damn dude nice avatar, and its part of the pcv system kinda like a crossover tube!Steve Lloyd wrote:What's that port on the back of the valley for?? the one by the engine stand??
as far as the undercoat goes, i used two different kinds, on the diff i used some heavy duty stuff in a rattle can that i got at o'reilly's, then the subframe i used some stuff that i got at work! (nissan dealer) if you know anyone that is a tech they use it to protect the fuel sending units when they do the recalls on older frontiers and xterra's! has some special part # and is only used for those recalls! but it's some pretty amazing sh&# and its pretty expensive also! if i get a chance monday ill ask the parts guys for the part # and post it up! the stuff from oreilly's wasn't near as good quality wise but was alot thicker and rugged!slipnfall wrote:Sorry for the misfortune on the engine BTW.
I'm am curious to know what type of 'undercoat' you used - out of a rattle can I presume? Have you had past exp. with it?
Jamie
i see the check valve but if memory serves me right that is a bypass valve that is only there to bypass the filter if there is a restriction, kind of a safety so you dont starve the motor of oil when smart people drive millions of miles on oil changes. i'm not a 100% on that but what you say could be correct also i'll have to do some more research and if that's the case then i'll have to get creative with designing it!Carl H wrote:just remember with the adaptor plate to design in a check valve...the filter tree on the stock vh has the check valve for drain back unlike the sr where the valve is located in the block.
efeezie you have mail again those ignitors are the wrong ones just lmk if you have a different style! thanksefeezie wrote:Email me at [email protected] Ive got more than a few ignitors.
