maxima278 »
https://forums.nicoclub.com/maxima278-u20438.html
Thu Mar 16, 2006 6:04 pm
the hardest part, I think will be bolting up the transmission. Everything else is self explanitory. I changed out the engine AND transmission as a unit in mine so I don't have any experience with bolting and unbolting trannys. The hole for the master cylinder is punched through one side of the firewall so all you have to do is drill it the rest of the way out. Then, you go to your fuse box and you have to rig the clutch relay so it will start. It only costs as much as the parts. I saw in modified where they just used a drimmell tool and cut the brake pedal on both sides so it was smaller, then they just put a custom pedal set over top of all the pedals. Sure beats changing them out like I did. Pain in the ***!
What's the worst that could happen? So you have to take it to a mechanic or get a mechanics help to finish it.
I just realized something, if you are going with an rb swap later, this is a waste. just get your paint and window tint, then when you do the rb swap, all you need is the clutch master cylinder, hard line, slave cylinder, pedal. Most of which you can get at the dealer pretty cheap I think. But if you get a really good deal on the transmission and swap stuff, then who cares? You can sell it when you get the RB. Just stuff to think about.
