i tried looking for it on the catalog but cant find it, its a rubber bushing allows the hood to seat properly (just on top of the headlights, on the side to the front fender).its for a 89 240sx.
can you quote me on that,pls
thanks
Tsukai240
Thank you
i cant tell what the # is but i need the one to the lower right of the p/s pump in the picture. (does that make sence?) i think its 49722n, if it is all one piece.
(jd)
andrave wrote:Hey I have a rare car, 1990 Infiniti M30, having trouble finding some parts. I'm actually getting ready to order a speedo cable and a door jamb switch from your website, but I also need the driver's side front turn signal and the driver's side front mudflap from the wheelwell. They aren't listed on your site but I'm sure you could look them up. I don't know if you sell them, but my car is also missing the trim around the radio as well.Thanks
Ok here are part numbers and prices for you.Speedo cable 25050-F6600 $44.87Door jamb switch 25360-41L01 $5.03LH Front T/signal 26135-F6625 $29.79The mudflap is color coded I can get the code from your vin $66.81Radio trim 68260-F6620 $62.68
I would have to special order these for you.
Let me know
John
(jd)
The sunroof w/weatherstrip is 91210-35F20 $369.50The defroster vents come in LH and RH they are color coded they are $19.18 each.
John
(jd)
sleepyRPS13 wrote:i tried looking for it on the catalog but cant find it, its a rubber bushing allows the hood to seat properly (just on top of the headlights, on the side to the front fender).its for a 89 240sx.
thanks
The bumpers are 62840-D0100 $4.09 each I have them in stock.
John
(jd)
49722N is part number 49720-53F10 $76.81 I would have to special order this for you.
Let me know
Thankyou
John
Tsukai240
i
Let me know
Thankyou
John
i hope that is it. how much shiped to 77006what is this part?
http://www.trademotion.com/par...gid=1
i have a bad idle problem (its way to high, 1800). will this fix it?
(jd)
Tsukai240 wrote:i
$7.25 freight for the hose kit.
i have a bad idle problem (its way to high, 1800). will this fix it?[/QUOTE]
Yeah thats an idle solenoid but it may just need to be cleaned. Check with nistech about that I really don't know much about idle problems.
John
Tsukai240
Thank you
i know what i need for sureits that 2nd hose from the bottom right of the pump in the picture. it a lil shorter than the other one and it has an electrical conector on the end.
jdmfreak
(jd) wrote:
Let me know on the exhaust section there is an intermediate, muffler, and tip. I'll just quote you on them all.Intermediate - $187.49Muffler - $187.49Tip - $21.58Spark plugs $8.25 eachFrt Struts - $67.49 eachUpper Rad hose - $12.07Lwr Rad hose - $12.07Htr Hose Inlet - $12.07Htr Hose Outlet - $25.87Htr Hose Bypass to core - $8.36Corner lamp $47.68 (this is the lamp next to the headlamp) If you needed the one in the bumper let me know.
John
Hey man! Remember me? Well now Im ready.
Sooooooo.....How do I go about cppntacting YOU for the order?
Jookmasta
hey john, could ya give me a quote for a timing chain kit for my 93 240sx. [email protected] thanks.
Return to “Advertisers' Marketplace!”
