kevwa »
https://forums.nicoclub.com/kevwa-u75921.html
Sat Aug 16, 2008 3:22 am
well i know its been a while since i have updated this but i have been busy with work and i moved -
anyway here is the latest - i'll admit i was a little too excited to get the truck running and was short on money so i didnt initially do any gaskets, which kicked me later... i ended up having a small leak in the head gasket on the back of the motor by the auxiliary head bolt - so i replaced the head gasket and while i had the head off i did ARP head studs, intake manifold gaskets, throttle body gasket, new exhaust manifold gasket and studs, and my timing belt, idler pulley and tensioner pulley which were on back order for about 6 weeks also showed up. oh and i also got a nismo fuel pressure regulator since the stock one was stuck running max rich - so finally with all that installed i have a running RB25DET in my S10!
i still have a few little isuses though - 2 days ago was the first time i actually drove it since all the new parts went on - it was breaking up just after it builds a little boost ( no boost gauge yet so im not sure what psi) it felt to me like it was blowing the spark out so i re-gapped my plugs to .8 which helped alot, however it still seems to break up a little at higher rpms and it feels like something is holding it back from making the power it should be - anyway i will be messing with it all day today so hopefully i will get it all sorted out
i def need to get the OBDI connector for it so i can hook up a scan tool and see what its doing
i will try to get some more pictures up soon and hopefully some more updates
