I know what you mean but IF the aluminum tray that Tollboothwilley is designing is similar to the pix on the G35 (above)t hen you wont need that plastic lip.IlyaKol wrote:The lip I am talking about is the one you can see in this picture, it is most visible in the middle of the bumper at the bottom. It goes down a bit, but doesn't stick out from in front.
As the front of the car slows down the air without a diffuser, this is the ideal place for an inlet. A splitter is commonly used here, serving to increase the amount of downforce at the front of the car. The airstream is brought to stagnation above the splitter by an air dam, causing an area of high pressure. Below the splitter, the air is redirected away from the stagnation zone and is accelerated, causing the pressure to drop. This, combined with the high pressure over the splitter, creates downforce. The larger the area of the splitter, the more downforce is generated.
That's good news, than Enigma!EniGmA1987 wrote:The plate does not stick out like that, the one that that picture Wangtang posted is a different product.
This is the same width as the original - Mike just doesn't have his stock wheel well liners on. The slots are there for VENTING air - can easily be removed if thats what people prefer.TDot wrote:Doesn't the original go across the entire bottom, why doesn't this? And why are there slots and holes in it; won't that build up grime on the inside?
Stock tray doesn't have an oil doorvasekvi wrote:Ok I got my car on my friends lift while I was consulting with him over exhaust options.
I don't see any door for the oil filter. I have yet to change my oil so I don't even know where the filter is yet.
The G-series shield doesn't mount to an M. As for the other things - see above comments.Larz wrote:I'm sure this piece would be much stronger than the plastic sheild we have now, and it has a door to make oil and filter changes much much easier. Having said that, I see two issues that prevent me from buying it.
1) There are slots in the sheild which will allow rain, dirt, and road debri into the engine compartment.
2) It isn't wide enough to reach from one side to the other which also leaves us with filthy engine compartments.
I'm hoping that picture shows the G-model sheild mounted on an M- model and the actual finished product will be the proper width and, hopefully, no slots or holes that allow dirt and grime to collect on our belts, hoses, and engines.
Agreed.TDot wrote: I would personally prefer no unnecessary vents/holes...looks underneath the car is meaningless to me. As far as venting air, if stock didn't see the need for it in a place like this then I don't see the need, just my opinion. Good work overall.
Holy Mary !tollboothwilley wrote:TDot wrote:Doesn't the original go across the entire bottom, why doesn't this? And why are there slots and holes in it; won't that build up grime on the inside?The G-series shield doesn't mount to an M. As for the other things - see above comments.Larz wrote:I'm sure this piece would be much stronger than the plastic sheild we have now, and it has a door to make oil and filter changes much much easier. Having said that, I see two issues that prevent me from buying it.
