first off, congrats. always like to see someone taking matters into their owm hands when doing something like this. as many times as ive had someone ask me wher i got my motor swap done, i never get tired of saying "i did it myself".
a few posts back when ur turbo went out, u mentioned u had ur wastegate actuator hooked up to a vacuum source. vacuum is not good for an actuator. surprised nobody on here caught that. u need to get it hooked up to a boost only source, something with no vacuum. this needs to be before the throttle body.this is what i used for my car. tap this fitting into the silicone hose coupler that connects ur turbo to the intercooler pipe and walla!!!
http://www.frsport.com/Turbo-Q....html
i wish i knew about frsport when i did this though, i spent almost 30 bucks on that same thing through option imports. not dogging them though as they are still a good site to order from.
anyways, for your intercooler piping, i would recomend u getting rid of those puny little clamps and get some solid t-clamps. it will help significantly to prevent ur intercooler piping from poping off again. something like this. they are kinda spendy but they are worth it.
http://www.qualitycustomparts.....html
good choice on fans, they are spendy but they work real good. i have the same ones. i used to use their thermostat but after a while i just hooked it up with a switch and i leave them on all the time. that works good for me though cause i live in cali and it is always hot and with stop and go traffic.
anyways, thought id add my 2 cents and good luck
