elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Tue Nov 13, 2012 2:47 pm
So basically what you've done is leaned out the mixture by going to smaller injectors (270cc vs 370cc), and advanced the timing. Effectively you've done the same thing that an ECU tune gives you. You might have gained 30HP by doing this. The "cold air intake" and exhaust have probably netted you nothing, but just for grins I'll say that gained you 10HP combined. Going to the iridium plugs is probably a level move, although you did move to a colder range than stock which would help now that you're running a little leaner.
We know that you can gain about 40HP N/A with a proper tune. So, assuming the VH comes with 300HP crank from the factory (not an unreasonable assumption), 340HP is about the max you can do on an otherwise stock engine. It's well known that "cold air intakes", regardless of your setup, will not gain you anything but more dirty air in the engine. You can get secondary and tertiary effects of a "cold air intake" by fouling the MAF and causing it to run leaner than it's supposed to, but that's not from the cold air intake doing what it's supposed to be doing.
400HP N/A on a VH45 is only achievable with higher compression, modified camshafts, or both. Basic thermodynamics tells you the easiest way to increase an engine's thermal efficiency is by increasing the compression ratio.
BTW, it's easy to smoke cheap or bald tires, making the car seem way faster than it actually is.
I have taken my Q basically to the limits that you can take a N/A Q to, which is a full exhaust with no cats, "headers", tuned ECU, 5-speed manual, and it's not doing a 13.5 in the 1/4 mile. I can tell you it's not putting out 400HP, maybe 340-350, but not 400.
14.9 in the 1/4 mile for what you've done is believable. 13.5 is not. If you think it is, go to the quarter mile and line up against basically any stock G37, FX50, CTS-V, 370Z, or newer mustang GT. All of those cars do low to mid 13s. If you beat one of those cars in a fair 1/4 mile race from a stop, I'll eat my words. Recently, I had both my Q and a stock 2005 CTS-V. The Q and the V are basically the same weight, but the V has 400HP and a 6 speed manual, compared to the 5-speed manual in my Q. The V is way faster than my Q, and my Q is basically modified to the limit of what you can do with an otherwise stock VH45. My Q is probably putting out about 340HP with what I have done to it. I haven't done a 1/4 mile in my Q, but that would be interesting to see.
You could have avoided all that hassle and installed one of my ECUs for the same or better result.
