maxima278 wrote:I have that article. That's a good looking S14 too I keep coming to the same conclusion every time I start trying to figure out the cheapest route, and it seems like there's not one. Obviously, the RB's are going to be the most expensive especially to maintain, but the aftermarket is wide open for the SR and KA, and the pros and cons seem equal when you listen to people who are biased either way. The most important thing to research is how not to blow your motor. I don't have the article in front of me but wasn't that guy getting those results with only about 7 psi of boost???
I saw a guy dyno a SR at the meet and he posted about 260 hp at an ungodly 26 pounds of boost, so 5 bucks says he blows his motor soon
Yeah the guy was running between 8-10 psi. That's a safe realm when you're using a crude engine management system. You can always turn the wick up later when funds are available.
ONLY 260 hp @ 26 psi? He must have been using the stock turbo . I agree that he will be searching the NICO Classifieds for a donor motor soon.
Well maxima278 you said that you have another motor laying around right? IDK what you're running now, but you can build your other one up gradually and then you can keep your options open. If you ever come to terms with the KA-T option, you'll already have a beast ready to go
