OEM Nissan / Infiniti parts
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
jdmfreak
Oh and thanks.
180crafter
Car: Nissan 240sx
Woah man... U r working like a machine.
Well, Im looking for the 5 lug hubs off a N/A 300zx. I need to get the remaining pieces for my 5 lug swap. Im also interested in replacing all of the ****ty rubber moulding around the doors and windows. I also missed where you found the pricing for the front mats. I need the little hook thing and all the clips that go along with it.
BTW, my car is a s13 FSTBAK and the interior is grey. Thanks
(jd)
Car: 03 Chevy Silverado
Jookmasta wrote:so everything would only cost 3.95 to ship? get back to me [email protected]
thanks
Email Sent:)
(jd)
cf1203 wrote:can you give me a price for a set of rings and rod bearings for a 93 sentra se-r including shipping. im not sure if you can get the synchronizers for the sr20det transmission, but if you can a price on them.
Ring set - $76.71Rod Bearings (depending on grade I'll ballpark this price) $4.85 each need qty 8
I don't have a listing for synchs on that transmission.
John
(jd)
jdmfreak03 wrote:Yea sorry I maent the one in the bumper.
$15.22 :)
(jd)
180crafter wrote:Woah man... U r working like a machine.
Floormats - $56.25Hubs $126.25 each (Z32)Door outer Sealing Strip LH - $114.68Door outer Sealing Strip RH - $103.89Door to frame seal - L & R - $55.05 eachWindow to roof mldg - L & R - $54.49 each
Let me know if I missed anything
John:cool:
jdmfreak
Dose the light come with the brackets too cuz they're broken. If not, then how much for them?
marshun
how much is a coolant resovoir for a 93 240sx?
i fiber glassed mine to hold water, but its weird with fiberglass on it and it bothers me :P
wangless
Car: '02 MBP WRX
i used cut up pieces of a clear milk carton and a blow torch to fix mine :D
(jd)
marshun wrote:how much is a coolant resovoir for a 93 240sx?
$68.29 21721-35F01
jdmfreak
N.O. Accorderz
is there a clutch "kit" for the 240sx? if not i need all the parts to change my clutch/pressure plate/t.o. bearing...this is all for a 1993 240sx 5spd
(jd)
/\ Yes there is a clutch kit 30001-Y06S1NW you're price is $93.74I don't have it in stock but can get it for you.
John
(jd)
jdmfreak03 wrote:Dose the light come with the brackets too cuz they're broken. If not, then how much for them?
Send me an email, I'm not sure which bracket you need, I can send you an illusstration.Thank you
John
[email protected]
jdmfreak
I sent you the email. Lte me know if you got it or not.
Oh and I forgot to ask you how much the rear struts are.
(jd)
jdmfreak03 wrote:I sent you the email. Lte me know if you got it or not.
I didn't get the email sorry about that.
The rear struts are $56.19 each
Go ahead and send that email again.
Thank you
John
Shorty65
Can you get a 97-98 S14 JDM Front Grille (regardsless even if the 25% doesn't apply). If so, how much and how long will you be doing this?
jdmfreak
Thanks I just sent another one with the make and model. Just in case it didnt go through again, its a 95 Maxima GXE.
RiceBurner98sC
Floor Mats...Nissan 240sx 1996 Black on Grey Cloth Interior. Front and back...of course.
.akai
Car: Take a wild guess
1990 240SX hatchback:
Driver and Passanger side power window handle things, where the buttons are to make the windows go up and down. I need those, the handle and the buttons. the windsheild washer stick. and the driver console with the cruise control, emergency lights buttons, I forgets its name. thanks.
SilviaSativa
Car: '93 240sx
I need:-(2) front strut gaskets-(6) front upper strut nuts(that bolt into Strut mounting insluator.)-(4) front lower nuts(that bolt into shock absorber.) -(2) rear strut gaskets-(4) rear upper nuts-(2) rear lower nuts (that bolt into shock absorber.)-(1) rear hub bolt
All for S13 DOHC...
THANKS!!!
jdmfreak
You forgot the last part.
SilviaSativa
Car: '93 240sx
Haha, I started hitting the wrong keys :confused:
nab911
Car: 93 Nissan 240SX SE
How much is it for a ka24e clutch kit shipped (acworth,ga 30101) and you guys have any specials like a free hat or anything :) caus i gotta buy one and im trying to find a deal. Thanks!
(jd)
RiceBurner98sC wrote:Floor Mats...Nissan 240sx 1996 Black on Grey Cloth Interior. Front and back...of course.
Floor mats 999E2-4E000GR $56.25
John
(jd)
.akai wrote:1990 240SX hatchback:
You couldn't by chance send me you're vin number in an email or post it here could you? Just want to make sure you get quoted with the right numbers and prices.Let me know
Thank you
John
(jd)
SilviaSativa wrote:I need:-(2) front strut gaskets-(6) front upper strut nuts(that bolt into Strut mounting insluator.)-(4) front lower nuts(that bolt into shock absorber.) -(2) rear strut gaskets-(4) rear upper nuts-(2) rear lower nuts (that bolt into shock absorber.)-(1) rear hub bolt
All for S13 DOHC...
THANKS!!!
-(2) front strut gaskets $5.47 EACH
-(6) front upper strut nuts(that bolt into Strut mounting insluator.) $.64 EACH NEED 6
-(4) front lower nuts(that bolt into shock absorber.) $1.86 EACH NEED 2
-(2) rear strut gaskets $9.04 EACH NEED 2
-(4) rear upper nuts $.55 EACH NEED 4
-(2) rear lower nuts (that bolt into shock absorber.) $.30 EACH NEED 2
-(1) rear hub bolt $1.45 EACH
John
nab911
clutch!! :)
(jd)
nab911 wrote:How much is it for a ka24e clutch kit shipped (acworth,ga 30101) and you guys have any specials like a free hat or anything :) caus i gotta buy one and im trying to find a deal. Thanks!
Clutch Kit - $93.74 FREIGHT $9.25
Don't have any specials going on at the moment I need to see the boss and find out tho.
John
nab911
Find out, also what "brand" because some oem's are of different brands otherwise i can just ebay it.
Return to “Advertisers' Marketplace!”
