my vh s14 project!
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
newbissan-tech
Car: 96 vh45 swapped 240sx SOLD, 2011 frontier pro4x SOLD, 08' Altima SOLD, 2006 TITAN, 2012 SUBURBAN FOR THE FAM.
yeah my brother put it on a cnc lathe, then duplicated the id and depth from one to the other, the splines are identical its just the opening behind the splines (pump shaft o.d. + .oo3-5" i think) where the pump shaft slides into the pulley!
Modified by newbissan-tech at 2:47 PM 9/30/2009
newbissan-tech
so here's some pics of the stitch welding, some is good and some not so good! and here is some pics of a small rust spot i found and ground out and patched! and thats it for tonight!
newbissan-tech
ok so i worked my but off sunday afternoon and cleaned out the garage and managed to get the motor dropped in for a test fit! it's a tight fit but with a little massaging here and there she dropped right in! I just followed the instructions on the mazworx install kit. every thing came together really smooth, although i might have to trim the shifter hole a tad bit more. looks pretty good. here's some pics and some more pics of the wheels and rear bumper test fitted! currently in dallas at the nissan training center so wont have any updates till this coming weekend!
newbissan-tech
just an fyi and because i didn't read properly the z32 inner tierods ar alot stronger than stock but DO NOT work with stock outer tierods! so for future reference they only work with longer after market outers like the spl's so now i have a new set of oem outer tierods if someone needs them the spl's should be here in the next day or so!
garcia240
Car: 240s duh
Oh hooch.... your car is looking ticked
newbissan-tech
ok so i yanked the plenum swapping throttle bodies and eliminating some emissions vacume lines and pics of the front coilovers and suspension parts!
CrazyTrance
Car: 1991 Nissan 240sx - vh45de
Needs to be WAYY lower
kingkilburn
Car: '93 240SX
This isn't Zilvia now is it?
j/k
tmorgan4
Car: 2000 Nissan Pathfinder
Looks good! I've gotten rid of every line under the plenum and it's sooo much nicer to work on and still ran great.
newbissan-tech
yeah i think it will be alot easier also, just at a glance it looks like the only thing that i have to keep is the iacv hoses and the vacuum supply to the fpr's! an trust me this beast will go lower once i get it on the ground! ive been slacking lately, really busy with work, family and community svc! yes community service! damn speeding ticket from 2 yrs ago! it sucks but gotta keep the points off of my record!
newbissan-tech
oh and here's some pics of my spl outer tirerods and some clearance issues no biggie though just a mock up at this point!
SuperHatch
Car: 96 TLC
newbissan-tech wrote:yeah i think it will be alot easier also, just at a glance it looks like the only thing that i have to keep is the iacv hoses and the vacuum supply to the fpr's! an trust me this beast will go lower once i get it on the ground! ive been slacking lately, really busy with work, family and community svc! yes community service! damn speeding ticket from 2 yrs ago! it sucks but gotta keep the points off of my record!
Just as an FYI, you can bypass the IACV all together as well. These motors idle quite well without them.
Also, only the FPR goes to Vacuum, the damper actually goes to atmosphere (post MAF pre TB) according to the FSM. The FPR is on the same side of the engine as the TB, and there is a convenient vacuum port on the back of the manifold to connect it to. The damper is on the other side and I just leave it connected to nothing rather than plumbing it into the intake tube.
gs14racer
agreed on the iacv, idles fine without out it, i removed everything off of the intake manifold. Removing the plenum for me now takes 10 minutes.
Wonder what would happen if you removed the fuel pressure dampner all together.
Mettler
Car: HR31 GTS-8 coupe, VH41/45 Hybrid Transplant
Can injectors get damaged in any way from fluctuations or excessive fuel pressure?
gs14racer
i would imagine the coils could be damaged possibly, im running mine at 60 psi at teh rail right now, and all is well .... so far
newbissan-tech
good talk guys and thanks for the info (steve and jerry). thanks again
1WheelWonder
Keep up the good work!
SuperHatch
Car: 96 TLC
Mettler wrote:Can injectors get damaged in any way from fluctuations or excessive fuel pressure?
All injectors? No, because I can think of plenty of cars that don't have dampers and their injectors last just fine.
These injectors? I would still say no, but I'm not an expert. Anyone know if Scoobys have dampers?
From what I understand, the damper's purpose is to smooth out the rail pressure that can sometimes be viewed as a sine wave due to the pumping action of the fuel pump.
gs14racer
lol steve, i just went out and checked and aparently i removed mine when i did the swap last this past year.
SuperHatch
Car: 96 TLC
gs14racer wrote:lol steve, i just went out and checked and aparently i removed mine when i did the swap last this past year.
Well that takes care of that question...
newbissan-tech
definitely gonna do away with some of this stuff, but i think im gonna keep the iacv for now. with the crazy temps we get in the midwest it can reach over 100 degrees in the summer and below 0 in the winters so i want to have a little bit of driveability!
justinedible4
Car: 1990 Honda Accord, 1991 S13 HB
WOW! I read through your whole build and man is your work beautiful! Would i be possible to run ITB's?This car is going to be insane when done. Im hoping after college to do this swap into an S13.
newbissan-tech
hey man thanks alot for your comments and i am hoping to have itb's in the future, but as for now the budget is lacking a bit. i've still got so much to do just to get it road ready. at this point im just wanting to get it going! thanks again
Carl H
looking good man, sorry i didnt respond to your text a few weeks back but i woke up at like 3am saw it and rolled back into bed.
newbissan-tech
yeah i tend to forget that your in a different time zone! sorry bout that
swade
Car: !990 TSI AWD
Any new updates?
newbissan-tech
update indeed! so i've been quite lazy since the weather has gotten colder, but i finally got the urge to build my lower harness, here's some progress pics and the finished product! and the last one is the before pic of the harness that's all for this evening.
Modified by newbissan-tech at 11:40 PM 12/6/2009
XJared
Car: 06 Titan, 83 Z, 10 Z
Nice job on the harness, looks oe Nissan.
swade
Car: !990 TSI AWD
Time to do a DSM harness... :D
swade
swade
Car: !990 TSI AWD
Bump for any updates?
Return to “VH45DE / VK45DE / VK56DE Forum”
