hahaha spanish, it is real, garret part #714568, i just didnt feel i needed to pay $1400+ on the same turbo with a few meaningless holes drilled in it and and garrett cast into the side $900 shipped i couldnt pass it up, only a .63 t3 single scroll but i kinda wanna see what she can do compared to all these other combos that are comin out now for the 35r, when i bought this there werent too many choices to choose fromspanishricer wrote:IT'S NOT REAL!
I know, I was just giving you a hard time.Beemen550 wrote:hahaha spanish, it is real, garret part #714568, i just didnt feel i needed to pay $1400+ on the same turbo with a few meaningless holes drilled in it and and garrett cast into the side $900 shipped i couldnt pass it up, only a .63 t3 single scroll
Mike,thoughtless wrote:so i was reading your thread. i would love to have the money for all of this, but one thing i didnt see is what youre doing so the rear-end will hold 500+rwhp.
might i suggest, and i hope i dont get chastised, but Ford has a 9inch rear end. its solid axle and would handle all the torque you could ever deliver from the sr20.
good luck with the rest of your build.-mike
If the trans doesn't go, the axles will go...spanishricer wrote:
Mike,
The 240sx rear end will have no problem holding 500whp. It's usually the transmission that goes first.
R230 like the tt z32 diff is the mack daddy rear end swap for 240 anyways, but like spanish said the r200 is finethoughtless wrote:might i suggest, and i hope i dont get chastised, but Ford has a 9inch rear end. its solid axle and would handle all the torque you could ever deliver from the sr20.
I honestly can't think of a single 240sx with 500whp that had problems breaking the stock axles over and over again?jr_ss wrote:
Let me rephrase that... If you plan on dragging the car at all and are running sticky tires, dumping the clutch is going to break something... Hell running a 2-step and launching the car under boost is going to twist the stock axles out from underneath the car(with sticky tires). It may not happen the first time or the tenth time, but it is going to happen. Either that happens or the trans blows apart... I think Kentuckyslider? destroyed his 2nd gear in his trans with just 370rwhp and sticky tires. Now rolling on to the power or driving on the highway or street, then no, I don't see it happening. But when/if you drag the car, and you hook, something is going to give regaurdless...spanishricer wrote:
I do recall this one fellow broke his stock axle three times in the exact same place...but then he swapped out his SPEC stage 5 clutch for something with easier engagement and never had the problem again.
stock sr throttle body is 60mmgixxerbob wrote:
the outside dimension and external physical size of the throttle bodies are similar, i think the s14sr throttle body is 50mm and the ka is considerably larger, i searched but couldnt find any info on the ka throttle body swap or wiring to a sr20, any ideas so i dont have to weld a flange and overkill with a q45tb but dont have the smallest sr throttle body ever made
same here z32 transmission will be coming whne mine goesSolow240sx wrote:Yes, i no stuff will brake, but whats the fun if it doesn't=).. I have a backup KA transmission, and a extra set of stock axles, i will be happy if the trans just holds up for the summer so next winter i can do the z32 transmission swap, im not near as worried about the rear as i am the transmission i no the sr transmission has a week 2nd gear with sticky tires..
Considered trying to track down an S14 SR20DE throttle body? It's 60mm and bolts right on.gixxerbob wrote:the s13 throttle body is 60mm, the s14sr is 50mm i believe, i have to figure out how to wire the ka s14 throttle body tps to a s14sr harness since it is bigger and bolts perfectly.
spanishricer wrote:I have one... No you can't have it... It's actually 65mm at the opening and tapers down to 60mm at the TB plate.gixxerbob wrote:the s13 throttle body is 60mm, the s14sr is 50mm i believe, i have to figure out how to wire the ka s14 throttle body tps to a s14sr harness since it is bigger and bolts perfectly.[/QUOTE
