Magnum375 Jr. »
https://forums.nicoclub.com/magnum375-jr-u135673.html
Sun Jan 17, 2010 8:10 pm
Ok, So today was pretty freaking awesome. Woke up at 8, and sold some drag radials to a guy that drove 3 hours to pick them up. Then jumped right into disassembling the old junky piping. Its up for sale, but seriously, you will know now, I would not tell anyone to run this setup, ever. If you need an IC and stuff just for mock up or something, this would be ideal for that, but a better setup would be needed. Here you can see what it looked like before.
So, I began unbolting the various clamps and removing junk, and I find that this IC piping has become a mini catch can, holding at least 5-6 teaspoons of oil.
So after fulling fishing everything out, I snapped a pic with it all outta the bay, looks so good now, no massively crappy piping.
So, heres the s*** pile.
So, waking up the guys before 11 is damn near impossible, I had an hour and a half to spare, and figured, why not refinish my pignose. So, I wet sanded and spray painted the bumper. I only have a pic of it wetsanded, not painted.
So, fast foward to everyone showing up and beginning to work on the car.
So, I stopped taking pics at this point, and Doug has quite a few, and only uploaded a select few, so not much more of the install itself, but I'll post what I got to work with.
This kit required some cutting, we originally expected minimal cutting, WRONG, extensive cutting was required. The endtanks dont sit in without cutting, and we had to bring down the harness below and along the bottom of the radiator, so the IC mounts up. So I let Keegan figure out how we should go about cutting and he just took over and did a good job.
Here is what he eventually cut out on both sides, doesnt look like much, but it is quite a bit.
This was the first mock up, where Keegan setup the piping and let it hold the IC, while we tried to figure out how we wanted to bolt it in, little fabrication was needed.
So here we are, all standing around while Keegan keeps working....LOL.
The hard part was keeping the headlights UP. This kit required the removal of the headlight motors, and some of the headlight supports. Soooooo, they wiggled like crazy after we had to cut some of the flimsy metal away to allow room for the endtanks. Zipties, as you will notice, keep it from bumping up and down, and boy, are they tight, they wiggle less then stock fitment. Keegan did the passanger side, and I did the driverside.
Here I am doing the driverside headlight.
So We needed more cutting wheels, so Keegan did the running for that too, He's such a great guy. So we all stood out and Doug snapped this pic too., just to prove the badassery that we do out here in PA in January.
So when all said and done, here is final fitment.
Now, I also had acquired a chuki front bumper support, which I can now use with this High mount kit. We cut the foam to fit around the triangular lips on the edge. It definately tightened up the front end a bit, and really snugged up the front bumper. I love the fitment, which I have a few pics of, but only in the dark and rain. But here are my thoughts on the kit.
MAD BOOST RESPONSE!!!!! With the old piping I had found a 2 inch gash in the toilet plumbing coming off the turbo to the hotpipe. So I had a huge boost leak, and I would top out at 11psi. With this kit, I'm on stock t25, and It bounces off 15psi easy. So I cant really push it to its limits yet. I am happy to report, no damage to the turbo so far, after logging quite a few miles and did a few 4 and 5 gear pulls, she is wayyyyyyyyyyyyyyyy faster. And will be even faster with a newly rebuilt turbo. The surge is not as bad as people make it out to be. The car loves it, and I have to feather it through 1st, 2nd, and 3rd in the wet now....Never would break loose in the wet in third before. Tom was with me when I wailed on it in first and second, just feathering the throttle looking for traction....noppeeeee. LOL, love this kit. Someone is gunna be dumb and ask why it covers the rad, I actually run cooler temps with this setup because it doesnt have the Front mount blocking the rad,which means I now have more moving air coming from the lower openings on the pig, and smacking into the rad and then up onto the intercooler. Love everything about this kit. So here a few pics, I'll keep updating with info on my turbo setup, I'm going to try to readjust the boost controller, if not, im putting it back to stock settings, with a piece of vacuum tubing.
Thanks for reading, I know I prolly skipped alot of details, but I'm on 4 hours of sleep and after all the adrenaline and excitement, I'm just plain wiped out.
Modified by Magnum375 Jr. at 10:16 PM 1/17/2010
Modified by Magnum375 Jr. at 10:54 PM 1/17/2010
