supreamS14 wrote:Did you hit them with an impact wrench or a breaker bar? Are you keeping the stock exhaust? If not is there any way you could you cut it off? I took my whole exhaust off by un hooking the o2 sensor's , grounds , mount to the tranny and the rubber hangers. If you are planing on keeping it you might want to consider something a little more free flowing before you drop the sr in. Turbo's love turbo back exhaust's! Its an eazy way to gain 15-30whp!
Have some extra money for belts, plugs, z32 fuel filter, gear oil for the tranny, coolent, oil and extra oil and filters so you can change the oil after running it. I changed mine after 150 miles then after 600 miles. Also some simple things you can change with the motor out are front and rear main oil seal's, water pump, clutch and rear tranny seal. Check the bottom of your oil pan for dents(Very bad)! Also a good thing to have is an oil pressure gauge and a boost gauge. I suggest to not mount them on your a piller. Thats how I have mine mounted and rice lookin cars are like donuts to cops here in the USA. I love the sleeper look. I would de-rice my car but It's gonna be a track only car after my baby is born in 3 months! I'm gonna need something some thing bigger and safer for my family.
What will you be using this car for?
Thanks for the advice! Im going to run out right away and pick up a breaker bar as I dont actually own one. Hopefully that will get me somewhere. At first I was thinking of keeping the stock cat-back for now and then eventually replacing it but now I think since im down there im just going to get it done and do the whole deal. The only thing holding the whole exhaust on now is the two rubber hangers in the middle of the exhaust and the two at the back but none of the bolts will budge. Is cutting the rubber going to make life miserable for me to replace it? Ill see where the breaker bar takes me but I know it wont fit in the back where you have to reach above the muffler unless its easier to just take the pins and slide them out some how?
As for the rest of the setup, I am working on a somewhat limited budget for now as I am going through university right now and have to fork over a bit of money for that :P. However I will consider some of the things you have mentioned. I imagine changing the clutch is much easier with the engine/tranny out of the car, but is it going to be too much of a pain if I leave it for a while and just get it up and running first?
The car will be used primarily for daily summer driving as up here where I live we get a solid few feet of snow and -30 C degree temps in the winter. Other than maybe taking it to the strip once or twice I have no track or autocross or what have you plans as of now (don't actually know of any around here) but I would like to just get it running as a daily driver first with a little bit of minor mods for added fun. Next year will be suspension work.
